small engine gurus...why won't my lawnmower stay running? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 20 Old 05-03-2008, 03:29 PM Thread Starter
MFE
Super Moderator
MFE's Avatar
Exclamation small engine gurus...why won't my lawnmower stay running?
Tecumseh LV 195 6.5HP vertical shaft engine on a Toro. It'll start, but it won't stay running unless I keep priming it or hold the priming button in, tends to rev up and down, runs rich as hell. I can very slowly release the priming button and it'll fight to stay running until it's almost fully released, and then it'll quit.
Spark plug looks good, was new last year.
Fuel is good
Screen in fuel tank is clean
Doesn't matter whether the fuel cap is loose or tight
Doesn't matter whether the air filter (which isn't bad) is attached or not
I took the float bowl off and it seems to me the float is working OK, and the bowl gasket wasn't leaking.
Ever since I got it the RPMs would cycle up and down on startup until it warmed up, now it won't even stay running.
Is there another fuel filter in this thing somewhere? I don't see a place for one, the line runs from the tank into the side of the carb into a fitting that doesn't look like it contains a filter.
MFE is offline
post #2 of 20 Old 05-03-2008, 03:34 PM
ltdrifter's Avatar
Location: Dodging the guys in white coats in central IN
Possibly an obstruction in the fuel line, crap in the jets or fiddle with the mixture screws a little, if it has any.
Vince
"For there is one thing we must never forget, the majority can never replace the man. And no more than a hundred empty heads make one wise man will an heroic decision arise from a hundred cowards."-A.H.
ltdrifter is offline
post #3 of 20 Old 05-03-2008, 03:37 PM
Trader Feedback: (46)
Lightbulb just a guess
Fuel is good
Try adj the carb and cleaning the jets
yogibear357 is offline
post #4 of 20 Old 05-03-2008, 03:48 PM
If it's an OHV engine, the surging up and down for a few seconds upon cold startup can be common in OHV engines especially with riding mower engines (I know yours is not). If this model has a metal float bowl, the bolt that holds the bowl on is almost always the main jet. If it looks like a type of banjo bolt with some very small cross drilled holes, those holes are the jets and must be completely clean since EPA makes them runs all the engines so lean now. It will actually help if you can open these holes up a thousandth or two. The other type carb has a plastic bowl. Which one do you have?
88 coupe, 351 cleveland, unported 4V heads, buddy rawls custom solid roller, diamond domes, 6'' h-beam rods, stock 4bolt block/crank, holley strip dominator, 950HP holley, hoosier 28x10, 90/10s, UPR pro rear kit
nonstroked, stock iron heads and NO NITROUS!!!!!!!!
10.08@134.83 / 6.44@108.21 (1/8th)
All Cleveland is offline
post #5 of 20 Old 05-03-2008, 03:52 PM
Blk88GT's Avatar
^^^ Listen to him.
Ian
1988 Mustang GT - 422w/IS plate
8.63@158.12 (1.26 60ft) best 1/4 mile
5.39@128.98 (1.31 60ft on the back tires) best 1/8 mile
Blk88GT is offline
post #6 of 20 Old 05-03-2008, 03:54 PM Thread Starter
MFE
Super Moderator
MFE's Avatar
I found the answer elsewhere but All Cleveland nailed it, I didn't realize the brass bolt holding the float bowl on also was the main jet, with little holes in it not unlike a brake line banjo bolt. And although everything looked remarkably clean, I poked all the holes with very fine wire and cleaned it in solvent, dried it with compressed air, and now it runs like a champ.
Thanks for looking fellas
MFE is offline
post #7 of 20 Old 05-03-2008, 05:08 PM
Moderator
Ehardy1971's Avatar
Yeah,it does'nt take much on one of those carbs,what's worse is a weedeater,or chainsaw carb getting a clogged jet,ask me how I know!
'89 LX Coupe
GT40 306 with a few bolt ons and in the 12's
'01 Lightning
#6257 of 6381 Bolt ons, pulleys, and tuned.
'06 TBSS
K&N drop in, and Borla dual exhaust, for now.
Ehardy1971 is offline
post #8 of 20 Old 05-03-2008, 05:27 PM
gobraphil's Avatar
Curses! LAte again... I was gonna ask if you took the time to degree the cam...
