Go Back   Corral.net : Ford Mustang Forums > Classifieds > Cars > Mustangs For Sale/Wanted, 1987-1993
Thread Tools Display Modes
Old 08-31-2008, 06:12 PM   #1
331 LX Eric
1991 LX Coupe, 41,541 miles, 331, Tremec, Extremely Clean
For Sale: Car has a ton of top shelf parts. Here's the quick summary: (If you're interested in the car, I can email you all the details.)
- I'm the second owner of this car. I purchased it about 14 years ago w/ 21,000 miles on it.
- 331 cu. in. DSS stroker (about 2,500 miles on it)
- Tuned by Livernois
- Tremec 3550 tranny (ditto)
- Bogart racing wheels
- Wilwood brakes
- 41,541 original miles on the car as of today
- Always garaged
- Very rarely seen rain in the last 14 years
- No dents on this car. It is straight as an arrow.
- This car is in excellent shape...you have to see it to appreciate its condition.
- Runs consistent 12.1x or 12.2x @ 114mph on BFG Drag Radials. Since installing the 331 & Tremec, I've raced it about 8-10 times down the 1320. Very solid car.
Please feel free to ask questions. Price $11,500. Thanks, E
331 LX Eric is offline   Reply With Quote
Old 08-31-2008, 10:13 PM   #2
9secgt
91 coupe
eric, send me every detail you can on this car. i like what i see so far. thanks, r. booker mdpd 305-213-2000
9secgt is offline   Reply With Quote
Old 08-31-2008, 11:01 PM   #3
331 LX Eric
r. booker - I'll get you more details in the morning (going to bed now). I have attached a few more pics. I'm not a very good photographer
Thanks, E
Old 08-31-2008, 11:02 PM   #4
331 LX Eric
One more pic...
Old 09-01-2008, 01:23 AM   #5
michaels86gt
All I can say is WOW !Just a couple thousand out of reach.
__________________
1986 LX Coupe
1988 LX Coupe
1990 LX Coupe Black w/Black 25th Anniversary
1986 GT 1 of only 392
1986 SVO 9L
1993 LX Coupe 11.99/116 street tires
1984 GT
michaels86gt is offline   Reply With Quote
Old 09-01-2008, 08:58 AM   #6
331 LX Eric
Michael - thanks for the compliment.
A few more pics from this morning in different light...
I'll be posting much more detailed information regarding the upgrades later today. Thanks, E
Old 09-01-2008, 09:27 AM   #7
331 LX Eric
ENGINE DETAILS:
DSS 331 Stroker Kit
- Upgrade to 4340 forged steel crank
- Upgrade to 4340 forged steel H-beam rods
- Upgrade to Probe Industries Sportsman Race Series TFS-TW flat-top pistons
- Upgrade to Federal Mogul Plasma Moly (ductile iron) ring set
Cam, Intake, TB, MAF
- Anderson Ford Motorsport N-41 cam
- Trick Flow Street Heat intake manifold (1500-6500rpm)
- Accufab 75mm TB
- Pro-M 75mm "Bullet" meter
Cylinder Heads
- Trick Flow Twisted Wedge, ported and polished (clean up, smooth) Fererra 6000 one piece valves.
