Rack and Pinion - Use PS fluid or ATF? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 33 Old 11-23-2007, 07:40 PM Thread Starter
Luke87GT's Avatar
I keep hearing some people recommending Power Steering fluid in the rack while some people recommend ATF
I've heard the ATF is thinner and will give a looser steering feel. Any truth to this?
The car is a 94GT if it matters. I wanted to see what you guys recommend before I put it into thru my PS pump. Thanks
Luke
Stangless
Luke87GT is offline
post #2 of 33 Old 11-23-2007, 09:46 PM
I believe the good ole Owner's Manual says ATF. That's all I've ever used.
Patrick Olsen is offline
post #3 of 33 Old 11-23-2007, 10:15 PM
I've been using Valvoline's synthetic PS fluid. So far, no ill effects, but is it the best choice? What would be recommended for a car with hybrid parts? I have a Fox pump, which originally saw Type F and an '03 Cobra Rack, which probably was spec'd for Mercon.
2001 BMW Dinan 540i
1989 Lincoln Mark VII LSC
1986 Lincoln Mark VII LSC
1985 Lincoln Continental
ND4SPDLSC is offline
post #4 of 33 Old 11-23-2007, 10:37 PM
MFE
Super Moderator
MFE's Avatar
Foxbody racks and power steering pump spec is Type F ATF. If you run regular PS fluid in them you'll regret it.
EDITED, it was late and I got it wrong
MFE is offline
post #5 of 33 Old 11-24-2007, 03:12 AM Thread Starter
Luke87GT's Avatar
Here is what I have used in the past.
The fluid that is in my rack right now certainly is not red however. Looks like motor oil
Stangless
Luke87GT is offline
post #6 of 33 Old 11-24-2007, 10:15 AM
huesmann's Avatar
Gold, or black?
huesmann is offline
post #7 of 33 Old 11-24-2007, 10:58 AM
MFE
Super Moderator
MFE's Avatar
Yes, sorry, Type F is what's called for in these systems, not Mercon or PS fluid.
MFE is offline
post #8 of 33 Old 11-24-2007, 11:18 AM Thread Starter
Luke87GT's Avatar
huessman, it is gold
Stangless
Luke87GT is offline
post #9 of 33 Old 11-26-2007, 04:32 AM
Any idea what to use for a system with a Fox pump and an SN95 rack? It's two different recommended fluids.
2001 BMW Dinan 540i
post #10 of 33 Old 11-26-2007, 04:42 PM
MFE
Super Moderator
MFE's Avatar
I'd go with the Type F, because it's the pump that's sensitive to it, not so much the rack
MFE is offline
post #11 of 33 Old 11-27-2007, 01:31 AM Thread Starter
Luke87GT's Avatar
You telling me there is a different recommended fluid for 94-95 vs fox?
Stangless
Luke87GT is offline
post #12 of 33 Old 11-27-2007, 08:35 AM
Glenn's Avatar
According to my Mitchell-on-Demand a 1990 and a 1995 Mustang both specify ATF Type F for power steering. There is a possibility that seal compatibility might be an issue with long term use of something that does not meet Ford requirements.
The main difference in Type F fluid is it has a different friction modifier vs the Dexron/Mercon fluids. This was a concern in transmissions of older Fords but I can't see it being a major issue in power steering. FWIW I have used PS fluid, Mercon and now Mobil-1 ATF in my system. The Mobil-1 seems to take to on-track driving better than the others with a noticeably reduced tendency to foam, especially in autocross events.
Glenn is offline
post #13 of 33 Old 11-27-2007, 09:47 AM
Han Solo's Avatar
The owners manual for my 99 GT specifically says Mercon V. My 03 F150 just says use Mercon.
Like stated above the earlier cars called for type F but I have no idea when they changed.
Years ago we had to use type F in most all european cars due to seals being damaged by Dexron but I was told the compatibility issues were due to the use of natural rubber seals verses neoprene.
99 Mustang GT - Auto-x/track car, 96 Townsend Chassis Late Model Stockcar, 03 F150 - Daily Driver
Han Solo is offline
post #14 of 33 Old 11-27-2007, 02:37 PM
MustangTurboCoupe's Avatar
I run mercon V in mine.
Mustang GTS
89 Country Squire
MustangTurboCoupe is offline
post #15 of 33 Old 12-06-2007, 02:29 AM Thread Starter
Luke87GT's Avatar
Lots of opinions here guys, lol
Any other opinions before I put in the wrong stuff and cause a premature leak
Stangless
Luke87GT is offline
post #16 of 33 Old 12-06-2007, 10:02 AM
Trader Feedback: (18)
ATF type F. That's what the Ford manual calls for.
Goodson is offline
post #17 of 33 Old 12-06-2007, 11:58 PM Thread Starter
Luke87GT's Avatar
Thanks guys!
