Go Back   Corral Forums > Power Adder Forums > Superchargers
Notices
Gallery Corral Parts Store Videos Advertising Info Blogs Outside the Fence Corral Home
Thread Tools Display Modes
Old 04-20-2008, 01:41 AM   #1
straightliner1
straightliner1's Avatar
Centrifugal blowers and preferred rear gear - hmmm?
I'll be putting together a stout rear end soon (8.8, 9" ends, tapered roller bearings, 33 spline clutch posi, etc.) and was curious on what everyone's preference for rear end ratios were? I had 3.55's when the car was N/A and might just get a new set of those, unless you sway me another direction.
I'm likely to wind up with 600+ to the wheels through a 6 speed. This will be a weekend "fun car" with the occasional trip to the track (both road and drag).
__________________
Justin
91GT - 347" Dart, T Trim, Meth inj, T56 in search of 600+ to the wheelie dealies. 91LX Trunk - Stock-ish, for now
05 F250 PSD 4X4 "Big Red" Mod(s): MBRP 4" t-back
straightliner1 is online now   Reply With Quote
Support corral.net, please click our advertisers!
Old 04-20-2008, 01:44 AM   #2
modo
modo's Avatar
26 " tire 3.27s, 28" 3.55s
__________________
93 GT
659 rwhp on 93 octane
modo is offline   Reply With Quote
Old 04-20-2008, 06:45 AM   #3
swinerton
swinerton's Avatar
I have always been partial to 3.73's in my rigs.
__________________
Cory Swinerton (AKA: mtrsprt)
1999GT 2V Vortech. (Stock T-45)
10.91 @ 126.92 (1.47 short)
Video - http://vimeo.com/5763194
swinerton is offline   Reply With Quote
Old 04-20-2008, 01:35 PM   #4
Carbuff91
Carbuff91's Avatar
subscribing...I have a blown setup and am moving to a 28" tire this year and have 3.55's currently.
__________________
91 GT 302, Edelbrock 6037's, Perf. RPM intake, PMS, 1.72 Rockers, 42lb injectors, 3.55 gears, 6 point cage, Granatelli lowers, TKO-600, lunati cam, AEM/PMS Tuned and 11lb/12-rib 3 core intercooled Procharger...list goes on.
http://www.MdPokersupply.com
"Bringing the Casino Home"
Carbuff91 is offline   Reply With Quote
Old 04-20-2008, 01:56 PM   #5
keesor
keesor's Avatar
I have 3:73's on mine and 1'st gear is worthless. I'll be switching to 3:55's sometime this spring.
__________________
91 GT, AFR 165's, Systemax II, F303, 42lb inj, Aeromotive fpr, 255 + T-Rex, PMAS Velocity, 75mm TB, FC 3000 Ign, MSD ProBillet, BBK shorties, 3" Magnaflow dumps, Auburn w/3.73's, TKO-600, Pro Motion Clutch, Diablosport custom tune, PLX wideband, SQ S-trim @ 12lbs, AFM Powerpipe. 531 rwhp 465 rwtq
keesor is offline   Reply With Quote
Old 04-20-2008, 07:59 PM   #6
swinerton
swinerton's Avatar
Don't switch to 3.55's just to think your gonna hook better in first. With the power your making, 1st will still be useless. I went to 3.55's from 73's, and to be honest, it wasn't worth the change, but I had a howl from the previous install that I couldn't stand.
__________________
Old 04-20-2008, 08:34 PM   #7
StarrMan
StarrMan's Avatar
I have 3.55's and thinking of going to 3.73's because of the closer ratios in my TKO-600, but I find it hard to justify the cost to only go 1 step in ratio
__________________
In Loving Memory Anthony Michael Starr 08/14/2007 - 01/21/2008
- 95 GT - Aluminum Heads, Cam, TMoss Cobra intake, S-trim, SCT BA2400, 55's, Longtubes, McLeod bell, TKO-600, 3.55's, etc
- 02 GT (Wife's Toy) - Auto, 4.10's, Lowered, Off Road X, Predator Tuner - 13.6@102
StarrMan is offline   Reply With Quote
Old 04-21-2008, 02:08 AM   #8
straightliner1
Lots of good opinions here -
I agree with the power the blower cars are making now, 3.73's or higher in my opinion would be worthless. Just running my HCI 302 with the 3.55s it would blow the tires off in first but 2nd and 3rd were a delight!
