Go Back   Corral Forums > Modular Tech Forums > SVT & DOHC
Notices
Thread Tools Display Modes
Old 05-07-2008, 04:18 PM   #71
duane v
duane v's Avatar
Originally Posted by Bob Cosby View Post
Just ran some quick math. 129 mph @ 3350 lbs = ~495 RWHP. Pretty neat!
Will be even neater to hear how much rpm it takes to get there.
yeppers........ So now I would like to see his dyno sheet and basic engine specs (mainly cubic inches and CR)
DA snake boy!!!!
duane v is offline   Reply With Quote
Support corral.net, please click our advertisers!
Old 05-09-2008, 07:58 AM   #72
olgreydog7
olgreydog7's Avatar
It'll all come out in the 5.0 spread I'm sure. Naz will be more than willing to share once that comes out. He has helped me out alot in trying to recreate one of his old builds.
__________________
99 Cobra-bb/stroker, T-56, lots of suspension
olgreydog7 is offline   Reply With Quote
Old 05-09-2008, 08:04 AM   #73
na svt
Originally Posted by 97svtsnake View Post
i want to stay NA but with the 408 LS1s and the c6 Zo6 mod cars running around it looks like unless i d boost or spray it's a no contest can those same levels be reached by us also because i stopped trying to follow you after you dropped mony on that fr500 intake and that only being a 1/4th of the combo
this motor has no fr500 parts...
na svt is online now   Reply With Quote
Old 05-09-2008, 09:53 AM   #74
MP John
MP John's Avatar
The engine build tech article is complete and at the printer. The article / magazine will be out in mid-June.
There is no dyno graph in the article. I think you guys nailed the hp.
__________________
MP John
Modular Performance
FelPro head gasket sale
Quality parts at affordable prices.
248 446-8767
MP John is offline   Reply With Quote
Old 05-09-2008, 12:10 PM   #75
Cobra925
Just curious will the article have cam specs and/or cfm's for the heads and intake?
__________________
01 Cobra- Silver
CAI, MF cat back, MF X-pipe, Pro 50 shifter,T-56 tranny built by D&D,11" HD clutch, Aluminum drive shaft, H&R Springs, Brembo pads and rotors, Steeda Uderdrive pullies, 8.8 Built live axle MM PH & TQ ARM 4:10, Bilsteins Shocks/struts, MM C/C plates, MMXLSFC's, weight reduction.
Cobra925 is offline   Reply With Quote
Old 05-09-2008, 09:53 PM   #76
Stang32v
OMG!
I just sprayed her with a little 200 shot! WOW, she love it!!!!!!!!!
C16 fuel for safety, 10.7-8 AFR on the WB and some conservative timing. God bless the modular motors! Put the hurt on the slicks! LOL!
She pulls so darn hard that got me by surprise. The pull felt much harder than my Turbo set up. Easy 9s I must say!
Video coming soon!
Naz
__________________
1999 Mustang Cobra
537RWHP All Motor!
Nazty Performance
Stang32v is offline   Reply With Quote
Old 05-10-2008, 07:16 AM   #77
olgreydog7
olgreydog7's Avatar
This is true. I have that intake
I've heard the bores are too short in the stock mod blocks for a reliable stroker. Are the Boss blocks different? It's like $500 different between the BB/stroker and the BB Boss block.
__________________
Old 05-10-2008, 12:49 PM   #78
Cobra925
GT heads I take it?
__________________
01 Cobra- Silver
Old 05-10-2008, 01:05 PM   #79
IPSGreg
IPSGreg's Avatar
Originally Posted by Cobra925 View Post
GT heads I take it?
I would guess that this is a ford racing big bore block with a stroker rotating set up. Which would make it easiest to port a set of 03 castings since he has a sully intake and the pics he has posted does not show any welding on the heads or intake that I can see. It is a 322-324 ish ci motor with pretty high lift cams and good duration. Most likely the heads have larger valves to take advantge of the larger bore size. The entire combo is just working together to make the power that it is with a compression ratio of around 12:1. The pistions probably are notched becasue of the cams and the larger valves. I am guessing that the installed deck height of the pistons is pretty low which along with the bore, and what not gets the compression up there and makes for a nice quench and even burn in the cly.
This is my guess I wonder how close I am. What I am curious to see will be the cam numbers choosen with the runner length and extra cubes the motor has.
All in all nothing about it is complicated, just planned out with common sense in mind. Kudos to all involved.
__________________
Greg
99 Cobra
IPSGreg is offline   Reply With Quote
Old 05-10-2008, 06:29 PM   #80
na svt
When's the 300 shot coming...are ya scared?
