Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > Road Racing/Auto X
Thread Tools Display Modes
Old 05-04-2008, 08:54 AM   #1
KAILUAZ
KAILUAZ's Avatar
Arrow 96 Cobra rack on SN95 K-member?
I'm going to run a 94-95 K member/spindles on my 93 notch. I can get a 96 Cobra rack for dirt cheap. Will this bolt right up? I know I will need a new coupler for the steering shaft.
__________________
P-86 460 Coupe
militarymustang.info
KAILUAZ is offline   Reply With Quote
Old 05-04-2008, 03:13 PM   #2
Jack Hidley
Jack Hidley's Avatar
Yes.
__________________
Jack Hidley
Jack Hidley is offline   Reply With Quote
Old 05-04-2008, 04:08 PM   #3
KAILUAZ
KAILUAZ's Avatar
Thanks Jack, you are the man with the answers! Yet another reason to buy MM.
__________________
P-86 460 Coupe
Old 05-04-2008, 06:14 PM   #4
WJL
Do not forget the new tie rod ends or a bumpsteer kit. Fox R&P use SAE threads and the newer ones are metric.
Saves some time at install.
WJL is offline   Reply With Quote
Old 05-04-2008, 06:27 PM   #5
KAILUAZ
KAILUAZ's Avatar
Yeah I was going to go with the bumpsteer kit. I need to drill out the spindle to use the bolt correct? I need to do some more searching around.
__________________
P-86 460 Coupe
Old 05-05-2008, 10:56 AM   #6
gt40mkII
Nope. Maximum Motorsports has a bumpsteer kit what will bolt to an unmodified spindle.
__________________
-- Robert King
NASA AI #42, Texas
Instructor, NASA Texas Region
gt40mkII is offline   Reply With Quote
Old 05-05-2008, 10:47 PM   #7
Jack Hidley
If you transfer the inner tie rods from your old Fox rack to the new SN95 rack, you won't need to change anything except the steering shaft.
__________________
Jack Hidley
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
