Where do the hooks on the front brake pads go - 4 possibilities - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 12-29-2016, 04:53 PM Thread Starter
Question Where do the hooks on the front brake pads go - 4 possibilities
Which front pad hook goes WHERE?
Got a new set of front brake pads. 2 of the pads have no hooks on them. 2 of the pads have only 1 hook on the end. One hook in one end and the other hook on the other end. It seems that they could go on either side of the caliper and could be on the leading or trailing edge. Where is the proper place for the hooks? Outside or inside on the caliper and leading or trailing edge?
BIGHANK is offline
post #2 of 3 Old 01-01-2017, 04:16 PM
i assume youre referring to the squealers (Wear indicator). Put them on the bottom of the inside of the caliper. So it would be the piston side of the caliper
2007 Mustang GT/CS - BBK CAI
- Comp Cam Mutha Thumpr Cams with Cam Limiters
- Pypes Long Tubes w/ Pypes off road X pipe into Pipes Mid muffler Axle Back Exhaust
NVmy4.6 is offline
post #3 of 3 Old 05-14-2017, 07:11 PM
The go on the inside of the rotor towards the bottom. Like NVmy4.6 said
tesla2008 is offline
