91 lx: cleaning up the engine bay - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 24 Old 02-14-2012, 03:14 AM Thread Starter
i got a 91 lx 2 thanksgivings ago
as far as i know this is whats on it
3.73 gears
bbk headers
off road hpipe
flowmaster 40series
ac delete
smog delete
bbk cai
msd coil
lakewood control arms
lakewood sfc
world class t-5
firewall adj and quadrant
powdercoated pony rims
clear 3 peice headlights
udgraded fuel pump of some kind
lowed 1 inch all around
hurst short shifter
new weather striping
gt40 heads
gt40 intake
started about 3 weeks ago and im putting some gt40 heads and intake on the 302
ive been a member over on moddedmustangs for about a year and a half and i thought id join this forum too
heres my car
heres before i did anything
and work in progress
where im currently at
ill post up more as i go
Brandon444 is offline
post #2 of 24 Old 02-16-2012, 03:19 AM Thread Starter
got the injectors and fuel rails swapped over, also got the valve springs from alexparts.com put on
post #3 of 24 Old 02-18-2012, 02:48 AM Thread Starter
post #4 of 24 Old 02-18-2012, 04:04 AM
Wicked03GT's Avatar
Trader Feedback: (49)
Dont think I have ever seen a painted distributor...
Wicked03GT is offline
post #5 of 24 Old 02-18-2012, 04:53 PM
^^^ Nor have I.
Still, Looks good
-Nick
2001 CVPI
NGreen0807 is offline
post #6 of 24 Old 02-18-2012, 05:06 PM
NastyNotch306's Avatar
Welcome aboard! nice job on the smoothing of the engine bay.
NastyNotch306 is offline
post #7 of 24 Old 02-18-2012, 11:55 PM Thread Starter
thanks guys and yea i painted the distributor, it just wouldnt clean up enough
i also got the engine in tonight
post #8 of 24 Old 02-19-2012, 03:16 PM Thread Starter
polished valve cover
post #9 of 24 Old 02-20-2012, 02:15 AM Thread Starter
post #10 of 24 Old 02-20-2012, 07:51 PM
that looks really clean!!! good job
NotchLS1 is offline
post #11 of 24 Old 02-20-2012, 10:13 PM
looks real good bro good luck
julio816 is offline
post #12 of 24 Old 02-21-2012, 12:10 AM
nICE JOB MAN..
ERICS3000 is offline
post #13 of 24 Old 02-21-2012, 12:16 AM
Looks Great! That dist. is worth and easy 5hp painted! lol
racerxmdd is offline
post #14 of 24 Old 02-21-2012, 02:10 AM Thread Starter
i only needed 5 extra horse lol i just wanted some blue from the block more visible when its all put back together
post #15 of 24 Old 02-21-2012, 02:21 AM Thread Starter
post #16 of 24 Old 02-21-2012, 02:43 AM
teddyzee's Avatar
Did you forget to tap the intake runner?
Looks good.
'97 Mustang GT 5spd
'97 Ranger 5.0 H.O EFI T5
teddyzee is offline
post #17 of 24 Old 02-21-2012, 04:05 AM Thread Starter
for the act sensor? im putting it on the upper intake
post #18 of 24 Old 02-21-2012, 03:54 PM
teddyzee's Avatar
Just checking!
'97 Mustang GT 5spd
teddyzee is offline
post #19 of 24 Old 02-22-2012, 01:44 AM Thread Starter
still a few more things to do
any suggestions on where to mount the coil?
post #20 of 24 Old 02-22-2012, 08:56 AM
Looks good...and really clean. What about making a bracket and mount it to the top of the ps bracket? wires would be close or in a bundle that is already there. You wouldn't have to drape it over the non cluttered place you cleaned up.
again, looks great!!
maury is offline
post #21 of 24 Old 02-24-2012, 03:13 AM Thread Starter
i put the coil on the firewall so you cant see it to well and its hidden
and the act sensor
post #22 of 24 Old 02-24-2012, 03:28 AM
Hey, the bay looks good. Will be starting mine in the spring. What did you use for the welded seems on the apron panels. How were they prepped? Did you grind down the welds and seam sealer them? Cover all the bases for my go at it.
88lx Conv. 200K mile stock longblock. Trickflow intake, 42lb inj, Pmas protube,TKO500, 3:27, pypes muffs, Pa Racing tubluar K-member, DIY single turbo setup. Summit aluminum rad, Crane Hi-fire ign, subfames, 17" sc saleen's, Saleen ground effects, SCT tune by Dynosport. 380HP 435ftbs.
71swing is offline
post #23 of 24 Old 02-25-2012, 02:26 AM Thread Starter
its a lot of work man but its worth it, i welded them in then used body filler to smooth it out
post #24 of 24 Old 02-28-2012, 11:34 PM
looks great!
Bs895.0 is offline
