1994 ranger pro street w/ sbc trade 4 mustang - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 07-06-2006, 01:33 AM Thread Starter
i have a 1994 ford ranger xlt pro street tubbed for trade or sale for mustang 87-93 with 4 link coilovers with a narrowed ford 9" strange rearend with 35 spline strange axles and spool with a aluminium strange center section 3.50 bearing with 615 gears which im removing and putting 411's in this week......truck has a small block chevy sbc 305 40 over with a 600cfm edelbrock carb a hurricane high rise air gap intake,billet distributor with super coil ,100 amp chrome alt and billet pulleys...trans is a 400 turbo longtail,rear tires are 31x18.5 on a 15 wide and 205 60 15's on 5 1/2 inch skinnys up front.rims are prostars all round...has clear head lights and tail lights all the way around...a bed cover ...that covers a rhino lined bed with a new 20 gallon foam filled fuel cell not seen in pics cause it was just added cell has 90 ohm sender fuel cell hooked to a 500gph electric carter pump with all stainless steel braided line....paint is vibriant grabber green..new and in good shape.exhaust 2.5 with 1 chamber flows...this was a chassis off build frame painted to match...truck has tach oil volt and temp gauge all hooked up and working...i have the truck wired to works off toggles and a push button start not with the key but could if you wanted...i have everything to re install the A/C if wanted.truck has power steering....interior is black died panels with mustang gt bucket seats.......trucks a blast to drive...and stops every car show i go to...and have taken a trophy everytime...selling cause wife is 8 months preganant and is due in aug and wants to stay how with the baby...
theres a lot of money in this truck
heres a small list of some of the reciepts for the build on this truck
Paint and body work vibrant grabber green with 5 coats color 5 clear $2,300
strange rear hosing w/ axle bearings studs alum 3.50 center w/spool/gears & brakes $4000
Labor on suspension and frame backhalf $6000
Engine Assembly, Crate Engine, , 8.5:1, 330 hp, 375 ft.-lbs. Torque, $3,999.95
Automatic Transmission, Forward Shift Pattern, Automatic Valve Body, Chevy, TH400,$799.88
Gauge Kit, , Ultra Light Race Panel, 2 5/8 in., Water Temperature, Oil Pressure/Temp., Fuel Light, Kit $97.95
Automatic Shifter, Unimatic, Chevy, Each $99.95
Fuel Pump, Electric, Competition Series Black Pump, Rotary Vane, External, Universal, Each $99.88
Carburetor, Performer, 600 cfm, 4-Barrel, Square Bore, Electric Choke, Single Inlet, Silver, Each $264.95
Fuel System Plumbing Kit, Fuel Pump to Fuel Filter, -6 AN Braided Flex Line,. Length, Kit $37.88
Tire, Sportsman , 31.0x18.5-15LT, Bias-Ply, DOT- Approved, Blackwall, Each $579.90
Tire, Sportsman Front, 26.0x7.5-15, Bias-Ply, DOT- Approved, Blackwall, Each $197.90
Fuel Cell, , Black foam filled, 20 Gallons, 0-90 Ohm Sender, Each $299.95
Distributor, Blueprinted HEI, Magnetic Pickup, Vacuum Advance, Red Cap, Chevy, Big/Small Block, Each $149.95
Flexplate, 168-Tooth, Internal Balance, 2-Piece Rear Main Seal, SFI 29.1, Chevy, V8, Each $49.95
Torque Converter, Chevy, TH350/TH400, Each $229.95
Fuel System Plumbing Kit, Fuel Pump to Fuel Pressure Regulator, -6 AN Braided Flex Line, 3 ft. Length, Kit $32.95
Fuel System Plumbing Kit, Fuel Pump to Fuel Cell, - AN Braided Flex Kit $119.95
ehtorok is offline
Closed Thread