__________________
Justin
Old 04-21-2008, 03:54 AM   #9
94tealGT
94tealGT's Avatar
I had 3:73's with my old 26's..useless.
Now have 3:55's and 28's on order
Chris
__________________
94tealGT
"Build it fast enough to break it, then build it faster, fast enough to put in an automatic...then it becomes boring."-Hot Rod the Movie-1979
94tealGT is offline   Reply With Quote
Old 04-21-2008, 07:14 AM   #10
Carbuff91
Carbuff91's Avatar
Question
What causes that howl anyway? The pinion gear wasn't installed correctly and the gears aren't aligned?
__________________
Old 04-21-2008, 09:13 AM   #11
swinerton
swinerton's Avatar
Yes, very poor carrier shimming, and pinion mesh.
__________________
Old 04-21-2008, 11:10 AM   #12
JimsYellow88
JimsYellow88's Avatar
Trader Feedback: (44)
I tried the 3:27's in my car and ended up going back to the 3:55's. With the 3:27's, it just felt alittle doggy when cruising at 50mph. It was too fast to drive in 4th, but not enough RPM's for 5th. This was with A TKO and 26" tires.
I would say that with your 6 speed that you may want to even go with the 3:73's for a street car. But I like my 3:55's in my fox.
Jim
__________________
88 GT, Street Car, Dart Block 331, YS-Trim ,TKO
649 RWHP! 565 RWTQ! (on 93 octane, Mustang Dyno)
10.79 @130 MPH (Old S-Trim combo)
**Member of the 2-piece Stock Block Club**
JimsYellow88 is offline   Reply With Quote
Old 04-21-2008, 06:11 PM   #13
hbk_136
hbk_136's Avatar
Trader Feedback: (50)
yeah same here, im likin my 3.55 gears. Still have traction issues, but my tires are kinda small.
__________________
96 Triple Black GT Vert Supercharged -- 401rwhp / 394rwtq
Vortech V1 S-Trim @ 10psi--2003 PI Engine--36# injectors--90mm L-MAF--AFM PowerPipe
Accufab Plenum + 70mm TB--BBK LT's--MAC O/R Prochamber--Magnapaks
F+R 13" Brakes--3.55's--255lph Pump & T-Rex--Snow Stage 2 Meth Kit
hbk_136 is offline   Reply With Quote
Old 04-21-2008, 06:31 PM   #14
muttstang
I really like my 3.73s with the vortech
__________________
Mustang sold, time to rebuild a bike
It's the American dream, not the American guarantee. You have to go out and get it... Don't expect it to be given to you.
muttstang is offline   Reply With Quote
Old 04-21-2008, 06:47 PM   #15
ryans88gt
I thought so too, the previous owner of my 89 had the 3.55s installed and they whine at about 45-55 mph only. I thought it was a gear mesh problem, but the backlash was perfect at 0.011", the gear mesh was centered using marking compound, and there was no runout on the ring gear. There was no unusual wear either and it has an aluminum drive shaft. Why was it whining? I still don't know, but I just buttoned it up and it has been fine ever since, but still whines.
ryans88gt is offline   Reply With Quote
Old 04-21-2008, 09:35 PM   #16
buddha
buddha's Avatar
x2
I'm running a set of 3.27's with a 5-speed and less rwhp. Rolling in 2nd and matting the gas at 30 mph will put down as much BFG Drag Radial rubber as you like!
That being said, it can still be managed by pedaling it if your goal is traction............somewhat. LOL!
__________________
93' Cobra with a cogged NOVI 2k, R331
buddha is offline   Reply With Quote
Old 04-21-2008, 10:28 PM   #17
Macs Stang
I am going to be the one crazy guy and say I have 3.90's out back with my t-trimmed boss 347. Granted I can rev a little higher then a standard 302, but we'll see once it gets tunned and I get to the track. I am planning on mid 130's to 140 mph traps. I have 26x11.50-15 et streets so we'll see.
I might have to go with a 28" tall tire. Regardless if you have the proper suspension things will work out in the spin to win department.
__________________
BLOWN BOSS 347-CAMSHAFT INNOVATIONS
'91 GT: a2w intercooled T-trimmed Boss 347 through a Face-Platted TKO 600, w/ 2 1/2" exhaust.
