| Sponsored Links | |
Advertisement |
#4 |
If you look at the 3.5 pulley picture you can see that there are two slots or keyways where the pulley would connect to the shaft. Single key pulleys only have 1 slot. You'll see the matching key on the shaft of the supercharger. Double key is an upgrade as I believe most pro chargers are single key but you'll need to check yours to verify. The double key will work on a single key setup but the single key will not work on a double key setup.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
