Project Discreet - Page 2 - Ford Mustang Forums : Corral.net Mustang Forum
 2Likes
post #36 of 42 Old 02-14-2017, 06:52 AM Thread Starter
Ooop, just figured out how to use multi-quote.
jsimmonstx is offline
post #37 of 42 Old 02-14-2017, 06:53 AM Thread Starter
Originally Posted by HawkeyeGT View Post
Are you going to use the stock hood with a giant hole then?
I have a Cervini 2-inch cowl, but yeah, giant hole. I'm going to start measuring today.
Originally Posted by Grimey View Post
Was this car at Cars and Coffee this weekend in Austin?
Yeah, that's what the picture is from.
post #38 of 42 Old 02-17-2017, 09:11 AM
Cool stuff man! Did the shop tune the carbs or are you good with them?
5.0thunder is online now
post #39 of 42 Old 02-17-2017, 10:26 AM Thread Starter
It had a monster lean tip-in condition, so I tore the carbs apart (to see what was in 'em), and bumped all the jest up two sizes. The lean tip in is gone, but now it runs kinda rich all the time. I think I'm gonna try bumping the primary air bleeds up one size and the secondaries down one size, and see what happens.
In the mean time, it runs really well.
post #40 of 42 Old 02-17-2017, 10:39 AM
ought to get a wideband in the exhaust to make sure you're getting the right ratios. I thought usually lean tip-in was remedied with accelerator pump adjustments but not real sure. I always sucked with carbs and just tune standalone ECU's instead. lol
post #41 of 42 Old 02-17-2017, 01:52 PM Thread Starter
Well, there are a lot of remedies for lean tip-in: power values (mine are plugs, so no worries), jets, and air bleeds. There are additional things to check for double pumpers.
I have an air/fuel gauge in the car. It idles at 9-10, and runs (part throttle) at 10-12. I'd like it to be a bit leaner, but you gotta be careful with the older roots blowers. It's better to run rich than lean.
post #42 of 42 Old 02-17-2017, 02:00 PM
I'm in the same boat with roots tuning a sbf. lol
I shoot for 13-13.3 at idle and stoich during cruise. it seems to be okay with these settings so far. I tuned in an afterstart and warmup enrichment to give it more fuel until the engine warms up, as well as an IAC valve to supply air during warmup. This is what I was talking about with carb tuning driving me into EFI. Lol
I also have acceleration enrichment that injects more fuel based on TPS opening Rate, so the faster you stomp the throttle, the more burst it supplies. Allows for great tip-in response.