635 rwhp / 605 rwtq
Macs Stang is offline   Reply With Quote
Old 04-22-2008, 09:11 AM   #18
JimsYellow88
You may have some issues getting through the traps at those speeds with the 3:90's and 26" tires. Maybe someone else can chime in but, I "think" I was at about 6000 rpms in 4th at 131 with my 3:55's and my 275/40/17 dr's (which are 25.75" dia). FWIW
Jim
I do think the original poster may be able to go with a little more gear for the street considering he has the six speed.
__________________
Old 04-22-2008, 10:48 AM   #19
Macs Stang
Jim
I have 26" bias ply tires that will grow on the top end, but probably not enough. I will more then likely just buy a set of 28" tall tires for the track.
My old et streets lasted me 6 years so I think it might be time to replace them.
__________________
635 rwhp / 605 rwtq
Old 04-22-2008, 02:29 PM   #20
TonyG
TonyG's Avatar
I've had 3.27s, 3.73s, and 4.10s, and honestly I like the 4.10s the best. The gears pull hard at low RPMs, then the centri blower takes over and pulls even harder to the redline.
Here's a video with the 4.10s on street tires, to give you an idea of how the RPMs and MPH match up:
http://videos.streetfire.net/video/S...mph_153846.htm
On the dragstrip, I trap 122+ so I run a taller tire (28"). The 28"/4.10 combo is similar to a 3.73 ratio with stock tiress. Here's another clip on the dragstrip:
http://s132.photobucket.com/player.s...fs=1&os=1&ap=1
As you can see, 1st gear isn't "useless" at all. You're putting more torque to the tires, so you need more traction. Bogging the car down with taller gears isn't the answer.
__________________
Black 99GT 35th, 5 sp, intercooled V1 S-Trim
518 rwhp, stock shortblock
11.035/129.77/1.595
http://www.youtube.com/watch?v=q2ak8fsodjA
TonyG is offline   Reply With Quote
Old 04-22-2008, 06:06 PM   #21
buddha
buddha's Avatar
Let's remember that the poster is looking for a gear for the street 99% of the time.
With the 6-speed you can definitely get away with more gear, but I still personally wouldn't run more than a 3.55 gear with the power output he's looking at.
And yes, 1st gear on the street will be useless, regardless of the what gear is out back.
__________________
Old 04-22-2008, 09:39 PM   #22
phillie356
phillie356's Avatar
Trader Feedback: (23)
3.73 works for me.....
__________________
1993 electric red notchback
F RGR!
phillie356 is offline   Reply With Quote
Old 04-23-2008, 11:08 AM   #23
OWENMUSTANG
OWENMUSTANG's Avatar
Trader Feedback: (22)
I have 3.73's now. I have a set of 3.55's in the garage..
I love the 3.7's w/ the T-5.
Not sure wich way to go when I get the rear set up.. (also have a TKO 60 to install)
I have 245 drag radials... doesn't hook until 3rd with the 3.73's
__________________
93 notch, 5 speed black on black
stg3. bbk headers,373's,vortech sq, snow kit,3g alt, 255 intank,afr165's,b-21, tmoss ported rpm
OWENMUSTANG is offline   Reply With Quote
Old 04-23-2008, 05:27 PM   #24
408fox
Trader Feedback: (31)
4.30's here with a t-trim
408fox is offline   Reply With Quote
Old 04-24-2008, 12:18 AM   #25
StarrMan
StarrMan's Avatar
If your TKO600 has the 2.87 first gear then keep the 3.73's. The first gear in the T5 is 3.35 and with my 3.55's it was a real stump puller, but with the 2.87 first gear it seems a bit doggish and I have to launch at quite a bit higher rpm to keep it from bogging. Just my opinion though and my car is a bit heavier than yours
__________________
Old 05-17-2008, 07:48 PM   #26
straightliner1
Back from the dead!
I'll be ordering gears and a 33 spline carrier Monday. Anyone else care to chime in? I'm leaning towards my usual 3.55 setup but I have never driven a 6 speed car before, wondering if the jump to 3.73's would be a wiser choice?
Decisions...decisions...
__________________
Justin
Old 05-17-2008, 08:45 PM   #27
Thunder5.0
Thunder5.0's Avatar
410's 28" tire here
Thunder5.0 is offline   Reply With Quote
Old 05-17-2008, 10:36 PM   #28
fastgreen94
fastgreen94's Avatar
355s even with the 6-speed.
__________________
Old Car: 94 Green GT 5spd
502rwhp/461rwtq
New Car:??
fastgreen94 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
