who is having problems with nx solenoids?? and realy problems??? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > Power Adder Forums > Nitrous
Old 11-21-2005, 12:16 PM   #1
i have had an almost brand new solenoid(fuel) go bad on me on the dyno, i got back form the dyno and checked the solenoid from a pure source to make sure it wasnt electrical currant shortage. i found out that the solenoid was only opening up a 1/4 of the way it should be.
Well i took it to the track after i put i new solenoid on it, and now the nitrous kit wont come on at all..
!!!!!! when i put the new solenoid on it i tested it out, and it worked fine one time, now it does not work at all, im thinking bad relay and im getting rid of the relay tonight !!!!!!
__________________
91 coupe 65k miles - 428w 9.5:1 compression, TFS 225cnc HP, Accufab Midlengths 3 inch Mac exhaust. FTI Cam, super victor EFI, 60lb injectors - TKO600
94 cobra...Cobra R clone with stock 302cobra motor.
red93notch is offline
Old 11-21-2005, 02:07 PM   #2
sounds like something else causing the problems, id figur eit out before you spray, cause if you dont, you wont have a motor to spray on. send them to Josh at NX and have him test them for ya.
st@ngsteve1993 is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
