Thread Tools | Display Modes |
| Sponsored Links | |
Advertisement |
#72 | |
Trader Feedback: (45)
__________________
01 GT Vert bullitt intake 4:10 gears Mac LT's Mac Pro Chamber Vortech V2 Intercooled 3.12 pully Stock Longblock FRPP Aluminum D/S Tokiko Shocks Struts Springs 13lbs 437/384 "A lazy Man works Twice" |
#73 |
__________________
2004 GTO - Full Lovells Suspension, "baby cam" 389/378 SOLD - 2001 Mineral Gray GT Vert - 446hp/427tq Stock Longblock Tuned by Bob Kurgan SOLD - 2003 SVT Focus Euro Package - K&N Filter, Stock as a rock with 100k+ miles... |
#75 | |
__________________
#76 |
Been running almost 13psi non-IC'ed all year, with over 25 passes down the strip, and 200 miles driven a week.
__________________
Cory Swinerton (AKA: mtrsprt) 1999GT 2V Vortech. (Stock T-45) 10.91 @ 126.92 (1.47 60') Video - http://vimeo.com/5763194 |
#77 |
IS UR REAR END BUILT?
__________________
#78 |
Nope. Just 3.73's and stock 28 spline axles. 31 spline setup going in possibly next week. Last time at the track, my ET streets hooked hard and bogged the engine from 4500 down to 2600 lol. I need to launch at about 5300rpm or so, I might try it Friday.
__________________
#79 | |
__________________
#80 |
i have been running 75mm BBK throttle body, C&L plenum, DIABLOSPORT tunner,& a POWERDYNE supercharger w/6lbs of boost w/a boost pump for 3 years and just today i swaped out the pulley w/an 11lb pulley(there is quite a difference). we'll see how long it stays together. OH! and this winter i will be installing my PI heads w/comp cams 270's w/bee hive springs. yea, i'm pretty sure it's going to blow up after that, we'll see.
#82 | |
__________________
#83 | |
__________________
#85 | |
Formerly wolvee123
__________________
MY MUSTANG FACEBOOK GROUP, PLEASE JOIN, Club Chapters in Michigan, Indiana, Tennessee & Louisiana. EVENTS PLANNED FOR ALL ACROSS THE US and not limited to just the club. http://www.facebook.com/groups.php?ref=sb#/group.php?gid=252526394357 |
#86 |
I'd love to man, its the ultimate goal for my self to learn how to construct a kit, and have it work reliably.
I am short on $ at this point though, so it's on the back burner... ![]() May get a cheap fix and run some spray through it soon though, lol.
__________________
2000 GT 5 speed... WOOT! Almost stock. |
#87 | |
..just something to consider...
__________________
#88 |
im killed 2 tranys and one ring and pinion. i learned from the first trans to not use giggle juice in o/d ..burns the o/d band up at 50,000 miles. the rear end was a factory installed screw up!! it knife edged the pinion gear but the 430 gear is doing GREAT! i hope to someday to toast my motor but at 71,xxx miles the damn thing is going strong! i see a 5.4,cams, and more gas when it dies.
#89 | |
__________________
#90 | |
My 92K NPI motor has never been opened up. I have run gears, CAI and some exhaust upgrades for about 40K. I drive with enthusiasm, but I do rely on this car for everyday use, so whether I mean to do it or not, I must be going easy on it. Common problems I have seen in reading posts like this over the last 10 years; Very high RPM's. Doesn't matter how rich they set it up at the factory, if you top it out you will lean it out and break ring lands. Power adders and the leaner tune that usually goes with them. as a rule of thumb, spraying or boosting these 2v's wears 'em out. Plain old variability: It is a fact. Assembly tolerances allow for some head bolts, mains, etc. to be torqued down too hard, or not hard enough. ALL cars are like this, but they way most people drive, problems do not really ever become problems. Most drivers don't push their equipment the way we as enthusiasts do. I think what I have learned is this: If I go for a power adder I intend to be as picky as possible about who does the build, based at least as much on their durability record as on the performance gains they achieve.