Old 05-10-2008, 06:33 PM   #81
na svt
Old 05-10-2008, 08:59 PM   #82
Stang32v
Some research and planning to get the right parts working together is what it counts!
@ NA,
The 200 is good....very goood! The 300 will come but it will be on the controller. I was unable to put her on the dyno today. Just wanted to see the power curve.
Ill be at the track on Wen and see what she will do. I'm thinking that the 4.56s will be the limiting factor at this time.
Depending on how that goes Ill drop the gear to a 4.30 but we will see...
Naz
__________________
1999 Mustang Cobra
537RWHP All Motor!
Nazty Performance
Old 05-11-2008, 08:21 AM   #83
olgreydog7
olgreydog7's Avatar
you've got a solid rear right? If you were still IRS I'd swap pumpkins with you, I have 4.30s but want 4.56s. I can't wait to see this thing up close! And, get mine back together.....
__________________
Old 05-11-2008, 12:01 PM   #84
Stang32v
I had a solid since 2003....I can swap and set the gears very quickly! LOL! Its just a PITA.
Let me know when you are back in town...
Naz
__________________
1999 Mustang Cobra
537RWHP All Motor!
Nazty Performance
Old 05-11-2008, 12:33 PM   #85
Janstang
Janstang's Avatar
Man I hate reading your posts.. Our track is still closed. Snowed again yesterday. Damn global warming you know..
__________________
01 Mustang Cobra
T88 turbo, 5.4L, Cobra R heads, Powerglide tranny, plus much more..
Janstang is offline   Reply With Quote
Old 05-12-2008, 08:25 AM   #86
olgreydog7
olgreydog7's Avatar
Naz
Rats! Will do. I have to reset my clutch pivot ball, it worked loose and my fork is hitting my pressure plate. So I have to drop the tranny, I'll put in the aluminum flywheel while I'm in there. Then I'll get the subframes, irs brackets, and rear strut tower brace welded up. Once all that is done, I'll start pulling the heads. That really shouldn't take long for me to do. The heads may take me a few days though.
__________________
Old 05-18-2008, 09:30 PM   #87
Stang32v
Fun!
http://videos.streetfire.net/video/N...ant_161933.htm
http://videos.streetfire.net/video/N...ino_161942.htm
__________________
1999 Mustang Cobra
537RWHP All Motor!
Nazty Performance
Old 05-19-2008, 09:02 AM   #88
Guido in Da Cobra
Guido in Da Cobra's Avatar
holy ass. that thing must be sacreligious on the sauce.
__________________
1998 Cobra vert- H/C/I, 3" ex, T56, 4.56
America; We're only tough with tax payers.
Guido in Da Cobra is offline   Reply With Quote
Old 05-19-2008, 07:03 PM   #89
Stang32v
__________________
1999 Mustang Cobra
537RWHP All Motor!
Nazty Performance
Old 05-19-2008, 08:10 PM   #90
Cobra925
Unreal.... .....I'm so jelous
__________________
01 Cobra- Silver
Old 05-23-2008, 04:36 PM   #91
Stang32v
Well,
28x10s MTs just arrived. Ill run these with the Nitrous. Based on calculations this will allow up-to 141MPH @ 7750RPMs where the limiter is at right now.
That will be easy 9s even with my lame super slow motion 1-2-3 shifts! LOL!
I'm also doing my home work right now for an automatic swap. I contacted several builders and Im leaning towards at Lentech "Strip Terminator" 4R70W.
I spoke to them for a good 20 minutes rewiewing some specs and data.
Here are some "generic" info on the ST.
Part# 7000-4R70-STR
Rated to 1500hp !
Overview: The Strip Terminator AODE/4R70W transmission is in a new class all by itself. A manual shift, fixed pressure valvebody is standard fare.Incorporated into this valvebody is Lentech's famous Reverse/Third technology for huge torque capacity. It is recommended for wild performance vehicles that see limited street usage. Each unit receives numerous key internal modifications and upgrades for increased durability.This transmission incorporates Lentech's exclusive Stage 2, 26 spline 3-4 clutch cylinder and larger 1 piece input shaft. The lockup feature is deleted from the torque convertor for reliability. It is highly recommended that higher than stock axle ratio be installed (3.55 or higher) in conjunction with this transmission model.
Auxiliary transmission oil coolers are also highly recommended.
