Mustang SVE 5 Lug Disc Brake Conversion: Part 2 – Rear Brakes - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > Corral Supporting Vendors > Late Model Restoration
Old 05-08-2012, 05:57 PM   #1
Tony@Latemodel's Avatar
Alright guys, about two weeks ago i gave you Lee's Mustang SVE 5 Lug Disc Brake Conversion: Part 1 – Front Brakes. This week I have for you part two! Here is a quick summary of what is going on. Follow the hyper link back to the blog center and let me know what you think!
After wrapping up the front 5 lug conversion using the SVE 13″ Cobra brakes and SN-95 Spindles, we moved straight into the rear brake setup. This section of the install requires the most intensive labor – some modifications will be needed. During Part 2 you will be opening up the differential to remove the rear axles. This is a good opportunity to review some other preventative/predictive maintenance opportunities while you have the rear of the car in the air. If you have been thinking about adding rear end gears, fixing that failing axle seal, replacing those old axle bearings or leaky differential cover gasket, now is the time to do it! Don’t forget the other suspension upgrades such as rear control arms and shocks if they are due for an upgrade.
Tony@Latemodel is offline
Reply With Quote Quick reply to this message
Location
You MUST put your location in your profile. Any other text will be removed and you will have your ability to edit your profile removed as well.
Insurance
Please select your insurance company (Optional)
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
© 2010-2011 Corral.net
