Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > The Body Shop
Old 10-24-2009, 12:19 AM   #1
Colascstang
Question Painting an Explorer Intake
What is the best way to paint an explorer intake so it will last? And no I do not have the cash for powdercoating or I would do so believe me!
1987 5.0 GT stock 212xxx miles on the car, less than 100,000 on the engine.
Colascstang is offline   Reply With Quote
Old 10-24-2009, 10:09 AM   #2
vinnietbird
vinnietbird's Avatar
Trader Feedback: (40)
It's all in the prep work.Smooth it down and get rid of the molding lines and texture.I used 120 grit 5 inch discs on my drill and used a continuous movement,never holding the disc in one place too long,until the whole thing was smooth.Granted,I polished mine,but you still want a smooth surface to paint.After that,I'd use a good self etching primer and then whatever color you plan on using.
'88 Tbird..GT40-P,T-5,Explorer intake,TFS-1 cam and springs,Ported heads,FMS 1.6 roller rockers,MAC CAI,3G,Mass Air upgrade,65mm t-body,FMS 140 mph speedo,8.8 with 3.55's,BBK shorties,A/C & smog delete,mini starter,Pypes O/R X-Pipe and Flows,17x9-17x10 Cobra wheels,electric fan,CHE control arms
vinnietbird is offline   Reply With Quote
Old 10-24-2009, 01:52 PM   #3
bigpitbull2
bigpitbull2's Avatar
Check out my build thread... I have several pics of the process as well as the materials I used..
http://forums.corral.net/forums/show....php?t=1124908
bigpitbull2 is offline   Reply With Quote
Old 10-24-2009, 08:43 PM   #4
sd_fox_racer
sd_fox_racer's Avatar
here ya go
http://forums.corral.net/forums/show....php?t=1145741
hooker headers, MSD 6AL, O/R X-Pipe, aftermarket locker, 4.10 gears, rest is stock =(
sd_fox_racer is offline   Reply With Quote
Old 10-26-2009, 12:56 AM   #5
86GT2go
Epoxy.
"Speed doesn't kill people, stupid people who can't handle speed kill people."
86GT2go is offline   Reply With Quote
Old 10-28-2009, 10:51 AM   #6
Colascstang
When you guys sanded your intakes what process did you use? What I mean is did you go from 120 grit to x grit to x grit, ect. I have used 120 grit to smooth it down and get all the rough stuff off I just need to polish it up some, enough so I can paint it and it look smooth and show no sanding marks.
Thanks!
Old 10-29-2009, 04:22 AM   #7
sd_fox_racer
i didnt use sand paper because it would remove the pitting from the sand casting which is something i like, im not into that smooth finish too much....so i just used some degreser and a scotch brite green pad to scuff it up
Old 11-03-2009, 03:58 PM   #8
Colascstang
Question
I've taken off 99% of the rough casting on it I just need to sand in the cracks and such. Question how smooth do I need to get it to primer and paint it? Does have some sanding marks but that is because I used 120 grit to sand so far.
Old 11-03-2009, 09:42 PM   #9
mstngman28@yahoo.com
mstngman28@yahoo.com's Avatar
Before
After (crappy cell phone pic)
Just painted the intake tonight...washed it off with hot water and dish soap and then lightly sanded it and wiped it down after sanding and then painted it
mstngman28@yahoo.com is offline   Reply With Quote
Old 11-04-2009, 10:42 PM   #10
Colascstang
I'm starting to wish I had done what most have done and just cleaned it and painted it.
Old 11-05-2009, 06:53 PM   #11
LoL That is what I do with most of the stuff that I have to repaint...although I usually buy good looking used parts anyways and all I have to do it paint them and not put a bunch of work into them
Old 11-06-2009, 12:02 AM   #12
mustangboy
Powdercoating is not that expensive
1993 Notch 347 402hp/383tq all motor
mustangboy is offline   Reply With Quote
Old 11-06-2009, 12:14 PM   #13
Colascstang
Well I think I am stuck now as I have already sanded 99% of the upper. Just need to smooth out the sanding marks and a few nooks. If I had known it would be this much work Id have cleaned her up and painted it as is.
