For Sale MMR Billet Aluminum Main Caps For Ford Modular & Coyote Engines - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 02-02-2016, 08:40 PM Thread Starter
authorized corral.net advertisers
Mod Mustang Racing's Avatar
Trader Feedback: (59)
Replace the factory heavy cast iron Main caps with these Billet ALLOY Caps from MMR. They feature increased strength over the factory weak caps and provide increased bearing support for applications over 600HP. Billet alloy main caps are used in ALL Top Fuel and Funny Car applications - If they can handle 12,000HP imagine what they can do for your Ford Modular Engine!! Other benefits such as same thermal expansion rate as the factory block means that your line hone is perfectly straight under all warm-up and thermal conditions. Line Hone is required after installation.
Order now: MMR Billet Aluminum Main Caps For Ford Modular & Coyote Engines [400499] - $399.99 : Modular Motorsports, Home of the Worlds Fastest Modular Engines
Saves up to 7 lbs!!
Approx 23,000 PSI Tensile Strength Increase over factory Main Caps
Available for:
1995-1999 Teksid Alloy Block (8mm side Bolt / Jack screw)
1995-1999 Teksid Alloy Block (9mm side Bolt)
2011-2017 Ford 5.0 Coyote Blocks (ALL)
99-2010 WAP Alloy Block- 99-04 Cobra/Mach One & 05-10 Mustang GT
Ford GT / GT500 5.4 / 5.8 Alloy Block
Ford Racing Boss Block
Romeo Cast Iron Block
Windsor Cast iron Block 4.6
Windsor Cast iron Block 5.4
1-877-MOD-POWR
Precision Engineered Modular Engines and Components,
,5 speed Record holder-8.99@154
RANKED TOP TEN MUSTANGS OF 2011 by MM&FF Magazine
Mod Mustang Racing is offline
post #2 of 11 Old 02-23-2016, 12:34 PM Thread Starter
1-877-MOD-POWR
post #3 of 11 Old 02-25-2016, 12:45 PM
pretty!!!, do yall make the chain tensioners in the plain, non anodized finish as well?
Paulinator is offline
post #4 of 11 Old 02-26-2016, 04:16 PM Thread Starter
The Coyote secondary chain tensioner bracket is only available in the MMR red anodized. If you wanted one non anodized we could certainly do one custom however.
1-877-MOD-POWR
post #5 of 11 Old 03-11-2016, 01:46 PM Thread Starter
1-877-MOD-POWR
post #6 of 11 Old 04-12-2016, 11:55 AM Thread Starter
1-877-MOD-POWR
post #7 of 11 Old 05-11-2016, 03:16 PM Thread Starter
1-877-MOD-POWR
post #8 of 11 Old 06-20-2016, 06:04 PM Thread Starter
1-877-MOD-POWR
post #9 of 11 Old 07-28-2016, 12:10 PM Thread Starter
Ttt
1-877-MOD-POWR
post #10 of 11 Old 01-12-2017, 01:52 PM Thread Starter
1-877-MOD-POWR
post #11 of 11 Old 02-17-2017, 11:52 AM Thread Starter
1-877-MOD-POWR