__________________
2001 Cobra True Blue. OEM except for the air filter Last edited by Sea Pony; 09-08-2008 at 03:25 PM. |
#91 |
i havent had the spray in almost a year. ive been running all motor and it gets driven everyday to work and every place i go. hell i drove it to indiana with my 90/10s,50/50s,no sway bars,eibach drag springs with no problems other than a blown manifold gasket after i got there. the main rule i live by is if your going to play well your going to pay sooner or later! im still shooting for a 7.9x in the 8th with a all stock 4.6 with a 4r70w trans. i think im going to swap out the 3400 stall and go up to a 4000 stall with a trans refresh after summer. ill be getting the spray back before too long..people are starting to catch me up top so more is needed.
#92 | |
__________________
#94 |
tuning is key....get it right and enjoy!!
__________________
#95 | |
Awesome video
__________________
http://www.corral.net/photopost/data...162_edited.jpg |
#96 | |
Ron still has the stock bottom end. Here's a quote from another post.
__________________
2000 GT 4R70W, J-Mod, spoiler moved back 2 3/4", smoked headlights, CDC sequential taillights, Steeda sport springs, C/C plates, alum. lca's, Bullitt front brakes, Russell stainless lines, KB Super Subs, SpinTech Pro Street cat-back, BBK CAI, Accufab 75MM TB/plenum, FMS 4.10's |
#97 | |
__________________
#98 |
Windsor 2v > Romeo 2v
Most of the blown up stories are Romeo Engines. Look at all the posts from the 99-2000 Windsor guys. They all brag about upper 400's power numbers and still going strong. The one guy with the 99/00 and a blown up motor says it somehow was an early npi romeo engine. I don't know exactly the differences, but it seems like the windsor motors are much stronger.
__________________
2000 laser red mustang gt Windsor Block, cast steel windsor crank, Manley I beam rods, manley 11 cc flycut pistons, manley rings, clevite tri metal bearings, 04 cobra aluminum flywheel/clutch setup, ported heads, comp 270 cams. Flowmaster 2 chamber, bbk cai, bbk catted x pipe, 75mm tp and ported stock plenum, autolite 103 plugs. Zex 125 shot. Jba shorties, 3.73's, 31 spline axles, lpw diff cover. focus fuel pump, Recaro seats, bullet wheels, nittor dr's. Steeda tri ax shifter. Bolt in Sfc's. Eibach springs, bullit shocks. 92 ford tempo(pos daily driver) 81 mustang drag car |
#99 | |
__________________
#100 |
"Look at all the posts from the 99-2000 Windsor guys. They all brag about upper 400's power numbers and still going strong."
__________________
#101 |
I don't know, thats a tough one.
It seems most of the posts that are about spun rod bearings involve Windsor 4.6's. Plus there are less Windsor 4.6 'Stangs on the road than there are Romeo 4.6 ones, not as likely to find a blown Windsor 4.6 Mustang. Although, i'd like to get some positive proof behind that, as my GT has a Windsor motor...
__________________
#102 | |
__________________
#103 |
My 00GT is still going strong. Just raced a Shelby GT500 on the street last week and had fun beating him :-) The look on the guys face was priceless...LOL.
__________________
Chris Kauffman 2000 Saleen S-281 Replica Bullitt Intake with Vortech V2-SQ 3.12 blower pulley ATI-3 core intercooler--3.5" univer Kauffman Motorsports SCT switch chip many more mods 530rwhp & 463rwtq SAE on pump 93 octane (stock short block and stock heads) 1991 Mustang Notch 2.3L SN95 front and rear brake upgrade 03 Mach1 calipers/rotors 302 EFI conversion with AOD NOS Big Shot (150hp shot) BBK LT headers, BBK H-pipe, Mac cat back MSD 6AL 1988 Mustang LX drag car |
#104 | |
__________________
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
