Thread Tools | Display Modes |
#1 |
I have a 95 K-member/a-arms/spindles going on my 93 coupe. I'll be running 03 Mach-1 springs.
Which year run struts should I use (83-93 or 94-98)? I know one series is too short I just cant remember what year run it was. Thanks! Eric
__________________
P-86 460 Coupe militarymustang.info |
| Sponsored Links | |
Advertisement |
#4 |
Trader Feedback: (23)
Why are you going to install an SN95 K-member in a Fox? Is there a geometry advantage to this?
Darren
__________________
'83 5.8L TKO'd T-Bird on the bottle '93 5.0L Mustang coupe that beat your mom's LTD |
#6 |
If you're going to the trouble of swapping K-members, why dick around with a factory one when you can just as easily install an aftermarket K-member?
__________________
-- Robert King NASA AI #42, Texas Instructor, NASA Texas Region Instructor, TWS Perf. Driving School |
#8 |
$$. I cant afford a MM k member (the SN95 was next to nothing). MM is the only one I would buy. I have baby formula and diapers to pay for.
__________________
#9 | |
in that case, I wouldn't screw with the SN95 K-member. There's just not enough advantage to justify the effort of installing it.
__________________
#10 |
I already have the 95 K and the car is just a shell. I got the 95 K with the intention on using it on my 86, which would have made some improvements track width wise. Now I'm using the 93, so its going on it.
All I need to do is figure out which struts to use and bolt it on.
__________________
#13 |
So what are you going to do for fenders? I cannot help but wonder what the bump steer, ackerman...hell the whole front end could possibly be a mess to try and align. I would think it would cost quite a bit of money to get the car to align and drive right.
Darren
__________________
'83 5.8L TKO'd T-Bird on the bottle '93 5.0L Mustang coupe that beat your mom's LTD Last edited by d brune; 05-15-2008 at 10:07 AM. |
#14 |
The fenders will be rolled and I'm only running 245's up front. I'm using all the 95 suspension minus the struts, springs, bump-steer kit and camber/caster plates. I don't see any problems with getting it aligned.
__________________
#16 | |
I do know the control arms are .75" longer, increasing the track width.
__________________
#17 |
Supposedly the modular sn95 k-members have better geometry. Someone posted someplace that the 93-95 geometry was the same - no idea if true or not.
__________________
Got Vic? ESP Build Thread: corral.net/forums/showthread.php?t=916068 |
#18 |
Correct, the only difference is in the control arms, not the k-member itself. pre-87's (79-86) used a narrower k-member and the GT and SVO got longer (sn-95 length) control arms. So sn-95 control arms are actually 79-86 GT and SVO control arms. And you can use the longer control arms in 87-93 k-members to get a wider track width.
-Thomas
__________________
1988 Mustang Coupe 4.2L V6 - Magnuson MP112, Water I/C, Direct-Port N2O, BV heads, 215/220 cam, box upper, Custom Stainless LT's, E-Cutouts, Stainless X-Pipe, Borla stainless catback, 3.73's, FMS DS, Tube SFC's, Tube K, H&R Race's, Bilstein HD's, Dbl Adj LCA's, MM PHB, Torque Arm, Rear Adj Swaybar. |
#20 |
the MM site recommends that SVO owners use the SN-95 MM control arms to keep the same track width. If this is wrong please correct me.
Taken from MM's site: Maximum Motorsports Front Control Arms, designed for an SN95 Mustang, can be installed on a 1984-86 SVO Mustang. This will require the installation of a coil-over conversion kit. Installing the stock geometry MM Front Control Arms (MMFCA-7 or MMFCA-8) will retain the original track width and wheelbase of the SVO Mustang. -Thomas
__________________
1988 Mustang Coupe 4.2L V6 - Magnuson MP112, Water I/C, Direct-Port N2O, BV heads, 215/220 cam, box upper, Custom Stainless LT's, E-Cutouts, Stainless X-Pipe, Borla stainless catback, 3.73's, FMS DS, Tube SFC's, Tube K, H&R Race's, Bilstein HD's, Dbl Adj LCA's, MM PHB, Torque Arm, Rear Adj Swaybar. Last edited by Thomas; 05-16-2008 at 05:20 PM. |
#21 |
Read this whole thread as there is some really good tech and measurements in there that will answer some of your questions:
http://corner-carvers.com/forums/showthread.php?t=30274 Darren
__________________
#22 |
The SVO's used the early 80's continental front LCA's. The only thing they did was add track width to the front of the SVO. They're not the best performance piece as they are a little heavier than the stamped steel Fox versions.
There's a picture of one here in this thread. http://www.allfordmustangs.com/forum...-arm-ball.html
__________________
88 GT - Full Maximum Motorsport suspension "The Handler" 89 Saleen - getting some TLC Last edited by Goodson; 05-17-2008 at 12:19 AM. Reason: linky no worky |
#23 |
A few quick comments.
T-Bird SC, SVO and all SN95 FCAs have the same ball joint location relative to the inner bushing location. They have slightly different swaybar mounting hole locations. The "width" is about 14". All Fox (79-93) FCAs have identical geometry (except of course the SVO FCA). The "width" is about 12.75". The FCA mounting holes in the k-member have been moved around by Ford a lot over the years. Both in and out as well as up and down. On the SVO, the holes were moved inboard significantly to allow the "wider" FCAs to be used. The same is true of the SN95 k-members, the holes were moved inboard.
__________________
Jack Hidley Maximum Motorsports Tech Support |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
