For Sale Procharger D2R $1500 + shipping - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 11-28-2010, 08:07 PM Thread Starter
comecorrect's Avatar
$1500+ shipping
I'm selling a SBF Procharger D2R. I went 8.85 @ 158mph with it untuned at 3100lb. It have 23 1/4 mile and 8 1/8 mile passes on it. The 50mm cog setup has 42t blower and 77t crank pulleys. The kit include everything in the picture plus brained lines. All it need is the oil fitting that goes in the blower and your tubing. I will include a procharger 3 core sheet metal A/A intercooler with 3 1/2" oval opening. It's beat up and needs to be pressure tested. I'm selling it to get a roots blower for my race car. A picture of it on the car can be seen in post 25.
http://www.yellowbullet.com/forum/sh...d.php?t=299769
Thanks!
MIKE
Procharger D2R specs:
Volute diameter = 10.5"
Max Flow (cfm) = 2800
Inlet Hose Diameter = 4.5"
Inducer Diameter = 4.35"
Exducer Diameter = 7.2"
Outlet Hose Diameter = 3.5"
Outlet I.D. = 3.15"
Max Impeller RPM = 53,000
Internal Step-up = 4.44
More pictures can be seen here.
http://s217.photobucket.com/albums/c...ct/for%20sale/
Michael S. U.S ARMY Only two defining forces have ever offered to die for you: 1. Jesus Christ
2. The American G. I. One died for your soul, the other for your freedom. World's fastest SBF Powered Z06 Corvette
comecorrect is offline
post #2 of 13 Old 11-30-2010, 06:05 PM Thread Starter
The blower made 26lbs of boost on my 408. Below are some more details. Thanks!
Max Superchargered HP 1600
Bas HP Range of Motor 175-600
(Naturally Aspirated)
Max Flow (cfm) 2800
Max Boost (cfm) 34
Volute Diameter 10.5”
Inlet Hose Diameter 4.5”
Inducer Diameter 4.35”
Exducer Diameter 7.2”
Outlet Hose Diameter 3.5”
Outlet I.D. 3.15”
Max Impeller RPM 55,000
Internal Step-up 4.44:1
Reverse Rotation No
Self Contained No
Oil Capacity N/A
post #3 of 13 Old 11-30-2010, 09:09 PM
what a smokin deal, I cant believe this hasnt sold yet. if I can scratch up the cash before it sells I will pick it up from you.
1320notch is offline
post #4 of 13 Old 12-01-2010, 07:09 AM Thread Starter
I think being so close to the holiday's may have something to do with it, also the D2R had a very short production run so most may not know much about it. Thanks!
MIKE
post #5 of 13 Old 12-06-2010, 07:26 PM Thread Starter
post #6 of 13 Old 12-08-2010, 09:37 PM
do you still have the d2r kit availble? what rpm did you shift at with this on your car?
thanks matt
745gt is offline
post #7 of 13 Old 12-09-2010, 09:00 AM Thread Starter
I still have it. I shifted at 6600rpm. Thanks
p.s. Search all the treads I started here on the corral and hardcore50 for the build history and usage.
MIKE
post #8 of 13 Old 12-09-2010, 09:43 AM
d2r
could you post a pic of the tag on the blower
thanks matt
745gt is offline
post #9 of 13 Old 12-09-2010, 07:55 PM Thread Starter
The tag is worn due to the brace I made. You can see the brace in the pictures below. The serial # is 21148. Thanks!
post #10 of 13 Old 12-18-2010, 05:40 PM Thread Starter
post #11 of 13 Old 12-26-2010, 09:05 AM
Trader Feedback: (47)
pm sent
turbovert04 is offline
post #12 of 13 Old 12-26-2010, 09:40 PM
SHONUF816's Avatar
That's a smokin deal! i told my cousin about this. he has a 414sbf and he is looking for something like this! hoppefully i'll have it sold for ya! if not, GLWS!
SHONUF816 is offline
post #13 of 13 Old 12-28-2010, 09:46 PM Thread Starter
Thanks! I've been told I listed it too cheap! Now that Christmas is over I expect it to sell. If it doesn't I may put it back on the car for this year.
MIKE
