Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > General Mustang Tech
Old 10-31-2009, 02:21 PM   #1
riocobra
fox 8.8 in a 1999 and up anyone?
Has anyone done this before Im thinking about doing it to my 2000 gt to put sume 15/10 with 4.5 back spacing they dont hang out much now but I figure with a fox 8.8 it should suck them in. Anyone ever done this post pics please!
riocobra is offline   Reply With Quote
Old 10-31-2009, 02:44 PM   #2
mpe331lx
mpe331lx's Avatar
The lower control arm mount on the 86-98 rear is 12mm where the 99-04 is 14mm. You will have to either drill it out to fit the 14mm bolt or run a hybrid LCA with a 14mm front bushing to fit the body and a 12mm rear bushing to fit the rear.
FYI, the 86-93 and 94-98 housings are the same. The 94-98s axle flange to axle flange measurement bieng wider is due to slightly longer axles to fit the disk brakes.
Just make sure to order the correct axles for your brake set up.
I have a fox housing with all the sn95 brakes and sn95 moser axles in my 96.
Ive been thinking about doing a 94-98 8.8 in my 03 to do the same thing you are.
DSG 03 Cobra
DSG 97 Camaro
96 Cobra: Stock Longblock 4.6 4V, KB2.8H, T56, 9.93 @ 142
mpe331lx is offline   Reply With Quote
Old 10-31-2009, 03:05 PM   #3
riocobra
so I need a 94 through 98? and the wheels will fit?
Old 10-31-2009, 03:10 PM   #4
ManicMike
ManicMike's Avatar
I put a '90 8.8 rear in my old '00 V6. I drilled the mount out.
17x10.5 wheels in the rear with 315 sized Nitto DR's.
'88 LX -Basic H/C/I setup, custom single 70mm turbo, 3550 trans w/ spec stage 4 clutch. Run's alright.
ManicMike is offline   Reply With Quote
Old 10-31-2009, 03:13 PM   #5
riocobra
What brakes do you have on the rears drums?
Old 10-31-2009, 03:14 PM   #6
mpe331lx
mpe331lx's Avatar
You can use the 86-93 but they have drums. If you want disks, you will have to swap disks onto it. I's much easier to use a 94-98.
The wheels will definately fit better. Just not sure if the 4.5" B.S wheel will pull all the way in.
DSG 03 Cobra
DSG 97 Camaro
Old 10-31-2009, 03:17 PM   #7
riocobra
Well I was told if when you put an 8.8 thats drum and put disk on it it makes it wider. Im needin all the room I can get. If I do ues a rear with drums will if work just losing some stoping capabilities.
Old 10-31-2009, 03:29 PM   #8
ManicMike
ManicMike's Avatar
It was rear disk, I swapped everything over from the old 7.5 rear end.
Old 10-31-2009, 03:35 PM   #9
riocobra
Hey new question didnt even think about a 7.5 whats the length difference in them???
Old 10-31-2009, 03:39 PM   #10
ManicMike
ManicMike's Avatar
They are the same lenths as 8.8's, just much weaker.
Old 10-31-2009, 03:45 PM   #11
riocobra
Hmm wonder if someone has done it with drums? my buddy has a rear I can swap but Idk yet I if itl give me the clearence I need my wheels are 15/10s with 4.5 backspacing. what was the back spacing on you cobra rs?
Old 10-31-2009, 09:07 PM   #12
Mustang5L5
Mustang5L5's Avatar
There are ways to retain your disk brakes but not push the wheels out. Fox guys do it all the time.
http://northracecars.com/Brakes.html
Basically you need a set of those brackets for a GT, and a set of 5-lug fox-lenght axles. Then you simply bolt on your stock brake components and you now have rear disk, but keep the same axle width as if you had the drums.
Downside is you will lost your ABS since you can't mount the exciter rings...but you would have lost that with the drums anyway.
Mike
--1988 Mustang LX 5.0--
--2006 Infiniti G35x--
Mustang5L5 is offline   Reply With Quote
Old 11-01-2009, 09:50 AM   #13
riocobra
TTT getting alot of info guys thanks! some more pics would be great!
Old 11-03-2009, 11:19 AM   #14
riocobra
TTT anyone else out there done this
Old 11-03-2009, 05:44 PM   #15
Floordford
Formerly Fastangboi
Floordford's Avatar
I know for a fact that the 94-98 rears are 3/4" shorter on each side. I had to run one in my 2000 as a bandaid and i hated the fact that my 10.5" rims tucked back in to almost the stock location.
My advise would be to take measurements.
2000 GT-bolt ons and suspension. 273hp/ 309ft.lbs.
Originally Posted by tiresmokindad View Post
Crush sleeve is effective than axle. It is easier to replace pinion seal. I think because axle is not much popular than crush sleeve.
Floordford is offline   Reply With Quote
Old 11-04-2009, 11:24 AM   #16
riocobra
Got any pics of your car with that rear in it
Old 11-05-2009, 09:43 PM   #17
Richard Oben
Richard Oben's Avatar
FX track is 59.5, SN95 94 to 98 is 61 and New Edge 99 to 04 is 62 1/8 (pretty sure about the numbers but not positive), so it is more like a half inch than 3/4 but on the car that would make a noticable difference. Just trying to get the right info out there. 5L5 thanks for the link, cheers Richard. www.northracecars.com
North Racecars owner
Brake bracket specialist
corral.net advertiser
Richard Oben is offline   Reply With Quote
Old 11-06-2009, 11:58 PM   #18
riocobra
so there is a 2 inch difference between a fox and a 99 and up rear end
Old 11-07-2009, 12:17 PM   #19
Mesarina
it was longer to fit the abs rings, not disc...
Mesarina is offline   Reply With Quote
Old 11-07-2009, 03:41 PM   #20
riocobra
But I mean to run drum brakes for awhile is there a 2 in difference in them Im gonna be putting a 9 in in the car later on