Oiling System
- Canton 7 qt deep sump oil pan
- DSS Pro windage tray
- Melling high volume oil pump
Upgraded Engine Accessories
- DSS main support system - 6061 aluminum w/ARP studs
- Fluidampr harmonic damper - 28 oz
- Energy Suspension motor mounts and transmission mount
- Cloyes true double roller timing chain set
- Block protector w/torrington bearings
Bolts, Gaskets, Miscellaneous Parts
- ARP Water pump/timing cover kit
- ARP Head stud kit
- ARP Camshaft bolt
- ARP Termostat bolts
- ARP Distributor bolt
- ARP Oil shaft
- Ford roller pilot bearing
- March crank pulley spacer .645"
- FEL-PRO #1262 intake gaskets
- FEL-PRO Loc-wire 4.145 bore
- FEL-PRO #1415 exhaust gaskets
Engine Machining at Fowler's (long-time Columbus, OH engine shop)
- Engine hot tank
- Engine hone
- Engine over bore (.030")
- Engine spin balancing to 28oz (crank, flywheel, damper)
Engine Specs
- 4.030 Bore
- 3.250 Stroke
- 5.315 Rod
- 4.100 Gasket bore diameter
- 0.041 Gasket thickness
- 1.250 Compression height
- 8.206 Deck height
- 4.025 Piston diameter at top ring land
- 0.175 Distance from top of piston to ring land
- 5.000 Total valve relief volume
- 58.00 Combustion chamber volume (heads were milled, intake side too)
Final compression ratio: 10.02:1 Runs on pump gas (93).
More info to come, stay tuned! Thanks, E
Old 09-01-2008, 10:04 AM   #8
331 LX Eric
Here is the original sticker from the car...
More interior shots...
Thanks, E
Old 09-01-2008, 11:12 AM   #9
88GTStreetRod
Very impressive coupe, My opinion... It's under priced. This car is a steal!! Very hard to find these cars in this condition. Your gonna kick your self in about a year after you sell this car.
88GTStreetRod is offline   Reply With Quote
Old 09-01-2008, 11:30 AM   #10
91svtcoupe
91svtcoupe's Avatar
Trader Feedback: (70)
x2
X2
I agree....That is a very nice low mileage coupe. You can't find cars that are that new on the inside...You can make cars look good on the outside but Interior is a pet peave of mine. I love the car..good luck with the sale. I would say it would be worth more like $15000.00
Any HP numbers?
or coarse I am partial to white coupes....lol
91svtcoupe is offline   Reply With Quote
Old 09-01-2008, 03:16 PM   #11
331 LX Eric
The following HP/TQ numbers were measured on a Mustang Dynamometer at Livernois at the rear wheels:
330 HP @ 5250 rpm
355 TQ @ 4000 rpm
With a 17% drive line loss, at the motor would be
398 HP
428 TQ
Air/fuel ratio was near 12.30:1 to 12.40:1 during the entire pull. Thanks, E
Old 09-01-2008, 05:12 PM   #12
331 LX Eric
All PM's replied to.
I've gotten a few questions about the rear ride height. I know it looks like a hoopty wagon all jacked up like that!
Here's the deal, I've got Moroso drag springs on the car. The first time I installed the rear set, I cut them way too short. So, I bought another set and this time I was way too conservative and didn't cut them enough. I just haven't gotten around to removing the springs (again) and trimming them a little.
Also, the price is $11,500 OBO. I forgot the OBO part earlier. Thanks for all the interest in this car! E
Old 09-01-2008, 10:27 PM   #13
Cobra231
What brake setup is on the rear?
Cobra231 is offline   Reply With Quote
Old 09-02-2008, 01:26 AM   #14
Black01_GT
bump for a super clean, gorgeous car
__________________
2007 GSX-R 750 - Sold
2001 Mustang GT - Sold
1988 Mustang LX
Black01_GT is offline   Reply With Quote
Old 09-02-2008, 08:33 AM   #15
331 LX Eric
Rear brakes are drum w/5 lug. I forget what the size is.
Thanks, E
Old 09-02-2008, 08:42 AM   #16
Couped-Up
Cleanest coupe Ive ever seen! Good luck on the sale. I wish I had the money....
