#1 |
Mystery sunroof
I am thinking of picking up an 89 daily driver. Car is apparently in decent shape; all original except it does have some aftermarket sun roof installed...probably when it was new. I was curious what those have done when needing parts or when running into problems? I assume if I need a seal or 'hinge' or something of the sort I am going to be welding in a factory roof or something crazy, right?
#2 |
Or replacing the whole sunroof with a new unit. That would be a lot easier than the whole roof.
93 Reef Blue Notch - Stock Bottom End,Thumper Heads,Cobra Intake,Crane 2031, Crane 1.7's,Zex Dry w/Window Switch, BBK Shorties, Flows, & X-Pipe,BBK CAI,FMS 65mm TB,73mm C&L,30# inj.,Livewires,Module,Coil,Pullies,190lph Pump,3.55 Gears,Pro-5.0 Shifter,King Cobra Clutch,Adj. Clutch Cable,Quad & Adj. |
#3 |
I know...meant that as a joke but I totally hope it does not come to me having to replace the sunroof either. However, that would be a way cool T-top install opportunity!
I need to check the other guys thread now! Talk about work... |
#4 |
if it is an '89 almond hatch, i believe the sunroof is factory. mine has one too.
Black & Tan aka Scream Puff hawaiiperformancemustangs.com/forum/index.php?topic=10231.0] hawaiiperformancemustangs.com |
