Project Discreet - Ford Mustang Forums : Corral.net Mustang Forum
 2Likes
post #1 of 43 Old 01-16-2017, 03:34 PM Thread Starter
Project Discreet
Back in 2012, I bough a new Mustang. My only requirement was that it was white. Unfortunately, the 2013's were already on the lot (I didn't want a '13), so that left me with a vast array of V6/automatics to choose from.
In August of 2014, I performed major surgery on the car, and swapped out the V6/auto for a carbureted 427 Windsor and Tremec Magnum XL. It was one of five Mustangs in the world built that way, and one of only two that are driven on the street (the others were purpose-built race cars). It is, without a doubt, one of the most heavily modified street-driven S197 Mustangs in the world. In fact, the only things that are still OEM are the radiator, the fuel tank, and the rear-end housing.
This coming weekend (Jan 21), I will be embarking on what I call "Project Discreet" - adding a 671 blower with dual quad carbs to the car. Since this is the introductory post, I'll include some pics of the car during the engine swap. And FYI, the swap itself took just 28 calendar days from driving the car in, to driving the car out.
jsimmonstx is offline
post #2 of 43 Old 01-16-2017, 03:36 PM Thread Starter
More pics for initial build
post #3 of 43 Old 01-16-2017, 03:42 PM Thread Starter
More pics.
I used a Treme Magnum XL kit, but had to toss the bellhousing that came with it because it wouldn't bolt up to the Windsor block. I knew this would be the case so it wasn't a surprise, and I got a Quicktime scattershield, and had to have an aluminum spacer made to fit between the scattershield and the transmission so that the input shaft wouldn't bottom out in the crank. That's what the next-to-last picture is of.
We also had to relocate and fab a new bracket for the expansion tank because the tensioner pulley on the alternator bracket was in the way.
post #4 of 43 Old 01-16-2017, 03:44 PM Thread Starter
To accommodate the absence of the drive-by-wire harness, We adapted a fox body gas pedal to the car and used an OEM throttle cable. To get the pedal mounted, we made an aluminum adapter plate and simply bolted the pedal to it. All we had to do was drill a hole for the cable.
post #5 of 43 Old 01-16-2017, 03:46 PM Thread Starter
Finally, we wanted the OEM tach to work, so we installed a crank reluctor wheel from an explorer between the harmonic balancer and crank pulley, and used the OEM crank position sensor to drive the tach.
post #6 of 43 Old 01-16-2017, 03:47 PM Thread Starter
The car, as it sits right now, looks like this. It's come a long way from its V6/auto roots.
post #7 of 43 Old 01-16-2017, 03:52 PM Thread Starter
At this moment, the car is being prepped to add the blower. I took off the front bumper fascia, removed the OEM radiator fan and radiator, and disconnected most of the stuff that would keep us from removing the intake.
I also too this opportunity to remove all of the A/C stuff, which required a bracket change for the power steering, so I got a March alternator bracket kit, and March power steering bracket kit.
A word of advice regarding brackets - be VERY careful about what you order. Brackets for a v-belt system come with different bolts/spacers. The brackets will be okay, but the bolts/spacers will NOT be okay. On the power steering side, make sure you order the bracket for the appropriate power steering pump.
post #8 of 43 Old 01-16-2017, 03:54 PM Thread Starter
Since I removed the A/C lines, I was left with two holes in the firewall, so I fabbed up a little cover out of aluminum and installed it.
At this time, I have all the parts I think I'm going to need to install the blower - except the blower itself, which shipped today (I'll have it by Jan 19).
post #9 of 43 Old 01-16-2017, 03:57 PM Thread Starter
I'm getting the blower from Dyer's Blowers. IMHO, if you get a blower from ANYPLACE else, you're doing it wrong. These are the only guys I could find that supports the serpentine belt system that you see in the fox body mustangs. They are VERY accommodating, and will answer any stupid question you have. They sent me pics today of my blower kit mocked up before they packed it up for shipping.
post #10 of 43 Old 01-16-2017, 03:58 PM Thread Starter
More mockup pics.
post #11 of 43 Old 01-16-2017, 08:39 PM
sanchezj360's Avatar
Trader Feedback: (22)
Damn I still haven't seen the car in person. I passed by Chris's shop while it was in there but never saw it run. Good luck with it. Are you gonna put it on the dyno?