Specifications:
.Quality selected core, completely stripped, all major components washed and inspected for excessive wear
.Pump modified to delete lockup, and increase lube and cooler flow
.Clutch cylinders modified for extra clutches
.Numerous modifications in strategic areas for efficient clutch operation and life
.8 "high energy" 3-4 clutches
.4 redlined intermediate clutches
.5 or 6 "high energy" forward clutches
.4 or 5 reverse clutches
.New 2" redlined O/D band
.All new seals, gaskets, and filter
.New bushings and thrustwasher (where needed)
.New intermediate ratchet diode clutch and spiral lock ring
.New low one-way clutch
.Lentech custom fixed-pressure manual shift Valve Body with exclusive LentechReverse/Third technology. Transbrake also available.
.Billet 1-piece input shaft and Stage 2, 26 spline 3-4 clutch cylinder ( a Lentech EXCLUSIVE!)
.New oil pan and bolts
.Re-assembled with all critical clearances adjusted for high performance/racing use
.Cast gray finish
.All complete units are dyno tested to insure a quality product
.Lifetime LTD warranty
It will have a full manual valve body, transbrake and a custome 9in converter.
If this goes well, and she runs as expected 9.5s should be easy within reach...may be a bit quicker! Hey, we will see.
Naz
__________________
1999 Mustang Cobra
537RWHP All Motor!
Nazty Performance
Old 05-23-2008, 08:33 PM   #92
Janstang
Janstang's Avatar
You'll like it..Guaranteed.
__________________
01 Mustang Cobra
Old 05-24-2008, 02:11 PM   #93
Stang32v
That's the plan!
This up-coming Friday will be out to run my bud's TT stroker LSX TA. He just ran 9.96@140MPH. He has been doing some smack talk so....it should be a great run! This will be with my car as is, but the only change being the 28 inch tire.
Naz
__________________
1999 Mustang Cobra
537RWHP All Motor!
Nazty Performance
Old 07-24-2008, 11:40 AM   #94
MYMONSTER
Well NAZ where are you at? 5.0 did the story on the Boss block build but said nothing of the heads, cams, intake. Was that your build? This jarhead in Oki is wanting to know the details of your engine build. Oh...I've been away from my Mach I for 26.5 months. Only 9.5 more months to go...
__________________
MY WORDS TO THE WIFE..."YA BABY, I'LL LEAVE THIS ONE STOCK...promise..."
03 Mach 1 12.987@107.18
had...01 GT 13.40@102.75 with 4.10's and Nitto D/R's
MYMONSTER is offline   Reply With Quote
Old 07-24-2008, 12:28 PM   #95
Janstang
Janstang's Avatar
That was his build.. I'll let him respond on the details. Where you at in Okinawa?
__________________
01 Mustang Cobra
Old 07-24-2008, 08:34 PM   #96
turbo88coupe
Nice steup man, exxpp for N/A
__________________
88 4cyl coupe, 8.8 31 sp axles, 3.55s, miny tubs, upr upper adj. lowers, 3 inch cowl, upr k member, a arms, coil overs, 90/10s, upr caster cambers--SOLD--
New build- 94 gt, billet 5.4 2v twin 70s 1000hp.
suspension on the way, block in the machine shop
turbo88coupe is offline   Reply With Quote
Old 07-25-2008, 07:44 AM   #97
MYMONSTER
Janstang
MCAS Futenma...
__________________
Old 07-25-2008, 09:21 PM   #98
Stang32v
What you want to know?
Heads? They are 03-Up castings, 9 threads, fully ported by me. Very, very strong low and mid range and carry to the upper lift. Over 30% lift gains as low as .100 lift!!! One of the reasons the explosive trottle response and sick top end!
They incorporated a Modular Performance -Proprietary- VJ and 1mm oversized valves.
Intake? Sullivan, upper and lower ported by me. Combined with a Wilson Manifolds 1.5 inch billet spacer, dual TB Accuafab and a custom JLT RAI w/12 inch filter.
Cams? Very nice sticks. Nice idle, enough lope to let you know you mean buisness, instant trottle response, insane mid range and top end. Ball park figures: .500/.475, ~236/~230, ~111LS, degreed to John's @ MP expertise and experience. They peaked at ~7200RPMs and carried the power band to 7750RPMs ONLY dropping by 3RWHP!!!!!!
Tune? Base tune by Don@LaSota Racing, finalized by me. 12.8 Commanded and on the WB, up-to 27 deg timing. Picked up 15+RWHP going from 12.6 to a 12.8 AFR. Picked up another 10 RWHP @ peak with changes on timing, by playing with peak TQ timing, and moving from 25 to ~27 deg. More than that, there was no noticeable gains. 93 pump gas.
Hands down, sick little NA set up that loved the Juice! Made over 700RWHP on Nitrous!
Naz
__________________
1999 Mustang Cobra
537RWHP All Motor!
Nazty Performance
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2010 Corral.net
