Battery Light Comes On When Accelerating - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 06-16-2005, 04:12 AM Thread Starter
Exclamation Battery Light Comes On When Accelerating
Need Help:
When I drive my car, especially when I accelerate at high speeds on the freeway, the red battery light comes on and then turns off. Sometimes it will come on and then go off. I am the original owner and the car has 100k with the original battery. Is is the battery?? Should I replace it before taking it to Ford and paying a lot to have them tell me to replace my battery. Or is it a charging problem? THX
2001 Gt: FMS 3.73; Saleen Power Flash & Pulleys; Borla XR1 Catback, Bassani X-Pipe w/cats; MAC CAI.
psychstang is offline
post #2 of 9 Old 06-16-2005, 07:21 AM
That light indicates a charging system problem. It kind of sounds like the belt is slipping at high load. How old is the belt? and tensioner? Also, if your batt is 4 years old it could very well be dying to.
Red '96 GT
PI heads and Intake, VT stage II's, Densecharger CAI, Pro-M 85mm MAF, Accufab 75mm TB, 1/2 " intake spacer, MSD Coil packs and wires, Mac Longtubes, Mac O/R H, Flowmasters, Steeda Tri-Ax, Spec Stage II clutch, AL flywheel, AL driveshaft, 3.73's, Max Speed Progressive rear springs, KYB AGX adjustable shocks/struts, GMS upper and lower rear control arms, UPR tubular K and coil overs, Cobra rear swaybar, full lenth subframes, Brembo cross-drilled and slotted rotors, high-temp Kevlar pads, poly bushings everywhere.
dogmush is offline
post #3 of 9 Old 06-16-2005, 07:53 AM
Some good questions have been put to you.....Best to start cheap as far as trouble shooting and work your way up in price. I'd recommend you take the car to any autoparts store that can do a free charging system test (advance auto, autozone, etc) this service is free also. If all is well, check/change the belt. If all is not well and @ 100k miles iF the battery is original equipment, it's definitetly suspect. What about the alternator which charges the battery? Maybe she's dying as well. The tensioner is another good point. After a while that spring for the tensioner can and will loose some it's coil strength. Good luck with trouble shooting and we hope this steers you in the right direction. Let us know how it turns out.
1SLOHRS is offline
post #4 of 9 Old 06-16-2005, 08:31 AM
huesmann's Avatar
I have the same problem, about 92k but the battery is only a couple of years old. I guess I should check the belt/tensioner.
Would a failing alternator cause this problem at all?
huesmann is offline
post #5 of 9 Old 06-16-2005, 11:44 AM
powermod's Avatar
The alternator is what turns the battery light on.
powermod is offline
post #6 of 9 Old 06-16-2005, 12:15 PM
Check and make sure all of your connections are tight (Big 3)
livewire is offline
post #7 of 9 Old 06-17-2005, 09:42 PM Thread Starter
So you guys are saying that my belt could be slipping, which is causing my light to turn on? The belt is fairly new (Motorcraft, replaced by Ford dealership). I did not know that the alternator signals the battery light. The battery charging gauge on the dash, however, shows that all is well. Would a bad battery signal a battery light when accelerating???? Thanks for the advice on getting a charging system check. I will keep you all posted.
post #8 of 9 Old 06-18-2005, 01:28 AM
BlackSunshine02's Avatar
I must agree!!
Criminally Insane Racing
1990 Mustang GT Black 306 with stuff
2011 Mustang GT Silver/Black 6speed with3.73's and vortech - SOLD
2002 Mustang GT Blk/Blk 5speed with 3.90's and a 125shot- SOLD
FIRST COAST MODIFIED MUSTANGS
BlackSunshine02 is offline
post #9 of 9 Old 06-20-2005, 08:00 AM
Yes a bad battery could also trigger the "light". Do you have under drive pulleys isntalled on your stang? Some UDP kits have been known to cause charging problems also. Do the diagnostic and go from there: Charging system test, battery test, belt check/replacement if it's starting to crack/slip, tensioner check. Everyone here is pretty much dead on especially dogmush w/ the belt slippage. Good luck!!!!
1SLOHRS is offline
