Support corral.net, please click our advertisers!
#7 |
That's rough..
__________________
Tremec 3550, Spec stage 2,Alm. Driveshaft, SteedaTri-Ax, 3.73's,65mmTB, adjustable FPR, BBK long tubes, BBK h-pipe w/o cats, Edelbrock exhaust,e-fan, 50/50 and 70/30 lakewoods, LCA's, Eibach drag launch,GT40upper/lower, GT40 heads, 1.7 RR's, 75mm Mass-Air, 24lb's.263hp 306ft/lb |
#8 |
Just another example of a chevy spraying more than it can handle trying to beat a ford.
__________________
88 coupe, 351 cleveland, unported 4V heads, buddy rawls custom solid roller, diamond domes, 6'' h-beam rods, stock 4bolt block/crank, holley strip dominator, 950HP holley, hoosier 28x10, 90/10s, UPR pro rear kit nonstroked, stock iron heads and NO NITROUS!!!!!!!! 10.08@134.83 / 6.44@108.21 (1/8th) |
#12 |
Is it usually a wet or dry kit that has more of a tendancy to do that?
__________________
1992 Gt 306,K.B. hyper pistons ,cobra intake & gt-40 heads,b-303 cam,24# FRPP inj,PMAS maf sensor,FRPP shorties, cobra hood & rear bumper, & so on.in other words moneypit.
#14 |
Sucks to be that guy!!!
__________________
84 GT T-top, 306 GT40P 5 spd. Trick Flow stage 1 cam, 1.6 roller rockers, Edlebrock RPM Air Gap, BG Speed Demon 650, Mallory ignition, Full Mac exhaust, FRPP driveshaft, UPR pro rear suspension, Moroso drag springs, Lakewood struts/shocks, SOS anti roll bar, 4 point roll bar, 3100lbs with me!!!! |
#16 |
Gotcha,Ive heard our intakes arent designed to have fuel going thru them.
I guess a dry kit is the way to go,any disadvantages to a dry kit?
__________________
#22 |
I know this is a really old thread but you will be glade i was using the search option....
did anyone else that saw this video see the fire coming from exhaust and right before the big bang the fire went away.... could the explosion been from him staying on the nitrous and getting out of the throttle? |
#24 |
At least parts should be cheaper now to fix the GM junk....
__________________
90 LX Triple Black Vert, 306, B303, Cobra 1.7 Roller Rockers, GT40 ported iron heads, Cobra intake, shorties, 65mm TB, 73mm C&L, 24lb injectors, Cobra front brakes, Lincoln rear discs, 3.55 gear, sub frame connectors, strut tower brace, H&R springs, Tokico struts/shocks, Flowmaster Thunderseries |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
So go look in the Gallery, and what you see is what you get.
Linear Mode
