Who's running a torque converter??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 02-14-2002, 12:07 PM Thread Starter
Which one do you have?
Do you like it?
I am interested in one for my daily driven (365 days a year) SN95. What sort of trade-offs are there when using an aftermarket converter?
Thanks.
[SOLD] Sapphire Blue 1995 GT AODE, 3.27, ASP Crank Pulley, "tmoss" ported lower intake, Magnaflow catted H-pipe, FRPP cat-back, "Jerry mod", PI Stallion 2600 Stall
1965 Nova SS 327
novadude is offline
post #2 of 8 Old 02-14-2002, 02:02 PM
I got a 2800 on my re-built AOD-E...got it for $500
not sure about the brand name, but make sure u get a non-lock up trq converter if ur gonna do alot of highway driving cuz it does make the rpm's a lttle higher when cruising on the higway.
i have 4.10's and at 70mph it was at about 2500-2600rpm. Now with the new trq. converter it is a couple hundred rpm's higher, but it pulls very nice on demand!
'98 GT: "Naturally NOSpirated"
- 311 RWHP & 301 trq. N/A -
- 424 RWHP & 449 trq. w/ 125 shot
Loud98SVT is offline
post #3 of 8 Old 02-14-2002, 02:16 PM
bud4660's Avatar
Loud98SVT:
I noticed in your sig. that you used the kit in the trans. Does the computer try to correct the shifting?? I keep seeing everybody say do the chip to change shifting patterns?? Do you know if you do just the shift kit and not the converter change does that cause a problem with anything??
Bud
1967 GT Fastback...(New Toy)
390, C6, 4:56 gears and more stuff.
10 point cage, tubbed.Progress pictures on the link below.
1998 GT Convert. (Sold)
This would be really funny if it weren't happening to me!!!
bud4660 is offline
post #4 of 8 Old 02-14-2002, 02:26 PM
it's not too noticable of a problem...i ran the shift kit in the car with no trq. conv. and no chip for a while, and it shifted hard as hell. but i did blow that tranny cuz i didn't have a tranny cooler and with a shift kit, it alows for more "HOT" tranny fluid to pass thru the tranny making it shift harder..also burning the clutches and shortening the life of the tranny.
I now have a re-built tranny with the new converter, shift kit, tranny cooler and custom burned chip and it feels tighter then the stock on. it shifts just as hard and is more precise cuz the chip turns up the line pressure and raises the rev limiter to work in unisen with the performance parts i added to the tranny
some good advice: if you r gonna do ANYTHING to help the tranny run better (chip/shift kit) spend the $75 and get a tranny cooler "cheap insurance" cuz heat kills the clutches in the tranny really fast and once they're shot it won't engage into gear, and it'll just spin on the flywheel and u won't go anywhere
post #5 of 8 Old 02-14-2002, 11:07 PM
bud4660's Avatar
Thanks for the info!! And if I understand you, even the chip will cause the clutches to burnup without the cooler??
Thanks again!!
Bud
bud4660 is offline
post #6 of 8 Old 02-15-2002, 07:36 AM
I would suggest reading and studying the article "Ford Overdrive Transmissions 101" written by Jerry Wroblewski. It is the most well written and informative article I have seen on the subject. It explains the Ford AOD, AOD-E and 4r70w very well. It also includes specific areas of modification necessary to build and maintain a bullet proof 4r70w, main control modifications, torque converters and driveline harmonics. http://www.tccoa.com/articles/tranny/transmission/index.shtml
Hope this helps.
98GT 4.6L 2v Auto
Best 1/8 mile E.T N/A
60 FT______2.106
1/8 ET_____9.34
MPH_______75.86
Best 1/8 mile E.T. NOS 75 shot
60 FT______1.887
1/8 ET_____8.247
MPH_______85.91
88 LX
Work in progress...
nailpounder is offline
post #7 of 8 Old 02-15-2002, 07:50 AM
John Edwards's Avatar
torque converter
I have put about 40,000 miles amd 200 1/4 passes on mine with a Precision Industries 4,000 lock-up converter. Car still gets 23-24 mpg. The only time I notice it is at slow speeds below 45mph and when racing. Times in sig.
John Edwards
SPONSORS WANTED for 2004 season. PM or e-mail for details.
99 GT NA 2V 4R70W
FFW Steeda/Hyland Mod Motor Top Ten Eliminator Club Member
1999-2000-2001-2002
7.34 @ 94.45
11.57 @ 116.93
350 HP 337 TQ SAE
modmaxracing.com
propowerparts.com
performanceautomatic.com
foxlakeracing.com
John Edwards is offline
post #8 of 8 Old 02-15-2002, 10:06 AM
bud4660's Avatar
nailpounder:
Thanks for the info I will print that off and keep it!!!
Bud
bud4660 is offline
