Anyone deal with Bestone Tire? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Non-Tech Forums > Lounge
Old 06-30-2012, 07:31 AM   #1
Bossnine's Avatar
I took my car in to have the AC serviced. The technician informed me that they found no faults with the system but coulndt explain why it wasnt blowing cold. It had no leaks and was showing correct pressures. He explained I could bring it back if I wasnt happy with the temp it was blowing after picking it back up as I did overcharge it before I took it in.
I did some research and found that others with a Ford 500 had the same issue and I found the problem to be a bad, replaceable, valve in the compressor. I purchased the valve but needed the system drained in order to install it.......so I took it back to them to see if they would drain and install the valve and refill, for a fee of course. After they looked at the car AGAIN they told me the AC compressor was leaking badly and thats what was wrong and it needed a new one. For a hefty price of course.
I took the car home and put the valve in myself and charged it with my gauges, something I didnt want to do initially as my time is limited. Amazingly after several weeks it is still blowing cold as ice and no problems.
Tisk Tisk
__________________
Matt
Bossnine is offline
You may not post new threads
You may not post replies
HTML code is On
© 2010-2011 Corral.net
