#1 |
How fast before Automatic???
I am running a 347 NA making about 455 HP. Feel like the T-5 is holding me back.
Best run to date is an 11.78 @ 116.89mph with a 1.68 short time. Still have stock axles, so I'm taking it easy on the launch. The tranny has all the World class upgrades, but it doesn't feel very good. How fast did you guys run your t-5's?? I street drive the car, but I suppose I can always step up to the c-4. I also have a Hitman Plus plate kit, but I highly doubt the tranny will hold up to it. Thanks!!!
1992 Mustang Coupe Wild Strawberry 11.66 @ 119.55 10/3/09 new best 10.94 @124.98MPH on 100 shot 2001 Ford F150 Silver Supercrew 4X4 on 33's 1996 Honda 900RR Red |
#2 |
Moderator
Your definatly leaving alot of ET and MPH on the table. My 347 in my sig made 420rwhp/400rwtq threw a tremec 3550. It went a best of a 10,84 at 124 n/a with a 1.48 60'. I went many 10.30's @132 on a 150 shot with it before I hurt it missing a shift. I now run a C4 setup.
Get a good 5sp (tremec 3550/tko/500/600) and some good axles....then let it eat.
Outlaw Street Madness 6.50 index Dedpedal Race Team;Tuned by Lasota Racing R302 347, forged eagle crank and rods, ross pistons (10.8:1), Comp Cam custom solid roller (.616/.622,248/260,113 lobe sep), RHS 215 heads, 1.6 rockers, Neil Erickson ported TFS-R box intake, Hooker S/C 1 3/4" LT, 3" X-pipe & dumps, 42lb inj, 90mm TB, 90mm lmaf, NX efi plate kit, Built C4 w/ brake, ~4500 n/a stall, now running on E85 w/ C4 N/A:10.88 at 125 with a 1.56 60' 150 shot:9.75 at 134.9 w/ 1.30 60' (6.16 at 110.4 in the 1/8) |
#3 |
http://www.youtube.com/watch?v=-Pz3Jimnlwk
this is my stock t5..my 3rd gear is rather weak, so I take it easy on that gear. You want to be consistent like a bracket car, go auto. Bang some gears at the track, or around town driving, go with the 5 speed. I just like rowing the gears and having fun. Its all up to you. Do you feel like rowing through the gears?
1989 coupe, 302, stock T5, aftermarket heads, carb and intake, lightened chasis: 2680 w/ driver and w/ a good suspension. 11.24 @ 122.37 1.53 60' |
#4 | |
298ci ModMax Stroker, HP Cams, ProCharger D1SC w/ 3.2 Pulley, 10% od IW Damper, 60# Injectors, Complete Aeromotive Return Style Fuel System, Ported Plenum, Aluminum Driveshaft, 3.73 Rear and more!~~~ HP & Boost Numbers Coming Soon!! |
#5 |
This guy called Shaun runs a stick shift back here in the UK...best run a 10.8
check it out http://www.youtube.com/watch?v=x4PE-83Vrik
Black 94 gt auto-Edelbrock 60379 heads,Ported Cobra intake,70mm TB,190 Fuel pump,BBK adj FPR & gauge,24lb injectors,BBK Shorties,offroad X,Summit underdrive pulleys,smog pump deleted(short belt),BBK CAI,MSD Blaster,Cobra front brakes,S197 rims & spacers Coming soon-3.73's, |
#6 |
Thanks a lot!.... 5500 rpm.
#7 |
I went 11.25 at 123.6 with a stock T5, 1.58 60 feet. Swap it for a G-force T5 last winter...
http://s43.photobucket.com/albums/e3...nt=nbt2008.flv
1993 black coupe : Stock shortblock, F cam, TW, GT-40 intake, 30 lbs inj, PMAS 95mm velocity maf, 70mm tb, Paxton novi 1220SL, UPR boost pipe, G-force T5, 31 splines cobra diff. 10.91@ 126 mph, 1.49 60 feet, 3200 lbs |
#10 |
Street car keep a 5spd more drag go with the auto.
A friends Strim 306 he only ran 12's with the 5spd, swapped in the C4 and went 10's
want it done right is that to much to ask??!! |
#11 | |
#12 |
My goal is to get bored running 10's with a 5 speed before i decide to switch to an auto. My combo screams auto.
Stock block, GT40 heads, Explorer intake, Precision 67mm Turbo, T5 10lbs, 431HP 497TQ on 110 octane 12.01 @ 122
#13 |
I have been 9's N/A on a TKO600, and 10.2's N/A on a stock T-5 for many years.
