Boss 302 crank, pistons and rods in Coyote 5.0 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 08-25-2012, 01:49 PM Thread Starter
If you are thinking about upgrading your internals on your coyote then this thread is for you Ok so here goes, I am in the process of building a B&B AC cobra kit (was planning on an old 302),but I picked up a 2011 5.0 that was replaced under warranty by ford just over 3000 miles on it. Car run great at idle but at higher RPM it had a slight rattle. Turns out number 7 rod bearing started turning. They replaced the engine and I had a chance of picking up the old engine for the price of the Core $1000. After some research I learnt that the Boss 302 uses the same block as the Coyote and Pricing on the Boss stuff was really reasonable so I planned to pick up the Boss parts and do the swap.
Vette454 is offline
post #2 of 16 Old 08-25-2012, 01:50 PM Thread Starter
Pic of car with motor
Vette454 is offline
post #3 of 16 Old 08-25-2012, 01:54 PM Thread Starter
So I ordered the new forged Boss 302 crank and Rod/piston setup from ford since I get 10 over cost (can also be purchased from American muscle). I got a shop manual printed from ford to aid in the buidling of the engine. I came to learn that the Main bearings are individually sized in these engines, not only is each main bearing individually sized on the coyote but the upper and lowers are individually sized. There are 2 charts you use to size them .One chart sizes bearing 1 and 5 and one chart sizes 2 3 and 4. There is a number stamped on the crank and one on the block.
HLKLOC3 is my block number. So HLKLO is bearing 1-5 . There is a similar number on the back of the crank you use to size with and cross reference the block number.
so the bearings can be a combination of 1/2 2/2 2/3 3/3 upper and lower bearing. You size each one this way.
Vette454 is offline
post #4 of 16 Old 08-25-2012, 01:55 PM Thread Starter
This is a shot of the page with the diagram used to figure out main bearing sizes.
Vette454 is offline
post #5 of 16 Old 08-25-2012, 01:58 PM Thread Starter
Another I learnt is the boss 302 has Cracked rods, where the connecting rod is made from one piece of metal and they score the inside of the bearing hole (like cutting a piece of glass) and once you remove the rod bolts then with a good whack you break the bottom cap off of the rod , kinda scary....
Vette454 is offline
post #6 of 16 Old 08-25-2012, 02:00 PM Thread Starter
New Boss 302 forged crank
Vette454 is offline
post #7 of 16 Old 08-25-2012, 02:03 PM Thread Starter
I found a used 5.0 intake complete with fuel injectors , fuel rails and throttle body on ebay. I also picked a new starter , alternator kit , head bolts etc etc , Im just waiting on my Main bearings to arrive before we start getting deep.
Vette454 is offline
post #8 of 16 Old 08-25-2012, 02:05 PM Thread Starter
The boss 302 Piston Kit comes with a set of oil squirter block off plates since they dont use them in the boss , they say it causes to much windage with squiters in the boss engine...
Vette454 is offline
post #9 of 16 Old 08-25-2012, 02:09 PM Thread Starter
Vette454 is offline
post #10 of 16 Old 08-25-2012, 02:10 PM Thread Starter
Happened to snag some new emblems too
Vette454 is offline
post #11 of 16 Old 08-26-2012, 09:32 AM
CCS86's Avatar
Cool project man I'm looking forward to the updates.
Sent from my PG86100 using Tapatalk 2
Formerly: 1995 5.0, Upgraded T-5, Trick Flow Stage 1 Cam, AFR CNC 165 Heads, Scorpion 1.6 RR, Edelbrock Intake, FMS 24 lb Injectors, Pro-M 77mm MAF, TwEECer, MM Control Arms
The Latest: 2012 GT Premium, 6-Spd, GT500 Mufflers, Spohn Del-Sphere Panhard & UCA, Ported Stock Intake
CCS86 is offline
post #12 of 16 Old 08-27-2012, 10:18 AM
RazorbackMustang's Avatar
Very cool. I plan to build a Cobra one of these days and this is along the lines of what I'd do. Modern drivetrain.
Lucas
2011 Mustang GT
2013 Fusion Titanium
RazorbackMustang is offline
post #13 of 16 Old 09-02-2012, 11:06 AM
Are you going to have the rotating assembly balance checked?
2007 BMW 335i
Goody_Seven is offline
post #14 of 16 Old 09-02-2012, 11:23 AM
VAiN's Avatar
Great thread/project! Subscribing, can't wait to see the results.
2012 Grabber Blue Premium GT | Brembo Package
GT500 Exhaust, All Parts STEEDA: 93 Octane Tune, CAI, Cat Deletes, Billet LCA & Relocation Brackets, Adj UCA, Adj Panhard Bar, Sport Springs & Upper Strut Mounts
VAiN is offline
post #15 of 16 Old 09-02-2012, 12:01 PM
jkrahn's Avatar
Subscribing, this looks like fun.
347 AFR 205's, TMoss Vic 5.0, Rawls cam, Tremec 3550.
jkrahn is offline
post #16 of 16 Old 09-02-2012, 12:36 PM
Moderator
Dennis's Avatar
Cool project.
Fracture joint rods are in more engines than you'd think. It is common to make the scribe wtih a laser then fracture the rods on an expanding mandrel. It takes precise metallurgy to get the rods to fracture but still stand up to the stresses. Make sure there are no loose particles floating around when you put the rods back together.
'67 notchback 289 Mustang - first car.
Dennis is offline
