#316 | |
Trader Feedback: (34)
8-8-08 1.73- '60 7.92- ET 86.07- MPH
'89 GT: STOCK shortblock 5spd./TW/SYSTEMAX/N4=6.80@100.42 Rodney Tolleson #008 ALL MOTOR ALL THE TIME
#317 | |
Guess I'll update mine too. On my first full pass at pinks in Gainesville, I decide to set it on kill (jetted it up from a 150 to a 250 ), and try to put it in the 9's. Well, it rolled out, put up a 1.40-60', but I broke the trans when I shifted into third. Still went 6.26 in the 1/8th, even though it was only running 96mph. So, its in peices at the moment, trans is out, about to be sent off and rebuilt, motors out getting a freshening, and another kit, And it will have a 'moly 10pt cage in it before it hits the track again.
1993 Coupe Street car with full interior and no cage has run a 1.40-60' with a best 1/4 of 10.12@133mph. On ET Street Radials ![]() "Life is tough. Its even tougher when you're stupid" -John Wayne |
#319 | |
8-15-08 1.70- '60 7.88- 1/8TH. 86.20- MPH
#321 |
A slightly newer best done back in May or June
1.46 sixty 6.56 1/8 105.2 mph New best 1/4 mile August 2nd at HRP 1.52 sixty 6.61 1/8 106.1 mph 10.37 1/4 131.2 mph 2950 lbs race weight, 427ci pump gas mix with a little 111.
Carl S.: 427ci, AFR 225s, Ported Vic Jr, Holley 850, CircleD 9" 4400 rpm converter, C4, 4.10s, 3000 lbs raceweight. 10.30s all motor/pump gas baby! Sponsors: Smokin Tires Racing, Southern Creationz.net http://i269.photobucket.com/albums/jj77/carlrenee1/sigpic1-1.jpg |
#322 |
8-15-08
1.43 60ft off foot brake 6.13 @ 113mph 1/8 mile 9.59 @ 142 1/4 mile
Mods: Trick aluminum valve covers, fancy dancy extra thick spark plug wires, and some redneck glass packs. 9.22@147 3245lbs and shifting at 6400 on a 275/60/15 The dump truck making a pass http://s205.photobucket.com/albums/bb37/98grdpoundr/?action=view¤t=chad936144.flv |
#324 |
78 fairmont 2700 lbs
7.22 86.80mph leaving off footbrake at only 2400 got that prob fixed brakes will now hold it to3600 can't wait to go back
n/a 347 procomp heads funnel web intake tfs stage3 4.56 8.8 stock suspension 60' 1.632 330'4.826 1/8 7.193 mph 86.80 1978 Fairmont the first fox |
#325 |
#326 | |
1998 turbo cobra TH400 GTS78 1.29 60ft 5.73 @ 123.2 1/8 8.93 @ 153.2 1/4 |
#327 | |
My Falcon 6.385@106 and MY Mustang 7.971@85 both on motor
Streetcar 90 Notch Stock 69 351W C6 trans 8.8 with 3.73, Strange 31spline axles and spool Racecar 68 Falcon FE487ci PowerGlide trans. 9' with 4.56 with 33spline axles and spool FE is blown up. BBF 503ci coming soon |
#328 |
7.35 at 97 On motor)
Spinning bad though. Only a 1.68 60 ft Have not ran it on N2O yet (jetted for 125 shot)
1979 Capri, 351W, Edelbrock RPM heads, 2660 lbs , Edelbrock 351 intake, 10.1 compression, BBK longtubes, C-4 w/ transbrake, arms. 11.17 at 120.77 on motor, 1.42 60ft/ 10.22 at 131.83 on 100 shot |
#332 |
so far 12th pass on new set up testing .
1.31 60ft 5.34 at 135 mph 8.60 AT 146mph getting out it ... blew and oring in the injector leaking fuel hoping to get out and test some more on friday saterday.. Neil
possessed racing and fabracation 8.35 @ 166 Last edited by possessed 1; 09-07-2008 at 10:47 PM. |
#334 |
9.334 at 80.57 with 2.345 60 Ft
First time out with the car and with a muscle car, I come from the VW scene. It's on 275/60-15 BFG Street Radials. I suppose the MPH should be good for mid 8's, I hope.'92 CHP Notch Cobra Intake Mani & 1.7 Roller Rockers Stock/debaffled airbox Ford MS shorties BBK catted H Stock mufflers dumped 3.73s Alum driveshaft pulleys Lakewood 50/50s Eibach Dragback Slapper Bars Draglites (skinnies up front) Pro 5.0 Shifter Centerforce clutch I need more seat time, this thing doesn't hook at all!!! |
#335 |
5.75@122.02
9.03@152.75 Dart block 331, hyd roller, ysi supercharger, pms, power glide 30lbs of boost & only 19 degrees total timing
Special thanks goes out to Donathen racing (302man) Mustang Muscle Dyno Service, TMOSS ported edlebrock performer rpm intake Kurgan Motorsports, Freezy74 for the cam, 8.96@155.19 |
#336 |
update, 6.76 @ 101.17....1.45 60ft......88 coupe went 7.19 @ 95.21, 1.58 60ft.
93gt...10.48 @ 128.19, 88 notch...10.98 @ 123, 90 triple black gt.......I need a hooptie.......
#337 |
Previous best: 5.64 at 124mph w/ a 1.26 sixty foot
Last week: 5.61 at 109 mph w/ a 1.25 sixty foot As you can see from the mph, I shut her down before the 1/8 mile marker. I'm pretty sure I can get a 5.4 out of it next time out. |
#341 |
1.51 '60
6.994 1/8th 97.87 MPH 302 H/C/I slicks etc......short video (Thanks Eric) http://www.youtube.com/watch?v=RxD1Ox5VMGI
#346 |
My best 1/8 mile is 7.85 @ 86.2 at Virginia Motorsports Park.
The run resulted in a 1/4 mile time of 12.41 @ 107.3 mph. Two different dyno sessions had 250 and 258 rwhp. I have a 1989 GT Hatchback with:
1989 Mustang GT: Sonic Blue with 347 & AOD 11.40 @ 115.04 with 317 rwhp 2005 GTO: Impulse Blue with 6.0 and 6-speed Daily Driver with 338 rwhp - Stock |
#348 | |
When did you start spraying it? Or did you swap in a 347?
LaserRed '95 GT:Just a little 306 |
#349 |
Trader Feedback: (48)
Car in sig @ 3150lbs
On motor: 1.77 60ft 5.34 330ft 8.442 1/8th 78.94 mph 100 Shot Dry spraying 30ft out 1.67 60ft 4.92 330ft 7.778 1/8th 86.71 mph
88' Coupe, bone stock 5.0, AOD, 3.73 DIY 60mm Turbo Kit, water/meth inj, 7.09 @ 99mph w/ a 1.71 60ft, 14psi
#350 |
Thanks for the compliment, all motor 302, 220,000 mile shortblock driven to the track ![]() Ran a 7.02, 7.03, 7.03, 7.04 and a best mph of 98.23 saturday night and i'll be beatin on it this friday and saturday at the track.
14psi
