Want to remove center console - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 03-02-2003, 09:10 PM Thread Starter
Dane Basch's Avatar
I need to remove it. I know there are screws under the rubber things that pad the arm rest. Any other screws/clips/bolts/etc hiding from me? Can I do it without removing the parking brake handle (looks like it, but just checking)?
Any tips appriciated.
Thanks.
Dane Basch
2000 Saleen Mustang S281 Serial #282
aka "The Daemon Saleen" (search it if you want to know why)
The Daemons have been exorcised!!!! The old MM-wrecked GT motor is gone. A 2003 Terminator heart beats in its place. You lost, person for whom I have much hate.....my car survives!
Dane Basch is offline
post #2 of 7 Old 03-02-2003, 09:43 PM
Trader Feedback: (25)
alright man your gonna have a pm here shortly
97 Roush GT- Novi 2k blah blah 550hp
03 cobra 11.34 @ 126
Roush97 is offline
post #3 of 7 Old 03-03-2003, 12:36 PM
ForPointSex's Avatar
From what I can remember there are 2 screws in front, and 2 inside the console. You do not need to remove the parking break handle to remove it. You must pull the brake handle the most vertical you can. I mean, really pull it hard up. Should be easy from there.
ForPointSex is offline
post #4 of 7 Old 03-03-2003, 03:40 PM Thread Starter
Dane Basch's Avatar
Thanks guys. Got the instructions from Roush97, and it was just fine. Only one harness to disconnect on mine, right under the shifter. Everything else was simple.
Great place; you need a question answered, post it! Mustang people is the bestest people!
Dane Basch
post #5 of 7 Old 03-04-2003, 06:16 AM
SnakeBit's Avatar
and the Corral.net is the bestest site!
Fred
03 Cobra Coupe DSG
“You don’t need the bullet when you got the ballot.” ~George Clinton
SnakeBit is offline
post #6 of 7 Old 03-04-2003, 11:14 AM
medik13's Avatar
Can someone please tell me how...I have to replace my plastic parking brake to a leather cobra one. Can I replace it without removing the center console?
2001 Silver GT Vert
Current Mods: Accufab Plenum, Accufab 70mm TB, MagnaFlow CB, VRS catted X, Steeda Tri-AX, FMS C Springs, 18" WR Bullitts, 03' Cobra Body Peices
medik13 is online now
post #7 of 7 Old 03-04-2003, 04:35 PM
if you do need the directions here is the pm i sent dane:
the screws under the little rubber things hold in the compartment...when you take those little screws out you can pop out that compartment...when you pop that out there are two bolts right in there that need taken out...now there are only two more screws left...take out that peice that goes around you shifter...i dont know if you have an auto or manual but i imagine they are probably the same...when you take that peice out there are two bolts that connect it to the middle of the dash...you wont be able to miss them...they are the only bolts/screws holding it down...now pull up on the ebrake as far as it will go...now pull up and forward and it will come up...now if you have the fog light switch and whatever else you will have some electrical harness to disconnect along with the lighter...good luck
Roush97 is offline
