does undercoating stop rust? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 24 Old 10-28-2010, 04:01 PM Thread Starter
stang3O2's Avatar
My dad just bought a used truck '01 ranger that has some rust on the underside and a small area on the bottom of the door. Will undercoating stop it from going any farther, or is there something you know about that will stop it?
thanks
stang3O2 is offline
post #2 of 24 Old 10-28-2010, 04:06 PM
Corral Charter Member
mmeans's Avatar
It will slow it down, rust never sleeps. POR 15 may be better, or Naval Jelly first then zinc oxide primer followed by paint then undercoating.
Michael Means
bot mm9000
mmeans is offline
post #3 of 24 Old 10-28-2010, 05:18 PM
tims88's Avatar
Once the rust has settled into the body seams the only option is an oil spray. Undercoating over rust will make it worse.
Tim
[SIGPIC][/SIGPIC]
tims88 is offline
post #4 of 24 Old 10-28-2010, 06:16 PM
188slo50's Avatar
Undercoating isnt worth a crap except to reduce road noise. Por 15 is your best bet for a protectant, there are other brands out there as well if you want something different.
1988 GT- 306, AFR 165 , Peformer II, 4.10's, MAF conversion, 93 Cobra brakes, 315's, etc...
1999 GT 2v A/T.....4.10's, Cobra brakes,H&R, 315's.....SOLD
188slo50 is offline
post #5 of 24 Old 10-28-2010, 06:29 PM
Moderator
eleanorfox's Avatar
Trader Feedback: (57)
Undercoating is a crock of ####.
Every vehicle that I have seen with "undercoating" and "rust prevention" are all rusted to ####.
Usually all that stuff does is trap the moisture and MAKE rust.
2001 Mustang GT Bullitt (terminated) #2793
2015 GMC Sierra 1500 4x4
2015 Chrysler 300 S
eleanorfox is offline
post #6 of 24 Old 10-28-2010, 06:29 PM
shame302's Avatar
Michael Means
+1. It has to be coated from the get-go to pe particularly effective. I had an 87 Tbird that was Rusty Jonesed and that chit was rust free.
shame302 is offline
post #7 of 24 Old 10-28-2010, 06:33 PM
Captain Chaos
Chauncy's Avatar
The analogy that comes to mind is putting Sunblock on a sunburn.
Canary - Yellow 1995 GTS - Adam - Gamertag: Naldaen
"It's hard to be religious when certain people are never incinerated by bolts of lightning."
— Calvin
Chauncy is offline
post #8 of 24 Old 10-28-2010, 06:39 PM
KPSVO's Avatar
There are rust converters like Eastwood's sells:
http://www.eastwood.com/rust-solutio...converter.html
KPSVO is offline
post #9 of 24 Old 10-28-2010, 06:41 PM
mmeans's Avatar
I had a line truck out of PA. It had 250K on it when I bought it and it was treated for rust, Rusty-Jones competitor, Zeibart. It still had a great body at 400K when the 400M gave up.
Michael Means
bot mm9000
mmeans is offline
post #10 of 24 Old 10-28-2010, 07:00 PM
Bossnine's Avatar
I use a product called Rust-Mort that converts the rust, then I POR15 if its a frame, or prime and paint if its a body panel.
Matt
Bossnine is offline
post #11 of 24 Old 10-28-2010, 07:54 PM
SinisterSnake's Avatar
This. My 63 Nova is rotted, it has undercoat on it.
Mike
13 Jeep Wrangler Unlimited , 03 HD Road King, 03 F250 PSD, 97 Cobra, 82 GT, 65 Mustang.
Xbox 360 - SinisterSnake97
Originally Posted by Craig. View Post
More elite than Ralph is now. Put THAT in your sig.
SinisterSnake is offline
post #12 of 24 Old 10-28-2010, 08:06 PM
The oil spray type products work the best imo.
My 89 would have likely become a rust bucket years ago without it and I haven't oil sprayed it for several years now and it's always winter driven in Canada.
The underside is black from all the previous applications.
No sign of rust that I can see.
Heres a Canadian company that's one of the best out there.
http://www.krown.com/#default
8950HO is offline
post #13 of 24 Old 10-28-2010, 08:41 PM
Gary L's Avatar
What the Canadian guys said.
Oil spray is the best, but you won't get that on this side of the border.
