are torpedo heaters safe for garage use?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 53 Old 12-19-2009, 11:00 AM Thread Starter
are torpedo heaters safe in a garage??
thanks
89llx is offline
post #2 of 53 Old 12-19-2009, 11:02 AM
87blacklx's Avatar
When I was working construction we would set up one near the door and keep it slightly opened so the garage would vent. Don't know how necesary that was but better safe then sorry. Did a hell of a job keeping it toasty in there.
You tell me that I sin. You say I'm bound for hell. So once your judgement condemns you... I SHALL SEE YOU THERE
Proudly supporting gay marriage as long as both chicks are hot.
87blacklx is offline
post #3 of 53 Old 12-19-2009, 11:28 AM
wayne94mustang's Avatar
That's all i use, the newer ones are far cleaner then the older ones.
94 gt auto becontrolls.com stand alone tranny computer,3000 stall,trannsgo shift kit,3.90s,31 moser axles, qa1 k-member,kb frame ties,mega bite lowers,comp extreme 270-276 dur .544 lift,#24 injecters,pro-m bullit meter,mac cai,pih kit,and all the little bolt ons
wayne94mustang is offline
post #4 of 53 Old 12-19-2009, 11:34 AM
SATURN5's Avatar
I crack both doors with mine. It pulls fresh air in one, and I point it toward the other on the far side of the garage...
However, mine needs a rebuild kit... After 23 years, it's having issues staying fired. Needs a new nozzle and fuel/air filter kit.
84 SVO Folvo, 03 Cobra suspension, steering, brakes, IRS
68 F100 Flareside, DOHC, M122, T45, CV IFS, Cobra IRS, 4.10s
96 Mark VIII, RPE chassis bracing, hub swapped
SATURN5 is offline
post #5 of 53 Old 12-19-2009, 12:01 PM
heater
I was always told that it depends on the fuel that was used. If you burn diesel then you would want some ventilation, but if you used kerosene then it wasn't that important. I was under the impression that these two fuels weren't that different in composition. Maybe they are.
My shop is 30'x40' and I can heat mine to 70 deg. from about 40 deg. in 15 minutes and won't have to use it again for 2 hours. I burn diesel in mine. I think it's 150,000 BTU.
89 Black 5 sp Coupe w/70k driver
03 DSG Cobra w/mods 476/501
Jason Myers is offline
post #6 of 53 Old 12-19-2009, 12:46 PM
Canker's Avatar
I burn diesel and barely smell anything when running mine. I don't crack a door or anything but my garage isn't the best sealed building anyway.
95 Mazda Miata
04 VW Jetta Wagon TDI
Canker is offline
post #7 of 53 Old 12-19-2009, 12:48 PM
fine for garage use.
Making people go "hmmmm" one post at a time.
sc302 is offline
post #8 of 53 Old 12-19-2009, 12:49 PM
after about an hours use the fumes from the spent kerosene starts to irritate my eyes. i would be interested to see how well the new ones work (propane) but they are a little spendy.
Purchasing a vehicle out of state and need someone to go get it for you? I'm your man!!!
91terry85 is offline
post #9 of 53 Old 12-19-2009, 01:12 PM
TimP's Avatar
Trader Feedback: (89)
I use my 60,000 btu unit hooked into a digital thermostat to keep the garage @ 50 all winter. I run clear kero in it, and have not had a problem so far. my garage is 22x22 and is insulated... so yes, I believe they are safe for indoor use.
Electric Currant Red 93 LX Hatch: July 98 MM&FF Feature Car, 9.39 @ 144.
Dark Grey Metallic 87 LX Notch: gears, exhaust, shift kit.
TimP is offline
post #10 of 53 Old 12-19-2009, 01:26 PM
87blacklx's Avatar
I get what you are saying, but I don't want people to read this and get the wrong idea. Some times it is the stuff you can not smell that gets you the worse. However, as others have said it is all in the fuel you use. I would recommend doing a little research on the fuel of choice before you decide whether or not to vent. When in doubt I would vent just to be safe. J
post #11 of 53 Old 12-19-2009, 01:33 PM
Corral Charter Member
Cobra Jet NJ's Avatar
Trader Feedback: (40)
I use a Reddy Heater which is very similar to this new one found at Home Depot:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
It's uses propane heat and I've never had an issue w/ odors, fumes or any other problems using it in an enclosed space, such as a 2 car garage... It burns really clean and it will definitely get you warm - warm enough that you may have to shut it off for a couple of hours. Just use your BBQ proane tank if you have one... if not, you can buy the propane at HD or Lowes too.
- Phil
1994 Cobra coupe SVT #0013, 2016 Mustang Fastback Premium EB/PP
Cobra Jet NJ is offline
post #12 of 53 Old 12-19-2009, 03:20 PM
jandmmustangs's Avatar
Trader Feedback: (64)
I use a Dayton 180,000 BTU unit, burning ORD. It gets the garage up to about 90 degrees in 30 minutes and stays warm in there for about 3 hours. Keep in mind this is a well insulated oversized 2 car (3 cars fit easily with tons of room to work). I'd only get concerned if you start getting headaches or feeling groggy in the garage.
1993 LX 331 5spd. The usual stuff.
jandmmustangs is offline
post #13 of 53 Old 12-19-2009, 03:29 PM
TimP's Avatar
my local gas station ran outta kero, so I used diesel in a pinch, once... good lord, that was horrible.
