#5041 |
Awesome fox, but honestly I would lose those louvers and same size white letter tires, with a quickness. Of course, just my opinion. Clean car
'86 Mustang GT 306 SOLD '85 Mustang LX 5.0 5-speed hatch SOLD '89 LX Coupe 11:1 306, 4:30s, 3" exhaust. A radio, clock, speedometer, parking brake, air conditioning, power steering, back seat - a gearhead needs not these things |
#5044 | |
306, 10.4:1 KB 116, arp rod and main studs, comp X4270h cam, gt40 heads, Weiand stealth, 600cfm vac sec carb, 1/2" spacer, 3.73s, lakewood lowers, boxed uppers, poly bushings, t5, pro 5.0, LT's, thunderbolt spun metallic cats, super 44's w/ tails...in a 2950 lb 93 coupe on centerline billet stars |
#5046 |
I love the 351. It is just a mild build but it has tons of tourqe. But I do wish that I could get the hood to clear.. I still drive it about every day if I can and was going to buy a cowl hood, but I kind of like the way the hood looks with the hole in it, so I have just left well enough alone.
92 Notch, 351 Windsor, Trick Flow intake and cam, ported heads, 5 speed, AEM wide band, PMS 99 Cobra vert. stock 89 hatchback stock 14.1@96mph SOLD 92 Notch gt-40 intake SOLD Last edited by 92LX-5.8; 11-05-2009 at 11:20 AM. |
#5047 | |
89 GT vert, Saleen wing, 2.5"cowl MachI hood, 3.55, Spec clutch, jet-coated shorties, flowmasters, off-road pipe, MSD billet dist, BBK 1.5" springs, light bar, GW sub-frame cons and jacking rails, MM strut brace, Black Magic Fan, FRPP Aluminum Radiator, Polished PBR front calipers, rear Cobra discs, 31 splines, Auburn Locker, 18" Roush wheels, FMS alumimum driveshaft, 160amp chrome 3G, Maximum Motorsport CC Plates. 331,AFR 185s,Cobra Intake,24lb injs,hidden wires. Blower coming soon! 66 GT Coupe, Candy Apple Red, Rmodel apron, chrome ponies, 302, 4spd, disc brakes, full-on custom showcar! IF IT'S UPSIDE DOWN AND BURNING...YOU'VE GONE TOO FAST |
#5049 |
[QUOTE=92cleancoupe;9320165]Not sure if I posted in here before....Somewhat rare set of polished Roush 18s.
QUOTE] Very nice! I always wanted a set of those Roush wheels for my fox, but as you mentioned they are rare. I never found a set for sale and of course they're no longer made.
89 Blk Hatch Novi, Max Motorsports, T56, Baer + Incon800TT in the works. 07 Elec Silver Volvo S60R 6MT 300HP AWD DD SOLD: 91 Twilight Blue LX Hatchback. S-trim B-50 342. Featured in 5.0 Mustangs and Super Fords Aug '04 - Appropriately titled Murphys Law |
#5051 |
What suspension and spindles/rear axles do you have?
#5054 |
Trader Feedback: (35)
Hey guys,
The Roush wheels on the car are 18x9s all around, same offset front and back. The car has SN95 spindles, then stock fox length axles with north race car brackets to run the cobra brakes. The red is Mercedes "mars red". The paint is literally the only thing I didn't do on the car myself, I'll leave that to someone with the proper equipment! Yes it has a custom roll bar that I made for it, but I don't want to ruin the wheel thread with a bunch of pics of non wheels. Here is a link to the complete build of the car with some videos etc. Scroll down to the bottom for finished engine bay pics with interior pics etc. http://forums.corral.net/forums/show....php?t=1153618 |
#5055 |
New 5-lug Cobra disc conversion with Cobra wheels (17x9):
1992 GT Vert: C&L/FMS TB, Cobra Intake, BBK headers and 2.5" exhaust, MM CC plates, MM R&T/Bilsteins, FRPP FCA & UCA, MM LCA, FMS d/s, 3:73's, B&M Shifter, MM XL SFC, STB & 4-pt brace, 03 Cobra deep dish 2004 Lincoln LS V8 Sport 2006 Volvo S60R AWD Turbo |
#5057 |
A little nicer than the last picture.
"The trouble with our liberal friends is not they are ignorant. It's just that they know so much that isn't so." - Ronald Reagan Last edited by josh_michels; 11-12-2009 at 04:20 PM. |
#5058 |
'92 w/17*9 M179 clones front and rear (36mm offset, 6.42" backspacing).
Front: SN95 control arms, 94-95 spindles, 98 cobra brakes, Koni Yellow (SA) struts, Griggs' Koni coilover conversion kit, 300# coilover springs, SN95 sway bar, MM bumpsteer kit, stock k-member, ~0* of camber, 275/40-17 Azenis. Rear: SN95 ABS axles, 98 Cobra brakes, Griggs adjustable PHB, Global West trak-link torque arm, no quad shocks, no UCAs, stock lower control arms, H&R 350-390 conventional springs, Koni Red (SA) shocks, 275/40-17 Hancook R compounds. ![]() ![]() Once I toss some negative camber onto the front, I'll take some more pictures and post them. The wheels stick out more in the front than I had anticipated and it looks like I easily have room to run 17*10.5s in the rear. Last edited by aurdraco; 11-14-2009 at 06:53 PM. |
#5060 |
01-04 wheel color?
http://farm3.static.flickr.com/2727/...ef5cf146d9.jpg does any one know the factory name for this color?
thanks |
#5062 | |
#5063 |
Argent would be the color the Ponies are, those are darker then that.
~Jeff 1986 Mercury Capri 5.0 T-Top 5spd 1988 Ford Mustang GT http://www.cardomain.com/id/98cowlinduct |
#5065 | |
'86 GT T-Top - 351W, Vic Jr heads, Holley Commander 950, Custom box intake, Pro Products EFI lower, 30#ers, 255lph and Aeromotive Regulator. In pieces. '88 GT Vert - Stock with 17" '03 Cobra replicas. |
#5068 |
What is that lowered with? Looks awesome!
93 Cobra Clone...Unequal Length Shorties, Dr. Gas X-pipe, E-cam, Aluminum D/S, MGW w/ blue handle, 70mm TB, K&N, Tremec SD T-5 |
"Happiness is being stroked and blown at the same time"