Undercoating works if done properly before the vehicle has seen any road duty or gotten wet. Most undercoatings will harden and crack after a while, making them virtually worthless after that.
Once the rust has started, POR15.
Isaiah 26:10 Though grace is shown to the wicked, they do not learn righteousness; even in a land of uprightness they go on doing evil and regard not the majesty of the Lord.
Gary L is offline
post #14 of 24 Old 10-28-2010, 09:21 PM
tims88's Avatar
Tranny fluid cut with WD-40 works just as well. Use a pump style garden sprayer with a wand to get into the door panels. It does smell for a while though. The stuff the commercial guys use doesn't smell at all.
Don't spray it on the exhaust.
Tim
[SIGPIC][/SIGPIC]
tims88 is offline
post #15 of 24 Old 10-28-2010, 09:24 PM
GTmustang00's Avatar
I use bar and chain oil mixed with clear coat. Looks great when done.
98 Chrome Yellow cobra 9800 miles
1989 Mustang GT, modified to hell
GTmustang00 is offline
post #16 of 24 Old 10-28-2010, 11:06 PM
Ray III's Avatar
When using an undercoat make sure the stuff contains asphalt.
this post property of RAYMOND
Ray III is offline
post #17 of 24 Old 10-29-2010, 12:18 AM
undercoat only works to prevent rust if the area sprayed has no rust to begin with. Undercoat over rust makes it worse. Rust needs oxygen to oxidize, so the key to products like por-15 is that they dont let air in...
snkmug is offline
post #18 of 24 Old 11-08-2010, 04:36 PM
Buck268's Avatar
POR15 is actually supposed to adhere better if you leave the (not loose) rust in place. I did their 3-step process to a machete which I routinely use during the summer months at my folks' cabin for gathering firewood and its held up extremely well over the course of about 5 years. Literally the only place where the POR15 has come off is where I have used a bastard file (right along the edge) to sharpen it a couple times!
2011 F150 5.0L 4x4
1996 Mustang GT 5spd - PI Cams and intake, Bassani OR X pipe, Dynomax Ultraflow mufflers, C&L plenum with 75mm TB, K&N FIPK, Hella FF75 foglamps, Cobra "Terminator" convertible top.
Buck268 is offline
post #19 of 24 Old 11-09-2010, 12:21 AM
Gary L's Avatar
Tranny fluid ....
Reminds me of when I lived in Ont. One of the guys I worked with told me about a job he had in college, it was an electronics service/tech/repair job in Toronto. They had an old van with a big V8 in it that he never drove, except for one time when the one he usually drove was in the shop. His boss told him "just ignore the people waving at you, get a lot of that with this van". He did too. Said he came to a stop light, and someone yelled "your van is on fire". Turns out the tranny had a pretty good leak, and it would drip onto one of the cats and there would be very visible flames. He was really pissed at his boss for not telling him about that when he got back.
Gary L is offline
post #20 of 24 Old 11-09-2010, 12:33 AM
ben5.0's Avatar
Trader Feedback: (38)
Undercoating = Rust promoter
ben5.0 is offline
post #21 of 24 Old 11-09-2010, 12:42 AM
Blame Canada!!!!!! I FAP for CANADA!
fapperDan's Avatar
Trader Feedback: (44)
I would die laughing!
Banned!!!!!!!!!!!!!!!!
Canada loves me this I know, Cause the "Don" tells me so! Tumbleweeds we sell all day long, Ghost towns are coming so stay strong!
fapperDan is offline
post #22 of 24 Old 11-09-2010, 08:53 AM
Yeah^^^
Non Elite Member #1
1990 SSP
Joe T is offline
post #23 of 24 Old 11-09-2010, 09:43 AM
jevchance's Avatar
POR-15.
about.me/jevchance
myrestoproject.com - coming soon!
1966 Mustang Coupe
jevchance is offline
post #24 of 24 Old 11-09-2010, 09:52 AM
Gary L's Avatar
It was good humor. There was actually a bit more to the story, like the leak varied with speed, and keeping the van over 60 or 70 on the freeway because it was fast enough to keep the flames from doing any serious damage. But I don't recall all the details now. It was 20 years ago that I worked with him.
Same guy had a strategy for dates. Don't recall the exact amount anymore, but somewhere north of $75-125 spent on the night would guarantee getting laid. I think the price on Younge St. was a bit less at the time, but to each their own.
Gary L is offline
HTML code is On
