Ball joint replacement...how difficult? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 06-01-2005, 04:42 PM Thread Starter
Both of my front BJ's have torn boots and I want to replace them (with OEM). How hard is it to press these in/out of the lower with the coventional bj hand tool?
Alex M is offline
post #2 of 17 Old 06-02-2005, 08:42 AM
Fairly easy actually. I was surprised, even with my $35 Ebay press. I just had to heat them up a little and whack them once with a hammer beofre I put on the press.
92MNstanger is offline
post #3 of 17 Old 06-02-2005, 08:57 AM
Han Solo's Avatar
ORRR it could go like mine did and require a gazillion pounds of pressure in a hydraulic press. Thing sounded like a cannon went off when they let go the final fraction of an inch. LOL
If it doesn't act like it's going smooth for you go ahead and remove the control arms and take them to a shop to press them out and in.
99 Mustang GT - Auto-x/track car, 96 Townsend Chassis Late Model Stockcar, 03 F150 - Daily Driver
Han Solo is offline
post #4 of 17 Old 06-02-2005, 10:19 AM Thread Starter
Is it worth paying the extra $100 for the complete arm replacement (03/04 cobra)?
Alex M is offline
post #5 of 17 Old 06-02-2005, 03:03 PM
Oktavius's Avatar
I replaced mine with the balljoing press from AutoZone. As Han Solo says, it sounds like a cannon going off.
The only problem that I ran into was that when I was trying to seperate the old ball joint from the spindle, I wacked the top of the balljoint. This made the top of the balljoint slopped. So when I went to press it out, the press wanted to slide off. Took some work, but I got it out.
And for future searches, you should only replace balljoints once in a set of control arms. Each replacement stretches the balljoint hole. Replacement balljoints, including X2 balljoints, are larger diameter than the stock balljoints. This is so that they fit since the hole was stretched when the initial stock balljoints were installed.
Tim ||||||| ||||||| |||||||
07 Subie Impreza - DD
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #6 of 17 Old 06-02-2005, 03:05 PM
Oktavius's Avatar
From what I have heard, the '03/'04 Cobra arms are a better stamping with more turning radias. They also have new bushings. They would also be easier to replace then the balljoints. So far I see three reasons to get them.
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #7 of 17 Old 06-02-2005, 07:26 PM
huesmann's Avatar
And the $100 is peanuts.
huesmann is offline
post #8 of 17 Old 06-30-2006, 12:42 AM
Do you need anything special to use the 03/04 arms? I have a 91, and I need to replace the lower ball joints. Do the 03/04 weight less?
Thanks,
-sam.
QWKENF is offline
post #9 of 17 Old 06-30-2006, 02:30 PM
huesmann's Avatar
If I'm not mistaken, the Cobra arms will be longer than your '91 arms. How much longer seems to be a matter for debate. However, the additional length may or may not create fender clearance issues for you.
huesmann is offline
post #10 of 17 Old 06-30-2006, 02:38 PM
hwyracer's Avatar
now i am interested....does anyone know if the 03/04 a-arms are longer than stock 87-93? and if they will bolt right in?
Track car: '96 Cobra Stock engine & trans. MM PHB, TA & rear adjustable sway bar, Koni coil-overs, MM A-arms, (K-member coming), Koni coil-overs, Brembo 4-pots w/ ducting. Torsen diff, 4-pt roll bar, .......and the list keeps growing.
New arrival: '93 Cobra
hwyracer is offline
post #11 of 17 Old 06-30-2006, 03:06 PM
90lx86svo's Avatar
All 94-04 front control arms are the same length.
86 SVO
95 Lightning
90lx86svo is offline
post #12 of 17 Old 06-30-2006, 03:27 PM
MFE
Super Moderator
MFE's Avatar
Which means they're longer than the '87-93. If you don't want them that way you can order the FRPP arms for 97-93's, and in them comes upgraded bushings and newer style low-friction ball joints.
MFE is offline
post #13 of 17 Old 06-30-2006, 03:52 PM
hwyracer's Avatar
I went with taking my arms to a machine shop i have used for years. he charged me $40 to remove the old bal joints AND bushings & then install new ball joints AND poly bushings.
I remember my 1st set of ball joints I replaced. My friend had a press. I pressed the old ones out (took alot of force) then pressed in the new. I froze the new & had the a-arm sitting in the sun all day. the ball joint went in easy.
hwyracer is offline
post #14 of 17 Old 07-03-2006, 04:20 PM
Mustang408's Avatar
Mustang408 is offline
post #15 of 17 Old 07-05-2006, 12:08 PM
Saleen308's Avatar
Where have you found them for $100?
Are the 03/04 A-arms longer or the same length as the fox a-arms? Can you still use fox struts, springs, etc. ?
2006 GT 5spd man, coupe 13.3 at 105mph on street tires - SOLD
Saleen308 is offline
post #16 of 17 Old 07-05-2006, 01:01 PM
MFE
Super Moderator
MFE's Avatar
He said $100 EXTRA compared to paying for the joints, and for the thousandth time, the '03/04 A-arms are longer than the fox arms.
MFE is offline
post #17 of 17 Old 07-05-2006, 02:07 PM
carrew's Avatar
I just wack it with a good quality steel hammer and they fall out. Then use the vatozone C press. I have even tack welded around the balljoint in three places after installation just for piece of mind.
Last set I purchased the FMS arms with X2's already installed and a set of Delrin bushings.
2014 Camaro 1LE
2001 Cobra White SOLD
1989 Mustang GT "F0xR0d" SOLD
12.49 @ 116.8 mph (BFG KDW Street tire)
carrew is offline
