For Sale Feeler Ad: Novi 2000 kit 87-93 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 03-18-2017, 11:53 AM Thread Starter
I've hung on to this for along time and finally considering selling it since I haven't used it. Novi 2000 straight volute for intercooler setup or non intercooled with a 90 degree elbow. Headunit has one dyno pull, never been run on a car so basically still new. 8-10lb setup currently. List includes
Novi 2000 headunit- basically still new
10 rib blower pulley- new
90 degree elbow- new
Double bracket setup
8 inch 10 rib Renegade crank pulley- new
Oil drain line- new
Oil feed line
Custom discharge pipe with mondo bov connnection welded on
Intake pipe
90mm aluminum maf housing
Filter
Bolts
Radiator pipe
Clamps
You will need a bov, $2500 pm with any questions thanks
BoostedBlock is offline
post #2 of 8 Old 03-19-2017, 04:34 PM
brad87gt's Avatar
Trader Feedback: (52)
Drivers side?
brad87gt is offline
post #3 of 8 Old 03-19-2017, 05:31 PM Thread Starter
Passenger side
post #4 of 8 Old 03-20-2017, 06:58 AM
Do you have installed pictures of it? Thanks
1988 Hatch: 414w, AFR 225's, CompCams XFI 236hr cam, 42lb injectors, 95mm PMAS MAF, Reichard Racing Trick Flow TFS-R air gapped lower, TFS-R 90mm upper, Accufab 90mm tb, Kooks 1-7/8'' longtubes, Tremec 3550 TKO, 3.73's, Moates Quarterhorse, BE/EA
PoweredByAFR185 is offline
post #5 of 8 Old 03-20-2017, 07:25 AM Thread Starter
I never installed it
post #6 of 8 Old 03-23-2017, 05:18 PM Thread Starter
Up
post #7 of 8 Old 03-26-2017, 11:54 PM Thread Starter
$2400
post #8 of 8 Old 03-29-2017, 02:56 PM Thread Starter
Sold