TimP is offline
post #14 of 53 Old 12-19-2009, 04:19 PM
U.S. Army Active Duty
NIUPonyBoy's Avatar
They melt ACU's if you are infront of one too long. lol
They are as safe as any other if you keep stuff away from them that shouldn't be there and the off gases away.
Annoy a Liberal: Work Hard and Be Happy.
A vote for a Demoncrat is a vote for terror.
Outback, Vulcan, Mustang, Impreza, Power Wagon, Freestar
"Si vis pacem, para bellum."
NIUPonyBoy is offline
post #15 of 53 Old 12-19-2009, 04:28 PM
tims88's Avatar
It is absolutely NOT safe to work in an enclosed space with these heaters. It will cause permanent brain damage from repeated exposure. People die from this every year.
Tim
[SIGPIC][/SIGPIC]
tims88 is offline
post #16 of 53 Old 12-19-2009, 05:11 PM
94cobra2615's Avatar
Carbon monoxide is what you have to be careful with........the gas produced when fuels are burned.
94cobra2615 is offline
post #17 of 53 Old 12-19-2009, 07:31 PM
Ray III's Avatar
They are similar. Diesel is more energy dense and harder to burn completely. Kerosene works in the same places diesel will if you need a cleaner burn or to have an easier time running an engine in cold weather.
this post property of RAYMOND
Ray III is offline
post #18 of 53 Old 12-19-2009, 07:36 PM
Fast Horse's Avatar
I don't know about any dain bramage but I get that tired feeling after several hours of running mine/working in the garage.
Fast Horse is offline
post #19 of 53 Old 12-19-2009, 08:22 PM
SATURN5's Avatar
I'm thinking of just replacing mine since it needs about $75 in parts... The only thing is a buddy has 20 gallons of Jet A for me.
SATURN5 is offline
post #20 of 53 Old 12-19-2009, 08:40 PM
hrtatack1's Avatar
my friend almost died from one.
it sprung a leak while he was working under his car, and burned the whole garage up, and his race car. and to add insult to injury his garage is attached to his house. everything was damaged from either smoke or direct heat.
if you want a good indoor heater, look up an amish fireplace..seriously. very, very efficient and very safe
Never let the pimp hand grow weak, keep it loose, keep it strong and keep it busy.
hrtatack1 is offline
post #21 of 53 Old 12-19-2009, 09:22 PM
Seriously, why is it so hard for people to understand the difference between "then" and "than"? They are two seperate words that have two seperate meanings. It's really starting to irritate me how many idiots are out there who graduated high school and can't use these words correctly.
capri is offline
post #22 of 53 Old 12-19-2009, 10:21 PM
Ray III's Avatar
Add to that the people who speak of "4:10" gear ratios, "lb/ft" of torque, "I could care less," and failure to correctly spell simple words like "separate."
Ray III is offline
post #23 of 53 Old 12-20-2009, 12:14 AM
Captain Chaos
Chauncy's Avatar
Your retarded!
Man it pained me to type that.
Canary - Yellow 1995 GTS - Adam - Gamertag: Naldaen
"It's hard to be religious when certain people are never incinerated by bolts of lightning."
— Calvin
Chauncy is offline
post #24 of 53 Old 12-20-2009, 12:17 AM
NIUPonyBoy's Avatar
Then your on the wrong site.
post #25 of 53 Old 12-20-2009, 02:47 AM Thread Starter
who gives a F ----I had a question about a heater
89llx is offline
post #26 of 53 Old 12-20-2009, 02:54 AM
stanger8995's Avatar
ive been using bullit heaters in my garage for years, used to use a kerosene one. Now i have a couple propane units. The propane ones burn pretty clean and dont give me a headache like the old kero one did
stanger8995 is offline
post #27 of 53 Old 12-20-2009, 03:03 AM
ELB Racing's Avatar
http://www.podcastingnews.com/conten...-alone-guy.jpg
ELB Racing is offline
post #28 of 53 Old 12-20-2009, 08:01 AM
Captain Chaos
Chauncy's Avatar
— Calvin
Chauncy is offline
post #29 of 53 Old 12-20-2009, 09:16 AM
tims88's Avatar
The other thing about bullet heaters is that they create moisture on everything in the garage.
Tim
[SIGPIC][/SIGPIC]
tims88 is offline
post #30 of 53 Old 12-20-2009, 10:08 AM
2stangcoupes's Avatar
Trader Feedback: (43)
no probs here.
2stangcoupes is offline
post #31 of 53 Old 12-20-2009, 10:13 AM
Ray III's Avatar
Since when?
Ray III is offline
post #32 of 53 Old 12-20-2009, 10:19 AM
tims88's Avatar
Originally Posted by Ray III View Post
Since when?
Since forever.
Tim
[SIGPIC][/SIGPIC]
tims88 is offline
post #33 of 53 Old 12-20-2009, 10:19 AM
LOL at this statement
post #34 of 53 Old 12-20-2009, 10:21 AM
Ray III's Avatar
Don't make fun of his sound Canuck logic.
Ray III is offline
post #35 of 53 Old 12-20-2009, 10:27 AM
tims88's Avatar
Ummm, if you burn a kerosene heater one of the byproducts is moisture. This is nothing new. Everything in the shop will be dripping with water after an hour or so.
Tim
[SIGPIC][/SIGPIC]
tims88 is offline
HTML code is On
