Eibach drag-launch springs & Tokico D-spec shocks & struts - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 03-01-2012, 11:05 PM Thread Starter
Is anybody running these springs? Im looking at running these on my car. It will be a 500rwhp daily driver. I want the car to hook up well and also handle/ride nice. Will I get that with these springs? Also looking at Tokico D-specadjustable shocks and struts to get me a good hook up at the track and nice ride around town. Any suggestions on these? Also, how much will these springs lower the car? Thanks, David
1993 Teal Cobra, cammed w Twisted wedge heads, 50lb injectors, full exaust, tremec 3550, and a Novi2000 to top it all off.
DavidLevi is offline
post #2 of 9 Old 03-02-2012, 09:55 AM
MFE
Super Moderator
MFE's Avatar
Drag springs? Good handling? No.
MFE is offline
post #3 of 9 Old 03-02-2012, 10:01 PM Thread Starter
Ok, decent handling? I want the car to hook, thats my biggest concern, but don't want to sacrifice the ride & handling much. Does anybody have any suggestions on springs that meet that criteria? Also looking to lower the stance a bit
post #4 of 9 Old 03-28-2012, 06:13 PM Thread Starter
Anybody have an opinion on a good setup to meet my criteria?
post #5 of 9 Old 03-29-2012, 04:44 AM
06GT300's Avatar
I suggest you use the search button, to avoid asking anymore stupid contradictory questions.
06GT300 is offline
post #6 of 9 Old 03-29-2012, 08:22 PM Thread Starter
Alot of help you are pal
post #7 of 9 Old 03-30-2012, 05:06 PM
clean93's Avatar
these springs will raise the ride height and they will not handle well. but theyre good for traction at the strip thats pretty much it. you can cut coils to lower it if you like. i would just get eibach pro kit unless you plan on only using the car for the dragstrip then you can go with the eibach drag launch springs
Aaron
1993 Mustang GT built and tuned by JPC Racing
clean93 is offline
post #8 of 9 Old 03-30-2012, 05:11 PM
I like the combo of fox four cyl springs with a trimmed coil and mach 1 rear springs
Sent from my DROID3 using Tapatalk
dsmdave is offline
post #9 of 9 Old 03-30-2012, 09:42 PM
john98's Avatar
Eibach Drag springs are junk for straight line let alone handling. If you want comfortable balance between comfort and straight line and OK hadling, just stay with your stock springs, cut one coil off and the aforementioned D specs
89 GT
john98 is offline
