Go Back   Corral.net : Ford Mustang Forums > General Tech Forums > General Mustang Tech
Old 11-03-2009, 09:25 PM   #1
tconkling
welding undercarriage with carpet in?
I have some subframe connectors that are close enough to the floor pan where I could weld them on there for most of the length and in the larger gaps I'm wanting to make some plates to fill the negative space and weld them all to the floor pan. I am hoping against hope that I could get away with doing the welding with the interior in? I am assuming the metal isn't thick enough were I wouldn't just fry the carpet but I figured I would ask
tconkling is offline   Reply With Quote
Old 11-03-2009, 09:38 PM   #2
2ksteeda
2ksteeda's Avatar
It will definitely burn the carpet.
2ksteeda is offline   Reply With Quote
Old 11-04-2009, 12:37 AM   #3
carrew
carrew's Avatar
Dude its tin metal thickness, I would pull the carpet where ever your welding.
carrew is offline   Reply With Quote
Old 11-04-2009, 12:41 AM   #4
toyman
toyman's Avatar
I don't think there's any benefit to welding the SFC's to the floorpan. Just weld along the full contact length of the subframe's on both sides.
Richard
KB 2.1L, FRPP M5400-A Suspension System, FRPP Aluminum D/S, Shift Kit, High Stall TC, FRPP 3.73 Gears, Balanced Roller Cammed Engine, Edelbrock Performer Heads, Comp 270HR cam, AEM EMS, 3.5 Bar MAP, Zeitronix ZT-2 WB, FRPP 70mm TB, modified UPR CAI, Be Cool Aluminum Rad
toyman is offline   Reply With Quote
Old 11-04-2009, 02:15 AM   #5
tconkling
yeah, I did assume it would roast the carpet, just hoping that i was wrong
As far as it helping I would like to tie all the structures together as much as possible. I can't see it hurting rigidity and filling in the gaps would definitely increase the stiffness in bending as there is more then a linear increase of strength in bending with increased 'height' i.e. a 1x2 vs a 2x2 will have about 4x the strength in bending.
plus its fun playing with my welder lol.
Old 11-04-2009, 09:54 AM   #6
MFE
Super Moderator
MFE's Avatar
Then you'll have plenty of fun reparing all the holes you create
MFE is offline   Reply With Quote
Old 11-04-2009, 11:12 AM   #7
carrew
carrew's Avatar
Actually the old mm SFC's had little pieces that filled gaps between the torque boxes, but the new ones don't seemed to have them. Must of been a cost thing.
Old 11-04-2009, 01:07 PM   #8
DAVE94LIGHTNING
DAVE94LIGHTNING's Avatar
The floor pan is so thin that even with the lowest settings on the welder it burned holes in the floor pan. I finally managed to strengthen the seat mounting area by welding it to the floorpan from the inside of the car with the carpet removed.
1994 Ford Lightning. (357 Vortech YS)
1988 white 5.0 Coupe (100% original)
1991 white 5.0 Coupe (98% original)
DAVE94LIGHTNING is offline   Reply With Quote
