#1 |
10 second streetable combos
Curious about what setups you guys have running in the 10s and still streetable. I'm trying to find the cheapest street friendly way to do it(yes I know the 2 probably dont go together).
92 AOD GT Lentech/HCI 2009 G8 GT CAI/Tune |
Support corral.net, please click our advertisers!
#2 | |
Trader Feedback: (63)
Nope its hard to have GOOD and CHEAP together lol
Looking for performance Parts?Check out my for sale thread. http://forums.corral.net/forums/showthread.php?t=1138608 Quote:
#4 |
They go together very easily (10's and streetable not the cheap part, forget that now) with a power adder such as nitrous. A 331 n/a combo that can break off 10.90's takes more effort/money and depending on your defenition of streetable may be hard to do. But a stout aftermarket block with a good n/a combo and a cam that can take advantage of a 150-200 shot when your at the track could be very streetable once again depending on your idea of "streetable". My car will run mid elevens n/a and I feel it is very streetable but some might not agree. With a decent shot of spray I could be deep in the 10's. Tens and cheap dont go together very well, anyone can make a 10 second car that will last a couple passes but if you want dependability and 10's now your talking about more money, more time and more testing. Let everyone know your idea of streetable and if you want to stay n/a or go power adder and if so which power adder you prefer. Do you want to stay efi or alright with carb? You gonna race on street tires or dot slicks or full slicks? Etc, etc.
Gem City Stangs 93GT 347 AFR185's improved springs, FTI cam 10.5:1 , 1.6 CompPro Magnums, "R" intake,30lb. injectors, 75mm TB, 80mm Pro-M, 4" Powerpipe,1 3/4 LT's, T-5 Centerforce Dual Friction,3.73 gears, Kenny Brown Subs, UPR Moly k-member, a-arms, coil overs, Strange 10ways,Tri-Ax, Pro-Chamber and Pro Dumps, Mega bite jr's, UPR uppers, Torque box supports. |
#5 |
heres a cheap and very streetable pump gas low 10 second combo that i use to run.all motor no power adders.
CHP 347 shortblock flattops AFR 205's 58cc with titanium retianers and Kmotion K950 springs Super Victor intake probe 1.7 shaft mount rockers Pro systems carb 860cfm Camshaft Innovations solid roller cam tko 600 box stock Spec stage 3+ clutch 5.13 gears 28in tires car wieghed #2880 with driver i shifted it at 7600-7700 rpm. that was a stock E7 block. i adjusted the valves twice a year, drove it about 150 miles every week for 3 years that way before i sold it. it ran 1.38 60ft. 10.27 @ 133mph every rip. that car could've been a bracket racer.
There 3 types of work I offer! if you want it cheap and fast it won't be good. If you want it cheap and good ,it won't be fast If you want it good and fast ,it won't be cheap |
#6 |
370-410 cid 351W stroker, 11:1, AFR 185's, victor jr intake and 750-850 double pumper, 1 3/4 headers to a 3" dual system, a Comp Magnum 280H (hyd flat tappet).
Peak horsepower around 5000-5500 rpm, launches like gangbusters, and pulls from 2500 rpm onward, powerbrakes, low rpm idle, shift around 5500-6000. One example went 10.50's (3200 lbs), with an auto (no trans brake), and slicks. pulled 60 ft times in mid-upper 1.40's (No trans brake!). switched to a solid flat tappet (the only change) and got 10.30's out of it. Last edited by buddy rawls; 08-11-2009 at 06:33 PM. |
#7 |
306 stock crank/rods, old forged TRW pistons, TFS TW heads, TFS 1 cam, Holley Systemax II, 70mm Tbody, 42# inj, Vortech S-Trim, ASP 8" crank pulley, Vortech 3.33 blower pulley, Power Pipe, MSD 6AL, 1 5/8 Hooker shortys, 3.55 gears and a T5.
Shift at 5800 and it's mid 10s all day long in hot thin air.
