For Sale (TX) Trickflow 38cc 2V Heads - $1600, MM900 + Upgrades - $1700 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 02-12-2013, 10:27 AM Thread Starter
JKolbfleisch's Avatar
I was up in the air about keeping my engine to throw into a new project but decided to unload it:
MMR900 w/ following: (SALE PENDING LOCALLY!)
•Standard Bore -18cc Dish Pistons (Stock Compression) + Cast Iron Block
•Forged 8 Bolt Crankshaft (I will include flywheel if u need)
•Manley 594200 Pistons
•Teflon Treated Piston Dish ($250 Upgrade!)
•ARP Mainstuds ($150 Upgrade)
•ARP2000 Rod Bolts on 4340 H-Beam Rods ($90 Upgrade)
•Racing Sidebolt Kit ($40 upgrade)
•Cryotreated MMR Oil Pump ($160 upgrade)
•About 10,000 miles on the engine. I ran it with a number of different setups including a 520whp procharger setup for about a year and a 650whp Turbo setup for another year. I drove it to work all the time and no issues. I pulled a rod and crankshaft cap last night just to check on bearings and they look great.
TrickFlow Twisted Wedge 38cc 2V Cylinder Heads
•OUTFLOW 4V Termi heads out of the box!!
•Reposition the Valves so you can run big cams w/o flycut pistons
•Combustion Chamber design allows more timing under boost or N/A
•Made 650whp on only 14psi of boost and stock cams thanks to these heads!
•Will raise your stock compression block to about 10:1
•For more info click HERE!
•About 10,000 miles on the above block. About 1,000 miles ago I blew a head gasket due to some detonation from my crank signal wire rubbing bare on a pulley @ the track. Removed both heads and the passenger side had some damage where the detonation had burned through some aluminum. Took both heads to Garvin's Machine shop in Killeen, TX where they repaired the head and resurfaced both. They also inspected them and nothing was needed as the guy said they looked brand new. Put back on and have been running flwalessly for last 1,000 miles.
* Rockers and Lash adjusters are in a ziploc bag but I will include them with heads if you need them!
I also still have the TrickFlow Intake Manifold for $500 in another listing but a number of people locally want it next payday. First come first serve though.
Shipping might be a expensive. I am NOT including shipping in these prices and they are so low I'm not very flexible. I will weigh items and give dimensions. We can look together to find best/cheapest shipping option.
PM me or call/text me @ 801-735-4078 with questions.
Factory Five 1965 AC Cobra 427SC Replica (In Progress ... )
2001 Mustang GT - [645WHP, 652TQ][MMR900 + Trick Flow Heads + Intake][ON3 Turbo @ 14psi]
2007 Jeep Grand Cherokee HEMI, 2006 Infiniti G35, 2012 Honda CRV EXL [The Daily Drivers!]
JKolbfleisch is offline
post #2 of 8 Old 02-12-2013, 12:20 PM
I am interested in the heads. Please email me some more info on the "repair" and any and all pics you may have please to cridgell@yahoo.com
bulldog5.0 is offline
post #3 of 8 Old 02-12-2013, 08:11 PM Thread Starter
Block no longer for sale.
post #4 of 8 Old 02-18-2013, 10:17 PM Thread Starter
Updated pics in original post.
post #5 of 8 Old 03-03-2013, 04:51 PM
Is the trickflow intake still for sale?
SlowStang08 is offline
post #6 of 8 Old 03-05-2013, 07:28 PM
Trader Feedback: (58)
were the heads warped at all? do you have bill for the head work? not to be pushy but i've seen issues with "repaired" heads that were warped, snapping cams in half and such.
bullitt15 is offline
post #7 of 8 Old 03-10-2013, 07:00 PM
PM me bottom dollar for the heads shipped to 60543 also if interested in partial trade of hellion single turbo kit.
slow 2000 gt is offline
post #8 of 8 Old 03-29-2013, 09:04 PM
everything is sold?