1993 Ford Mustang Lx-turbo stolen feb 22nd 2017
Vin 1FACP41E2PF165961
1994 Ford Lightning- Sold
1990 Ford Mustang Lx- needs a heart transplant.
sanchezj360 is offline
post #12 of 43 Old 01-17-2017, 04:11 AM Thread Starter
If I know Chris, yeah, probably.
post #13 of 43 Old 01-17-2017, 09:04 AM
This a houston build or San Antonio?
5.0thunder is online now
post #14 of 43 Old 01-17-2017, 09:53 AM Thread Starter
San Antonio.
5.0thunder likes this.
post #15 of 43 Old 01-19-2017, 12:54 AM
Trader Feedback: (26)
do you know what it weighs with 427?
dragking is offline
post #16 of 43 Old 01-19-2017, 11:21 AM Thread Starter
I weighed the car (it has a 100 pound roll bar, fiberglass fixed back seats, and a heavy fiberglass hood). The final weight was 3650 pounds, which is just 50 pounds heavier than a fully loaded 2012 GT premium.
post #17 of 43 Old 01-20-2017, 08:47 AM Thread Starter
I got the blower last night (the UPS guy was really struggling to get the boxes off the truck). I'm only going to un-box some of it so I can reinstall the harmonic balancer and crank pulleys.
post #18 of 43 Old 01-20-2017, 12:03 PM
Should check for damage on the parts. Ups always ####s my #### up.
post #19 of 43 Old 01-20-2017, 01:27 PM Thread Starter
The boxes arrived puncture free, and the flanges are all still flat. Dyer's packed everything really well.
post #20 of 43 Old 01-20-2017, 01:29 PM Thread Starter
While I'm waiting for a slot to open at the shop that's going to install this thing, and to inspect the parts to make sure there's no shipping damage, I decided to mock it up for pics.
post #21 of 43 Old 01-21-2017, 09:38 AM
Trader Feedback: (21)
That's sexy! Can't wait to see it peeking out from the hood....oh hell, it will be screaming LOOK AT ME! Awesome stuff!
And you're lucky. UPS (United Package Smashers) and FedEx can break an anvil packed in cement.
droopie is offline
post #22 of 43 Old 01-24-2017, 05:23 PM Thread Starter
Testing fitment. The back was my biggest concern, but we're looking good...
post #23 of 43 Old 01-24-2017, 10:42 PM
Sweet! Let me know when you take it out would like to see it in person. Also sending you a pm.
post #24 of 43 Old 01-25-2017, 02:56 AM Thread Starter
I'm gonna try to have it ready by the 2nd weekend in February.
post #25 of 43 Old 02-02-2017, 09:54 AM Thread Starter
Finally at the shop that's doing the install. It's gonna whine more than an ex-wife trying to get her alimony increased.
post #26 of 43 Old 02-02-2017, 07:17 PM
71stpsde's Avatar
That's a huge bitch!
1985 Mustang GT - 42k original miles
71stpsde is offline
post #27 of 43 Old 02-04-2017, 06:45 AM Thread Starter
End of day two at the shop. Blower installed, fuel system connected, cooling system connected, Spal fans mounted, and linkage has been started. Still have to connect the fans, mount/connect the valve cover breather tank, and clean up some electrical routing. We expect to start the car sometime today.
post #28 of 43 Old 02-04-2017, 07:22 PM
Very cool project. I had thoughts of trying to switch my '11 GT to a 408W, but didnt have the funds. Cool to see someone who did it.
HawkeyeGT is offline
post #29 of 43 Old 02-04-2017, 07:42 PM Thread Starter
BLOWAAAAH!
HawkeyeGT likes this.
post #30 of 43 Old 02-11-2017, 09:42 AM
Sounds nice any more videos?
post #31 of 43 Old 02-12-2017, 10:44 AM
rms8's Avatar
Looks awesome!!!
rms8 is offline
post #32 of 43 Old 02-12-2017, 03:55 PM Thread Starter
cars and coffee today
post #33 of 43 Old 02-13-2017, 05:08 PM
sweet
s197turbo is offline
post #34 of 43 Old 02-13-2017, 07:35 PM
Are you going to use the stock hood with a giant hole then?
post #35 of 43 Old 02-13-2017, 11:05 PM
Was this car at Cars and Coffee this weekend in Austin?
Grimey is offline
