Help!! Ticking noise on the gas?? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > Power Adder Forums > Nitrous
Old 08-26-2003, 09:18 PM   #1
Member
I have been using a Zex 100 shot for about 3 months now.. Never ha a problem..... Last time i shot the nitrous, i started hearing some ticking noises.... Don't know if it is the engine or the headers..??? The thing is the car still pulled strong, but after i shut off the nitrous I tried running na, ran hard and couldn't hear any noise.... My car has a 255 pump, timing at 8 deg, stock engine, and running 93 octane.... What could be the reason for the noise???
Thanks in advance.
Rick
__________________
94 Green Vert GT
Full Mac Exhaust
Steeda Tri-ax
Kirban AFPR
Walbro 255
C&L 76mm
BBK 65mm
MSD Digital 6
Cobra Brakes
Tokico Shocks and Struts
X2C uppers and lowers
ZEX 100 shot
rchung is offline
Old 08-26-2003, 09:28 PM   #2
check the plugs for shiny speckles or black speckles that look like pepper spots. If you see any of that then it was detination. You need to check all the plugs not just one. If you do find any problems like that you probably need to take either more timing out or just run some higher octane gas.
__________________
Ran 6.10 1/8 mi and getting out the gas 3/4 track. 347, canfeild heads, Victor5.0 intake, TNT nitrous, Compucar nitrous, C-4 no transbrake, 13.5 ET streets, stock computer w/extender, 30# injectors,and the car is 3100#'s. ANY ?'s.
WAO Racing is offline
Old 08-26-2003, 09:37 PM   #3
David1969's Avatar
I have a ticking noise coming from the engine bay and it's the headers. They seem to be leaking a little exhaust from one of the collectors and you can hear it, but only when you're on the gas.
__________________
'95 Cobra #802 of 4005, born 1/10/95, 2 chamber flow's, H&R SS springs, BBK O/R H-pipe, BBK Longtubes, Romac balancer, MM Bilstein shocks/struts & C/C plates, 3.73's, Kirban AFPR, FMS blue wires, MSD Blaster coil, MSD BTM, Autometer Lunar Boost & Fuel Pressure gauges, 80mm Pro-M, 42# injectors, Vortech S-trim, AFM Powerpipe & AFM B-21 cam, twEECer.....more to come!
I'm not speeding officer, I just look fast!
David1969 is offline
Old 08-26-2003, 11:48 PM   #4
Member
That was my first assumption. I am gonna try to tighten the header bolts, and see if it continues... Something i never did since i installed them....
Rick
__________________
94 Green Vert GT
Full Mac Exhaust
Steeda Tri-ax
Kirban AFPR
Walbro 255
C&L 76mm
BBK 65mm
MSD Digital 6
Cobra Brakes
ZEX 100 shot
rchung is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
