Powerblock Horsepower New Project '97 TBird - Page 3 - Ford Mustang Forums : Corral.net Mustang Forum
post #71 of 80 Old 05-28-2011, 11:15 PM
I like my carbed windsor, I guess it just brings out the backwoods redneck in me
red73fastback is offline
post #72 of 80 Old 05-30-2011, 02:26 PM
Shakerhood's Avatar
Originally Posted by LilRed86 View Post
They just dynoed the 427w, made 610hp,580+ torque.The cam they are running sounds streetable. Plus running 10.1 and 93 pump gas sounds very streetable to me.
That Engine sounded real mean too, I think they said it uses the Ford Racing Boss Block.
Shakerhood is offline
post #73 of 80 Old 05-31-2011, 08:01 AM
SATURN5's Avatar
Cool. Still doesn't change the fact it will not fit under the stock hood, killing the sleeper point of the build.
84 SVO Folvo, 03 Cobra suspension, steering, brakes, IRS
68 F100 Flareside, DOHC, M122, T45, CV IFS, Cobra IRS, 4.10s
96 Mark VIII, RPE chassis bracing, hub swapped
SATURN5 is offline
post #74 of 80 Old 05-31-2011, 08:23 PM
This is me Stan
kingcars's Avatar
Sleeper MN12 Tbird? Yeah could've been a really cool mod build. But for a windsor project, I don't understand why they wouldn't just use a fox Tbird instead. Guy on a forum I go do is building an 88 Tbird with a turbo'd EFI 5.0....a much cooler project imo. But I suppose I may be biased
1988 Thunderbird 5.0L | 240rwhp - 300rwtq
306ci, GT40 intake, 65mm TB, GT40Y heads, T5 swap, 8.8 disc rear w/3.55s, 11" front brakes, MM front & rear control arms, front coil overs, Koni yellows
Retired DD - '88 Tbird Turbo Coupe - 99.9% stock
Current DD - 2015 VW GTI SE 6spd manual
kingcars is offline
post #75 of 80 Old 06-01-2011, 02:43 PM
BradleyRJ's Avatar
Trader Feedback: (25)
I dont see the problem with a carbed windsor setup. I think Bruce's car makes good power.
393 Thunderbird Under Construction
He's a member here, 393bird. I rode in the car before the Ysi and it made my nutts tingle. I cant imagine how it runs now.
They say what goes up must come down but I ain't reached my cruising altitude.
Take a look at what I did but can you imagine what I'm about to do.
BradleyRJ is offline
post #76 of 80 Old 06-01-2011, 03:21 PM
SATURN5's Avatar
Nice ride. It also shows, there isn't anyway to get it under a stock hood.
SATURN5 is offline
post #77 of 80 Old 06-01-2011, 06:15 PM
P63
Moderator
P63's Avatar
Originally Posted by CamFox View Post
I was interested until I saw that junky pushrod they are putting in it.
Your life must be awesome if you consider a 427 to be a "junky pushrod".
Victor Marshall
Copyright 2017.
P63 is offline
post #78 of 80 Old 06-04-2011, 11:27 AM Thread Starter
They put the engine in the car and had to hack up the oil pan to clear the K member. Didn't show the car with the hood on after.
Fast forwarded thru to Musclecars and saw what they had to do for a hood. Rick Bacon fitted a fiberglass cowl hood. It would have been OK if it didn't have the 2 stupid looking inlets on it.
David
DaHowie is offline
post #79 of 80 Old 06-04-2011, 12:54 PM
That hood is pretty ugly.
2002 GT 4V swapped
2008 G8 GT Stock
CamFox is offline
post #80 of 80 Old 06-04-2011, 06:38 PM
LostPony's Avatar
I don't think Rick Bacon was all that impressed with that crappy hood either, notice the lack of product endorsement when he had to re-work the ugly POS to fit the car.
I also think they are going to be replacing one of the hosts this next season since they just introduced the new "tech" on this project. My feeling is it's the old guy. I can't remember their names, the only ones I like are Rick and Tommy from Musclecars.
'12 Boss 302 Kona blue #2758
LostPony is offline
HTML code is On