2011 Black GT/CS Convertible
6MT /Boss Splitter/LS wheels
gobraphil is offline
post #9 of 20 Old 05-03-2008, 05:31 PM
hellbound911's Avatar
also water/condensation gets into the bowls very well since the mowers sit up so long and that will cause them to shut down also.
mark
“I am the King of Rome, and above grammar”
hellbound911 is offline
post #10 of 20 Old 05-03-2008, 06:59 PM
Lashlarue's Avatar
I had similar troubles on a generator engine and a lawn mower engine, both were caused by small holes in rubber feed lines causing fuel stoppages trying to pump air.Also had a weed whacker that had a kink in the feed line inside the fuel tank, that was a sob to figure out. I was ready to buy a new one[$69.95] and was disassembling that one for parts when I found the kink.
NOT DRIVING YOUR CAR TO KEEP THE MILEAGE LOW IS LIKE SAVING YOUR WIFE FOR THE NEXT GUY
Lashlarue is offline
post #11 of 20 Old 05-03-2008, 07:25 PM
Authorized corral.net Advertiser - Kocky Products
93Cobra#2771's Avatar
Trader Feedback: (25)
Location: Helping Paul/Bob/Michael/Jeff spend Brian's money
I was gonna suggest cleaning the maf element, since that often causes a surging idle... :LOL:
For Sale: Reproduction Window Stickers, 87+ Mustangs, Cobras, Lightnings, and HD F150!
Richard White
H/C/I 93 Cobra
11' Hyundai Sonata 2.0T Limited
11' F150 SCrew 4x4 Ecoboost
96 Escort Wagon 1.9/5spd
96 Geo Metro 1.0 (small block)/5spd
93Cobra#2771 is offline
post #12 of 20 Old 05-03-2008, 08:05 PM
The Shrinkwrap Guy's Avatar
My old Craftsman mower had exactly the same symptoms and it ended up being a damp air cleaner element. Apparently my girlfriend thought it would be a nice gesture to rinse off the mower while I was in the shower, but she didn't realize that the air cleaner should be covered prior to rinsing. Lesson learned.
Chris
The Shrinkwrap Guy is offline
post #13 of 20 Old 05-03-2008, 08:19 PM
Moderator
Ehardy1971's Avatar
Chris
Make sure she does it with shrinkwrap next time!
'89 LX Coupe
'01 Lightning
'06 TBSS
post #14 of 20 Old 05-03-2008, 08:27 PM
Michael Yount's Avatar
Pull the diagnostic codes....and then go in and re-boot your PC for good measure.
Michael Yount is offline
post #15 of 20 Old 05-03-2008, 08:47 PM
Hey, don't laugh... That's what I use when whenever I steam clean the engine bay on my Mustang. It works pretty darn good too.
Chris
post #16 of 20 Old 05-03-2008, 11:29 PM Thread Starter
MFE
Super Moderator
MFE's Avatar
I was afraid to ask if I should set its TPS to 0.977777777777777777777777777779 to cure the hunting idle and speed up the throttle response.
MFE is offline
post #17 of 20 Old 05-03-2008, 11:45 PM
Resting Peacefully
Daywalker's Avatar
It could be broken.
Mmmmmm guns
Daywalker is offline
post #18 of 20 Old 05-04-2008, 06:41 PM
Do you run the gas out of it at the end of the season or use fuel stabilizer?
Leaving gas in it or at least not using fuel stabilizer over the off season is asking for trouble.
8950HO is offline
post #19 of 20 Old 05-04-2008, 08:21 PM Thread Starter
MFE
Super Moderator
MFE's Avatar
I run stabilizer in it before the season is out, and run it as low as I can before putting it away. And it ran pretty OK for the first few times this season, this time...not so much. But it's fine now.
MFE is offline
post #20 of 20 Old 05-04-2008, 08:57 PM
stangPlus2Birds's Avatar
Na, that won't help. You really need to lower the mower more. I'd suggest that you start at 2.5" lower. Then, keep going lower. If you familiar with a tiller, then that's about the height that you should be shooting for. That way, your mower will handle like it was on rails!
Now, this is how mowing should be done!
______
Joe
President of RicersRUs. :-)
stangPlus2Birds is offline
HTML code is On
