How often should you change your power steering fluid? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 04-20-2008, 02:23 AM Thread Starter
texsn95's Avatar
If it ain't broke, don't fix it? Or is there a general guideline as far as years and mileage? I had someone tell me today that the fluid never goes bad unless there is a leak Regardless, I thought the fluid breaks down over time.
Interlagos Blue 06 BMW M5
White 95 Cobra 347 Stroker 355 rwhp 378 rwtq
Grey 2012 Armada Platinum (wife)
texsn95 is offline
post #2 of 17 Old 04-20-2008, 02:26 AM
computers_suc's Avatar
Never, ever.
computers_suc is offline
post #3 of 17 Old 04-20-2008, 02:33 AM
Generally I think you are supposed to change it periodically.... but if you don't it'll just develop a leak and bam half your job is already done.
Win/Win
Non Elite Member #1
1990 SSP
Joe T is offline
post #4 of 17 Old 04-20-2008, 02:36 AM
I've only done it when i've changed out front end pieces, ie: rack and pinion or a pump. If your driving it daily and not going lock to lock ever 10 minutes, it wont need it.
post #5 of 17 Old 04-20-2008, 03:05 AM
Win/Win
Yes, 20 years down the road, i'm sure you'll be kicking yourself for not changing out that PS fluid earlier.
post #6 of 17 Old 04-20-2008, 11:08 AM
Ray III's Avatar
Only needs to be replaced if it gets dirty.
Oil that never gets hot does not break down.
this post property of RAYMOND
Ray III is offline
post #7 of 17 Old 04-21-2008, 12:59 AM Thread Starter
texsn95's Avatar
I've never known how hot (if at all) that oil gets, as the break down is my concern after 18 years and not that it gets dirty.
texsn95 is offline
post #8 of 17 Old 04-21-2008, 11:44 AM
schro31185's Avatar
I just top mine off every 2-3 months when it gets low, so I'd say I change it, every 18 months?
-Paul
1984 SVO - SOLD
1995 F-150, 4x4 302/AT, 3" single exhaust w/ flowmaster 70 series.
2002 Suzuki GSXR 1000, Akropovic can, power commander 3, and a little road rash - 155 hp
schro31185 is offline
post #9 of 17 Old 04-21-2008, 12:16 PM
Kinda like a car with so many leaks your adding a quart every thousand miles, eh?
No reason to change it just put on a new filter every few thousand miles.
Joe T is offline
post #10 of 17 Old 04-21-2008, 01:19 PM
Oktavius's Avatar
At one point, it seemed like I was replacing the fluid at every autocross due to it puking its guts everywhere.
Now I change it about once every year.
Tim ||||||| ||||||| |||||||
07 Subie Impreza - DD
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #11 of 17 Old 04-21-2008, 01:21 PM
Oktavius's Avatar
Never gets hot? Wonder what a power steering cooler is for...
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #12 of 17 Old 04-21-2008, 01:21 PM Thread Starter
texsn95's Avatar
Do you change it using a machine to pump it out, or just drain and fill?
texsn95 is offline
post #13 of 17 Old 04-21-2008, 01:49 PM
Oktavius's Avatar
I drain, spin the pump by hand to pump out the little bit left in there, and then fill.
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #14 of 17 Old 04-21-2008, 01:52 PM
bgjohnson's Avatar
I used a vac system. I'd do it every couple of years depending on use. But mostly, once it stops being red and turns to brownish. Time to replace.
1989 Fox 408W TT REbuild in progress
1979 Yamaha xs1100 restored
1996 splode sport 5spd. Slut beast.
bgjohnson is offline
post #15 of 17 Old 04-21-2008, 01:55 PM Thread Starter
texsn95's Avatar
I'd venture to say the stuff is 18 years old . I know I haven't changed it when I got the car in 2000 at 73k (160k now)
I'm a bit colorblind so I'll get my fiance to check the color
texsn95 is offline
post #16 of 17 Old 04-21-2008, 02:24 PM
poorracerkid's Avatar
I change mine whenever I change the transmission fluid.
All bleeding stops eventually.
poorracerkid is offline
post #17 of 17 Old 04-21-2008, 02:26 PM
Jimmies's Avatar
Yeah, no kidding. When I autocross my fluid is hot as holy hell.
"Don't waste your time, or time will waste you."
Jimmies is offline
HTML code is On