Couped-Up is offline   Reply With Quote
Old 09-02-2008, 09:24 AM   #17
331 LX Eric
TRANSMISSION/GEARS:
- Fidanza aluminum flywheel
- King Cobra clutch (2500 miles on it)
- Tremec 3550 HD (2500 miles on it)
- 3.73 ring and pinion (Ford Motorsport - 2500 miles on it)
- McCloud steel blow-proof bellhousing
- Lakewood driveshaft safety loop
- Ford Motorsport aluminum driveshaft
FUEL:
- 155 lph fuel pump
- Ford Motorsport 24 lbs injectors
EXHAUST:
- BBK Equal length shorty headers 1 5/8"
- BBK off-road H-pipe 2.5"
- Dynomax Super Turbo mufflers w/2.5" stainless steel pipes
SUSPENSION:
- Steeda upper and lower control arms
All these parts have about 2,500 miles on them
- Moroso drag springs (4)
- Strange Engineering 10-way adjustable drag shock
- Strange Engineering 10-way adjustable drag strut
REAR-END:
All parts have about 2,500 miles on them
- Auburn gear Pro differential (8.8" w/31 spline)
- Moser 31 spline racing axles w/C-clips (w/ 3" wheel studs)
- T/A Performance 8.8" girdle cover
Thanks, E
Old 09-02-2008, 10:26 AM   #18
tjmayer
HOLY BAD ASS.
tjmayer is offline   Reply With Quote
Old 09-02-2008, 10:53 AM   #19
blachatch
im in cleveland pm me your phone number please
let me know asap!
__________________
1991 mustang LX coupe
1993 mustang lx black/black
blachatch is offline   Reply With Quote
Old 09-02-2008, 11:51 AM   #20
331 LX Eric
All PMs replied to. Thanks, E
Old 09-02-2008, 02:49 PM   #21
331 LX Eric
Old 09-02-2008, 03:47 PM   #22
88GTStreetRod
Someone buy this car, I can not stop looking at it. Makes me want to trade my Saleen for it.
Old 09-03-2008, 01:22 AM   #23
9secgt
88gt
hey 88gt did you ever sell that beautiful 88 with the red interior you had listed a few months back? i did talk to eric and i am waiting on pics from the underside ref the 91 coupe. timing is everything. r. booker mdpd
Old 09-03-2008, 01:26 AM   #24
fast281
Damn, me too
__________________
89 Saleen, 347ci
361rwhp / 379rwtq
fast281 is offline   Reply With Quote
Old 09-03-2008, 08:07 AM   #25
88GTStreetRod
Yup, it's gone
Bump for a great coupe!!
Old 09-03-2008, 08:13 AM   #26
chawkins2001
chawkins2001's Avatar
Eric
Please call me
Craig
(404) 6417595
__________________
06 E55 AMG
04 Comp Orange Vert Cobra-10K original miles and True Forged RS Tens-455/484
chawkins2001 is offline   Reply With Quote
Old 09-03-2008, 10:59 AM   #27
331 LX Eric
Guys, I forgot to list a few other mods the car has:
- Griffin aluminum radiator (3 core, I believe)
- BBK bolt-in subframe connectors
- Pro 5.0 shifter
- BBK Cold-air induction kit
- 1.72 Ford Motorsport roller rockers
I'll try to get more pics (undercarriage) up later this week. Thanks, E
Old 09-03-2008, 11:19 AM   #28
blachatch
did you get my last pm? let me know
__________________
Old 09-03-2008, 11:26 AM   #29
331 LX Eric
I just replied to all PMs. Thanks, E
Old 09-05-2008, 05:54 AM   #30
chawkins2001
any updates?
__________________
06 E55 AMG
Old 09-05-2008, 07:56 AM   #31
331 LX Eric
SALE PENDING.
Old 09-05-2008, 04:27 PM   #32
mondays
If your sale falls through would you be interested in a trade for a Sliver Procharged Notchback
mondays is offline   Reply With Quote
Old 09-05-2008, 06:27 PM   #33
RUN4BUX
If the sale don't go thru, call me at 205-486-0893 or Pm me your number and Ill call you.
I can't believe this car didn't sale first day.
RUN4BUX is offline   Reply With Quote
Old 09-05-2008, 06:53 PM   #34
86turbo trooper
pm sent
86turbo trooper is offline   Reply With Quote
Old 09-06-2008, 09:06 PM   #35
Raist103
still have it? a/c?
Raist103 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
