#1 |
what is the best head gaskets made for nitrous?
hi i have ran a nx 100 shot about 8 times now without any problems, i stepped up to a 150 shot and did 2 3-4th passes and i did it from a dead stop the other day and 1-3rd were perfect and then half way thorugh 4th poof white smoke everywhere,........... the head gaskets are in there are the $40 felpro gaskets , i should have put much better ones in there but i didnt, but now i dont want to make the same mistake twice, what is the best head gaskets for use with nitrous??? i have 9.5-1 compression and might have 10-1 soon i have trickflow tw heads and was using a nx 150 shot thanks for the help..
__________________
306ci with Dss fly cut pistons for trick flow tw heads,tw heads, e-cam, trickflow track heat intake, pro-m 80mm mass air,Anderson power pipe, Ramchargers ele fan, acufab 70mm tb,kirbin adj fuel pressure reg, 24 lb motorsport injectors, 180 stat, asp under drives ,spec stage 2 clutch steeda clutch quad&firewall adj, tremec 3550 with pro 5.0 shifter,frpp alum drive shaft,frpp 3:73's frpp cermaic shorty headers,mac off road h-pipe,2 1/2 mac cat back exhaust, , mac subframes, autometer 5in sport comp tach, msd 6 digital plus, msd window switch, 2 1/16 mech water temp and oil pressure in pillar pod, 2 5/8ths vac and nitrous guages in ac vents, goodyear blue hoses, autozone 3 core rad, msd blaster coil metco drive shaft loop, walbro 255lph high pressure pump, granatelli motorsports upper and lower control arms, eaton 31 spline posi, superior 31 spline axles, trickflow rear end cover, mac adjustable pinion snubber, poly end links and poly spring isolators. 95 black leather cobra seats,96 17 in chrome cobra rims. -NX TRICKFLOW PLATE SYSTEM 50- 300 SHOT NX AUTO BOTTLE OPENER NX AUTO BOTTLE HEATER blow down tube, fuel pressure saftey switch, painless ashtray nitrous switchpanel. -dyno results 438.5rwhp 517.5rwtq with 150 shot at 10.5:1 a/f TUNED BY PAT SPEER, MIKE DEZ RACING. weight with driver 3416 w/o 3148 -TIRES FOR TRACK DUTY Hoosier 27x11.5-15 qtp |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
