Just picked up a 02 GT with only 106k miles for a song, it so far has a centerforce clutch, long tubes, BBK high flow cats, x pipe, Flowmaster cat backs, CAI.
I'm setting myself a budget of about $1,000-$1,500 for some goodies in the engine bay. I'm thinking a set of decent cams, valve springs if needed, tensioner/guides, maybe a TB and intake. Maybe all of the above in some sort of kit?
I plan on DDing the car, I drive 4 hours a day for work, so I'm not after a track monster. Just something to make commuting suck less.
Any recommendations would be great, with links! Thanks!
Subframe connectors and a tune - makes the car a lot more rigid and the tune will increase throttle response and extract a couple dozen horsepower, particularly with long tubes already on there. Cams will give you a few more ponies; TB and intake really won't as they are not much of a restriction for these cars.
Unfortunately these motors don't respond all that great to basic boltons. If it doesn't already have a 3.55 or 3.73 gear, that would probably be the first thing I did. I wouldn't go too crazy with the amount of daily you do on it. Larger cams may get old quick as well with that mount of driving. Other than that probably some connectors and lower control arms, sticky tires, and like mentioned a reputable tune.
On a daily driver that you do not plan to take to the track I would skip cams. It seems like drivability is a major concern for you- the small hp gain is not worth the drivability loss (stuttering, idle, startup etc). Keep your stock cams- they offer great daily drivability.
I went with Steeda springs and Koni shocks/struts(Gabriel for the quad shock).Night and day difference on a 100k mile car.Mine is a vert so it already has a stiffer frame.
Gears(3.55) if you do a lot of highway driving)and a tune.
Shifter is a solid upgrade.
Steeda underdrive pullies if you want a little extra.
Control arms are great but you may not need them on the street.If you aren't wheel hopping you may not need them.
I did a plenum and 70 mm TB on mine cause I got them both on sale.May not make much difference but my automatic needs all the help it can get.
Dont do the cams, go for gears 3:55 or 3;73 and keep it in stock mode if you get a Programer for the gears, this way you can still use Reg fuel/ save some money if a DD....I did the Stage1 Cams and wish I just did the SC a little later instead, my thought
Related Threads
Ford Mustang Forums
9.8M posts
200.7K members
Since 2001