Dave Zimmerman @ Team-Z Suspension Cary Chounard @ Performance Inductions Jim Woods @ Fordstrokers |
#14 |
wow...2 seconds off the 1/4 time by a tranny swap is insane! But im sure someone somewhere has done it. I'm a little confused myself.. lol
#15 |
Trader Feedback: (33)
2 second difference is because the driver was horrible.
Those arent real world before and after #'s Some drivers with sticks can run almost as fast as autos but some people just dont have the knack for shifting so they go the easy route and put an auto in
1992 GT Stock shortblock, TW Heads, Trick Flow Stage 1 Cam, Holley Systemax Intake, BG Turbo Kit, 42lb injectors, PA Supercomp AODE, 31 Spline Cobra Diff w/ strange axles and 9" style housing ends, 5 Lug Conversion etc 10.46@132.58 |
#16 |
LOL, I am a horrible driver too... with a manual. I guess if I put a c4 in my car, I will run 10.00's??
#17 |
I would say for me and you, maybe half of a second faster, if we bang the gears like no tomorrow with the manual...
#18 | |
#19 |
I totally agree with some of the posts above, if you're picking up over .2 just from stick to auto, you're a bad driver. Both of my cars are stickshifts...a 9.40 race car and a 10.90 street car. I can run within .02-.04 every pass on the same day. The autos being consistent doesnt have anything to do with it..I have seen some auto's that wasnt consistent... The Consistency is in the DRIVER!!
SS/D 427 Ford Fairlane NHRA-IHRA (Ex- Van Cleve) 9.47@141mph 1985 mustang FFW-NMRA True Street N/A 331 10.88 at 125mph |
#20 |
I totally agree!!! I ran the nmca/nsca efi elliminator for years with a stick finished 3rd in points in 2003 with a stick. Won several local bracket races with a stick to help pay for the national stuff the DRIVER is a HUGE varable when it comes to a stick car!! And the proper clutch set up helps too, the strongest isnt always the fastest!
pro comp headed 347 pump gas LS1 killer ![]() ![]()
#21 |
Right!!!! If you cant drive a stick, You CANT DRIVE!!!!! Im sure some idiot will argue this...BUTTT, if ur not quick enough to shift it, then u aint quick enough to steer it!!! And sure you can drive "normal", like every other idiot on the road, but you cant drive it like some "us" can...And to "US" that isn't DRIVIN'!
'90 Mustang GT- Stock longblock...Explorer intake 75mm t/b, pulleys, BBK = lengths, o/r-H, Flowmaster 40 series w/ turndowns, 3.73, Steeda Tri-Ax. soon to be installed, GT-40 irons-ported, 1.7's, 90mm LMAF, 24lb inj, TwEECer, suspension. |
#22 |
this is the coupe/vid that puts end to all the "manual vs auto conversations"
http://videos.streetfire.net/video/A...-vid_43327.htm
93 GT "Negrito" 359w TW VicJr 5spd, 3.73s MSD ign 99 Cobra "Slowbra" JLT, LTs X Stingers, soild 4.56, 87 Coupe "LeftOvers" Following the Nohrspwr path, GT40ed high-mid-low 11s car |
#23 |
Not everyone can drive like that.. lol It is possible to go fast with a 5 speed, but U better be ready to bang some gears.
#25 |
Trader Feedback: (32)
Isn't wonderbreads car proshifted? Kinda kills the streetable 5-speed theory.
Here an in car vid of me with my 5 speed. No dog rings, proshifted, heli cut gears here. Just fast foot/hand work. Don't mind the super slow 2-3 cause it was a new tranny and I had surgery on my elbow 2 days later. I can pull on the stick but it hurts like hell anytime I had to push it. But I normally shift the 2-3 just as fast. At the end of the run I was able to get a decent 2-3 in.
98 red cobra (N/A Stock longblock) 11.79@114.64 (1.62 60ft )
#26 |
X2 May not have been 2 full sec difference but even to go from 12.10 to 10.90 is still a stretch.
88 coupe, 351 cleveland, unported 4V heads, buddy rawls custom solid roller, diamond domes, 6'' h-beam rods, stock 4bolt block/crank, holley strip dominator, 950HP holley, hoosier 28x10, 90/10s, UPR pro rear kit nonstroked, stock iron heads and NO NITROUS!!!!!!!! 10.08@134.83 / 6.44@108.21 (1/8th) |
#28 |
Looks like you changed from a T5 to a c4? Correct?
#29 | |
Sorry, just thought that was cool......
1983 GT T-Tops (H.C.I.) Vibrant Red 93 Cobra #615-SOLD 1966 Mustang Coupe
#30 |
Ya just switched this spring went out on opening day got 2 passes on the new Ram clutch not the cheap one either, and on the thrid pass the clutch blew apart did the conversion went back out and the car picked up .02 tenths and 1 mph going from a stick to a C-4
![]() Thansk Matt