Stangless
Luke87GT is offline
post #18 of 33 Old 12-15-2007, 02:05 PM
MTNMAN's Avatar
I'm running a AGR pump with a 93 Cobra rack. AGR says they require using clear PS fluid. If not you pump is void of warrenty. I was running normal PS fluid and switched this year to Valvoline Syntec. That being the case I had always ran Amsoil ATF in the past and would still be if AGR didn't specify PS fluid. Run a synthetic fluid if you can find it.
1989 LX
331
assorted Maximum Motorsports parts
BAER brakes
OMP, Racetech, Safecraft, Amsoil, Zamp helmets,
Bell/Pyrotect, FinishLine, Crow, Autopower & Pro Challenge Race Cars
MTNMAN is offline
post #19 of 33 Old 12-15-2007, 03:27 PM
stangmaster's Avatar
according to fords latest tsb's ALLLLLLLL ford systems are to be switched to merc 5 atf after service. Ford recomends to add up to 2 tablespoons of friction modifier commonly used in the rear of trac-loc cars. It will quiet the pump and give the steering a smoother feel
Fox 8:50
"And the dynos rumbled, and God spoke 'Take thine five liter v8, install it upon thine car, and pwn the many ricers!' And thus Mustang, son-of-Ford, began to dominate the world 4 cylinder powered imports. And God looked down upon it and saw it was all that and a bag of chips
stangmaster is offline
post #20 of 33 Old 12-16-2007, 05:05 AM
Interesting about the friction modifier.
post #21 of 33 Old 12-17-2007, 09:04 AM
huesmann's Avatar
Never heard of that before. If you just flush and fill should you add the friction mod?
huesmann is offline
post #22 of 33 Old 12-18-2007, 01:34 AM Thread Starter
Luke87GT's Avatar
Friction modifier in the PS pump... That's a new one for me too...
Stangless
Luke87GT is offline
post #23 of 33 Old 12-18-2007, 09:01 AM
Glenn's Avatar
According to Mitchell, the TSB applies only to those vehicles that use Mercon®, mainly Fords from 1996 and newer. The change is due to Mercon® being phased out and eventually no longer being available. According to the TSB July 1, 2007 was the cutoff date for producing Mercon®. Once supplies are exhausted you will then use Mercon ® V.
There is also a CAUTION in the TSB for systems that have Type F as the recommended fluid. These systems should continue to use Type F or they may suffer reduced functionality or system damage.
For the record, I did not see any reference in the TSB to addding friction modifier.
The TSB is Reference Number(s) 07-1-7, Date of Issue: January 22, 2007
Glenn is offline
post #24 of 33 Old 12-18-2007, 09:02 AM
Han Solo's Avatar
Off topic but I use friction modifier in my T-45 tranny with 10w30 synthetic blend motor oil. Made a big difference in shifting and no problems with syncros after 60K+ miles.
Han Solo is offline
post #25 of 33 Old 12-18-2007, 10:24 AM
MFE
Super Moderator
MFE's Avatar
Yay for REAL ####ING TECH!
MFE is offline
post #26 of 33 Old 12-18-2007, 11:29 AM
AMEN!!
Goodson is offline
post #27 of 33 Old 12-19-2007, 08:57 AM
Jax Rhapsody's Avatar
Only those use ATF in the PS right no early foxes those just use PS fluid like everything else.
Jax Rhapsody is offline
post #28 of 33 Old 12-20-2007, 10:14 AM
dan50's Avatar
Your grammAr doesn't make sense.
Use ATF Type F in your Fox. End of story. No power steering fluid.
2015 Dodge Challenger 392 Hemi
1983 Bronco XLT 351W sleeping until 2018...
1991 Mustang GT 5.0 SOLD!
dan50 is offline
post #29 of 33 Old 12-20-2007, 12:45 PM Thread Starter
Luke87GT's Avatar
Originally Posted by pgtpwr View Post
grammer
If you are going to comment on someone's grammar, at least spell the word right. I don't know which is worse.
Stangless
Luke87GT is offline
post #30 of 33 Old 12-20-2007, 01:00 PM
dan50's Avatar
At least you could figure out what I was saying.
Big difference between a typo 3 and year old grammAr.
dan50 is offline
post #31 of 33 Old 12-21-2007, 09:08 AM
huesmann's Avatar
Are you dyslexic too?
huesmann is offline
post #32 of 33 Old 12-21-2007, 11:51 AM
dan50's Avatar
Just sometimes
dan50 is offline
post #33 of 33 Old 12-22-2007, 01:28 PM
The manual calls out ATF Type F. So I use ATF Type F.
I cut a hole in the floorboard so I can push the gas pedal down more. It made an additional 50rwhp/43rwtq on the dyno.
"Konichiwa, bitches" - RZA
fatchick1o9 is offline
