1922 south bend lathe ''restore'' - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Non-Tech Forums > Lounge
Old 03-01-2009, 12:30 AM   #1
wayne94mustang's Avatar
i picked this up a few weeks ago, it looked bad but it realy worked well. every thing is tight and not worn at all.
here's how it was the day i got it after i painted a few things.....check out the casting date in the last picture.
__________________
94 gt auto becontrolls.com stand alone tranny computer,3000 stall,trannsgo shift kit,3.90s,31 moser axles, qa1 k-member,kb frame ties,mega bite lowers,comp extreme 270-276 dur .544 lift,#24 injecters,pro-m bullit meter,mac cai,pih kit,and all the little bolt ons
wayne94mustang is offline
Old 03-01-2009, 12:37 AM   #2
this is what it looked like about a week later.
alittle buffing on the knobs and handles and more paint.
__________________
Old 03-01-2009, 12:38 AM   #3
You would have loved my dad's old machine shop. It was full of old machines that he didnt use anymore like a museum. I recently scrapped some more of the stuff I trucked home to our barn.
He had a LeBlond Lathe that sat next to the door that was 20's vintage I sold to someone for like $500 and he took it to mexico.
__________________
Non Elite Member #1
1990 SSP
Joe T is offline
Old 03-01-2009, 12:47 AM   #4
here it is with the bed painted and the ways cleaned up.
at this point i needed to build my lathe table so i could have my work bench for tearing the head apart.
the table has a 3/16'' steel plate top thats 3'x4'.
and the almost finished project
i bolted hinges to the motor plate figureing that gravity would keep the belt tight....it does not so i have to add weight to it.
__________________
Old 03-01-2009, 12:49 AM   #5
Probably built better than what they build today.
8950HO is offline
Old 03-01-2009, 12:49 AM   #6
that would of bin neat to see. this is my first lathe but i have messed around with them for over 15 years.
__________________
Old 03-01-2009, 12:50 AM   #7
no doubt in my mind
i'd like to see a 87 year old lathe from today be this tight.
__________________
Old 03-01-2009, 01:02 AM   #8
more random lathe pr0n pics
__________________
Old 03-01-2009, 04:01 AM   #9
Looks great. I spent a lot of time in front of a similar vintage lathe in school, worked great. You can't kill them.
__________________
Sunglasses, if they're cool enough, don't really impair your night driving.
Life's not that hard Man; Take it easy.
Morty91LX is offline
Old 03-01-2009, 04:20 AM   #10
Marlin's Avatar
Trader Feedback: (22)
Vintage tools are damn cool.
__________________
1993 Orange GT with a Fordstrokers 363
2012 Mustang GT
1991 4cyl notch
1992 Mustang GT
Marlin is offline
Old 03-01-2009, 10:27 AM   #11
SATURN5's Avatar
Nice... I have a similar sized Sheldon.
I need to take pics of it finished yet...
__________________
84 SVO Folvo, Cobra suspended and braked
SATURN5 is offline
Old 03-01-2009, 04:19 PM   #12
well, im calling it done, the brass tags are on so now its time to get to turning.
before.....
after.....
__________________
Old 03-01-2009, 04:21 PM   #13
nice, how old is that one?
__________________
Old 03-01-2009, 06:10 PM   #14
SATURN5's Avatar
Not sure... I believe 40's.. I didn't notice a casting date.
__________________
SATURN5 is offline
Old 03-01-2009, 06:43 PM   #15
sohcv8gt's Avatar
Sweet Job!
Just a suggestion on your motor plate, try drilling a hole on the backside or in between the pulley setup and motor. Then continue trhough the plate and take the hole straight through the table. Get yourself a good sized long bolt or piece of allthread rod, and lock two nuts together on the bottom (I'd use loctite), Up top, use a big flat washer, and two nuts so that you can lock it in place. It will be very easy to adjust the tension and since you set it up with the hinges on the plate, maintenance will be easy as well.
Cool project..wish I had room for big toys like that...
Matt
__________________
99 Mustang GT, KB 1.7L, TKO 600, DSS Super Mod, Forged Internals, P/P Heads, Crower Stage II Blower Cams, 31 Splines, Eaton Posi,MM PH Bar,Blah Blah.... 430rwhp/417tq , 65 Fairlane, 07 F150 SCREW
sohcv8gt is offline
Old 03-01-2009, 06:54 PM   #16
Ralph's Avatar
What kind of shape are the ways in? They look a little rough.
I think you did a nice job, just not sure what kind of accuracy you're going to get out of it.
__________________
www.badassmustangs.com <--No chance of AF over there!
Ralph is offline
Old 03-01-2009, 06:55 PM   #17
That is really sweet. Like someone already said that thing is built way better then todays crap. It has lasted 87 years and can easily last another 87.
AHP51 is offline
Old 03-01-2009, 07:35 PM   #18
Originally Posted by sohcv8gt View Post
Sweet Job!
Matt
this was my first thought as well but the thing is, to change speeds i need to lift up on the plate so i can change the belt over to different pulleys.
i then thought low tech and a small rope with a heavy weight hanging through the table would do the trick and i'll be able to change speeds quickly.
__________________
Old 03-01-2009, 07:38 PM   #19
they look rough in the pics but its just the pitting from rust. you can still see the old factory hand scraping on most of the ways. once i ajusted my tail stock and ran a 6''-7'' test cut on some 2'' round stock and it mic'd dead nut on.
__________________
Old 03-02-2009, 08:31 AM   #20
sapperstang78's Avatar
It'll break down now that you messed with it.
__________________
Originally Posted by Dave88LX View Post
Hell yeah! I can't wait to start sucking some cocks!!!
sapperstang78 is offline
Old 03-02-2009, 08:51 AM   #21
speedfreak87's Avatar
Location: New jersey I think..*sniff* yep! it's new jersey..
I totally need one of those for my dads garage...
__________________
F'n Joey
Pain is weakness leaving your body.
www.thefusionsolution.com
speedfreak87 is offline
Old 03-02-2009, 11:32 AM   #22
thats normally how that works but i did find that at least half of the oil passages were cloged with prehistoric grease and dirt so it should be good to go.
__________________
Old 03-04-2009, 11:42 PM   #23
my lathe also came with a full set of 2 and 4 flute end mills so i tried milling on a lathe for the first time the other day.
this is what i came up with, it was a scrap hunk of 1 1/4'' solid round stock.
i also made the piviots and the rod was some 5/16'' stainless that i threaded to fit into the end i made and into the lathe.
i should of bought a lathe years ago.
__________________
You may not post new threads
You may not post replies
HTML code is On
© 2010-2011 Corral.net
