For Sale CCW Vortech Jt-B - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 03-02-2017, 01:22 PM Thread Starter
CCW Vortech Jt-B
This head unit has never been ran or mounted. Volute can be rotated in any direction for your application.
Specifically designed for higher output on the modular Ford Mustang engines. The next step in compressor development, incorporating a technologically advanced, high-efficiency, 5-Axis machined billet impeller and high-diffusion housing developed in our SAE-J1723-compliant supercharger test cell.
The V-7 Series combines the advanced technology and race-proven performance and fits most of our existing mounting bracketry. The V-7 is designed for vehicles with highly modified engines and extreme CFM/boost demands. All units feature our exclusive D-port volute for improved efficiently and require the use of a Vortech Racing Bypass Valve or larger to meet discharge flow demands. The heavy duty (H/D) configuration includes high speed, ceramic hybrid ball bearings, ideal for race applications, and is compatible with cog pulley/Gilmer style drive setups.
$2650 shipped
Retails $3724.99
The V-7 JT-B Specs:
Inlet Hose Diameter: 4.00
Outlet Hose Diameter: 3.00
Impeller Inducer Diameter: 3.56
Max Pressure: 29+ PSI
Impeller Speed Max: 65,000 RPM
Max Horsepower: 1,000+
Euthanasia is offline
post #2 of 12 Old 03-08-2017, 08:15 PM Thread Starter
ttt obo
post #3 of 12 Old 03-08-2017, 10:33 PM
what is a JT-b ? where do you get that upgrade from ?
p4ndiamond is offline
post #4 of 12 Old 03-09-2017, 02:51 PM Thread Starter
Its the Jt trims big brother. The Jt-B comes with a billet impeller and a larger impeller shaft. Its not a upgrade. You have to buy the Jt-B
post #5 of 12 Old 03-24-2017, 01:10 PM Thread Starter
top
post #6 of 12 Old 04-03-2017, 03:45 PM Thread Starter
post #7 of 12 Old 04-11-2017, 01:17 PM Thread Starter
$2500 shipped
post #8 of 12 Old 04-17-2017, 04:30 AM
Trader Feedback: (27)
Dammit man! I'm just about to pull the trigger on a turbo setup, and NOW you do this... lol
1996 white/saddle Cobra convertible
Scammed by "Check M8" aka Brian C. Walkington of Jacksonville, Fl.
Droptop Snake is offline
post #9 of 12 Old 04-18-2017, 11:37 AM Thread Starter
You really don't want a turbo anyways lol
post #10 of 12 Old 05-18-2017, 08:47 AM
vortech gt's Avatar
Email sent
96gt,svo intake,svo heads,mhs blower cams strim(2.87)pulley,AFM powerpipe,60's,340 intank
sct2600,svo headers,x pipe,4.10's.495rwhp,13psi.water methanol.
11.83@121 on 18 inch drag radials@495rwhp
new numbers 577rwhp,526rwtq.new track times coming.
vortech gt is online now
post #11 of 12 Old 05-20-2017, 10:23 AM
Answer your messages, muzza fuzza.
post #12 of 12 Old 06-13-2017, 07:04 PM
Bump for Captain Incommunicado... hope everything is alright with you. GLWS
Closed Thread
