Ford Mustang Forums : Corral.net Mustang Forum
Ford Mustang Forums : Corral.net Mustang Forum (http://forums.corral.net/forums/)
-   GT & SOHC (http://forums.corral.net/forums/gt-sohc/)
-   -   need help with cams (http://forums.corral.net/forums/gt-sohc/555766-need-help-cams.html)
MaroonMustangGT 10-04-2004 02:53 PM
need help with cams
i have a 2003 GT. i'm considering cams, but i want a mild street cam. my question is will i have to install aftermarket valves and springs? second, who makes a good set of cams? what kind of HP gains will i see? and last, about how much do they run?
thanks!
superGT99 10-04-2004 07:09 PM
i had good luck with the SHM 2730 cams. stock spings and valves.
nyuk98gt 10-05-2004 09:18 AM
MaroonMustangGT:
MM&FF did a "cams comparo" a few issues back. The Comp 262's looked about the best (imho) for a daily driver that is taken to the track once in a while and you do not need to change springs. I put in 268's (NPI motor here) and they pepped the car up nicely. Comp recommends that the springs be changed with the 268's but I decided to stay with the stock springs since the lift is the same and the duration is not too wild. VT Engines makes some very impressive cams, too -- see the tech article(s) at modulardepot.com. Cams run about $600 per pair. Crane and ModMax make cams, too, for the modulars but I do not know much about them. You will need misc. gaskets, oil, filter, etc. so expect another $50 to $100 out of pocket expenses for the swap. A tune is highly recommended to make the most of the cams and this could run you $400 to $600, depending on where/who you get to tune the car.
Good luck with your selection!
Joe Miner 10-05-2004 02:43 PM
Another vote for the SHM 2730s here. I am making pretty good power with these cams on a headswapped 97 (search for my Headswap numbers post) and am running stock springs.
BLKsteeda 10-06-2004 12:53 AM
Check out VT's Cams...I have the stage 1's in my 01 GT Daily Driver and gained 33rwhp.
Powered by vBulletin® Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
© 2010-2011 Corral.net