The real reason that we can't have the Ten Commandments posted in a courthouse is this: You cannot post 'Thou Shalt Not Steal,' 'Thou Shalt Not Commit Adultery,' and 'Thou Shall Not Lie' in a building full of lawyers, judges and politicians...It creates a hostile work environment. |
#8 |
n/a 331 9.8comp 415rwhp@7200
ported performer rpm 289cfm@600 ported vic jr intake speed demon dg 750 .640 .648 248-256 dur 110 13/4 long tube tko600 by promotion 4.10 3000lbs w driver 10.8@127.8 n/a 225shot 9.57@145 same combo afr185 comp and 11.5comp steel flywheel instead of aluminium 3.73 gear 26x10 10.8@129 not mutch gain n/a but on a 250shot whent 9.43@147 1.39 60ft Last edited by lov2xlr8; 08-11-2009 at 07:37 PM. |
#9 |
Trader Feedback: (115)
408-427W with good heads, intake and camshaft or small cubic inch 302 based setup with a turbo on it.
![]() AUTHORIZED DEALER FOR: QUICKTIME - TREMEC - PRO 5.0 - SPEC - UPR - ASTRO PERFORMANCE |
#10 | |
#11 | |
#13 |
Junkyard shortblock with new rings and bearings, S trim with powerpipe,
out of the box edelbrock performer rpm heads, 1.6 rockers, crower 15512 cam, ported cobra intake and BBK equal length shorties 10.9 @ 130.5 with 1.86 60ft on drag radials. Car weighed 3250 lb with me in it, very streetable and drove like a stocker.
87 LX Vortech S Trim 558 RWHP 542RWT 10.9 @130.5 1.86 60 ft on Drag Radials,sold. 1995 Cobra Vert, Trick Flow stage 1 cam, Edelbrock performer intake, S-Trim 8 lbs 12.3 @ 118 2.0 60 ft.3850 lbs. New Combo:347 S-Trim with Patriot 185cc heads,TFS stage 1 cam,TFS track heat intake. 11.92 @ 127.32 |
#14 |
Freind of mine had a 10:5 to 1 347 afr185's,xhr282r,systemax,5sp,3250 weight would go 10.5's on a 150 shot plate system in colorado!!! all day!!!
would run 12.2's on the motor
04 Terminator Silver Chrome FR500's 93 COBRA Teal 90 NOTCH 302 w/Turbo 60-1,AOD *SOLD* |
#15 |
i went 10.80's all day taking it on road trips and driving to and from the track
3200lbs without me s-trim 12lbs aod 2200 stall 373 8:1 short, tf heads tf intake b41 cam exhuast, ignition, etc etc etc
98gt vert sold - PI conversion, low 12's on a 100 shot 93notch sold - 9 second supercharged street-killa ![]() 95gt - current project streetcar ![]() http://wayne-martin.mybrute.com |
#16 |
i'm another guy that is a nitrous kit away from a streetable 10 sec combo, i'm running a pretty mild 347.
1988 lx coupe R.I.P. 1986 lx coupe best pass 11.46 @ 116.01 1.60 60 ft. |
#17 |
get a 306 with some good pistons (no trws) and good bolts throught it, procomp aluminum heads, vic jr intake, good carb, around a .600 lift hyd roller, c4 w/ t-brake and about a 250 shot and it should be in the 10s
'02 GT:a few mods! '89 coupe all upr sus., cage, fuel cell, rear firewall, telstars |
#18 |
Nothing wrong with old TRWs especially with a power adder, The block is the weak link and Pro Comp heads are junk.
#20 |
I hoping to get there also . I'm having a dart 363 built by ford stroker with a jay allen cam and som TW cnc 205's . I doing this with EFI also , Some one PAY PAL me some spare change
#21 |
Ran this tonight, drove a hour there, ran 10.60's on pump gas, 3.55 gears, AOD, hyd roller, and drove home.
http://videos.streetfire.net/video/d...ome_701153.htm
Just a #$%^ talker, I know nothing.
