Hidden Antenna Module - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 35 Old 09-11-2002, 12:11 AM Thread Starter
California Mustang is selling an antenna module that can replace the mast. It's about $30. Has anybody got one of these things, and do they work?
NorthwestGT is offline
post #2 of 35 Old 09-11-2002, 12:31 AM
not much info, but I bet this is it:
http://www.visteon.com/technology/au..._antenna.shtml
looks like you have to mount it in a window...
$30, worth a shot I guess.
True Blue 01 GT Vert
Cat Back
with
Brakes, Pedals & Fuel Door
Goodridge SS Brake Lines
Ecsta Supra 712 275/40ZR-17 tires
Mach1 Chin Spoiler
Auxilliary Input for Mach460
TrueBlue01Vert is offline
post #3 of 35 Old 09-11-2002, 01:34 AM
powermod's Avatar
You mean this thing:
Looks like a good idea. Get it and report back how it works so I don't have to waste my own $30.
powermod is offline
post #4 of 35 Old 09-11-2002, 01:52 AM
FlowJack's Avatar
If that provides just as strong of a signal as the antenna, I would definately buy that.
Report back with your findings!!!
FlowJack is offline
post #5 of 35 Old 09-11-2002, 02:35 AM
powermod's Avatar
That module would be nicely complemented with this antenna delete plate:
http://www.mustangparts.com/images/rantplate.jpg
powermod is offline
post #6 of 35 Old 09-11-2002, 10:23 AM
Fast Eddie 2k1 GT's Avatar
I would prefer an electric raised/lowered antenna. Any body make one?
3X black premium 2k1 GT 5 speed ragtop
Drive Train:
FMS 3.73 gears, Vortech SQ, AFM powerpipe, FMS aluminum D/S, Steeda shifter, 80 mm MAF, Steeda Fuel pump, SnowPerformance water injecton, BBK 75MM TB, C&L plenum, SCT chip
Wheels/Tires: 10th anniversary Cobra, Nitto ZR 275 x 40 x17
Suspension:
TKO 5 way (years 87 to 93 for 94+ lowered stangs), Vert Eibach Pro Springs, offset rack bushings, Steeda c/c plates, Steeda subframes w/cross brace, Steeda X2 balljoints and bumpsteer
Interior:
99 Mustang A-pillar covers, Autometer A-Pillar gauge pod, Autometer FP and boost gauges, 03 Cobra headrest
Exchaust:
Steeda catback (Borla) wholesale price
RWHP/360 RWTQ/360 SAE corrected
Very conserative tune.
69 Maroon Torino GT Fastback
Eddie
Fast Eddie 2k1 GT is offline
post #7 of 35 Old 09-11-2002, 11:16 PM Thread Starter
I think I'll buy the thing from Cal-Mustang. I had in mind using an antenna delete plate. Pictures of the new Mach 1 seem to show it antenna-less.
post #8 of 35 Old 09-12-2002, 04:10 AM
Corral Member
esandes's Avatar
Eddie, thats tacky man, for a sports car. Remember those 80's sports cars that had the hidden headlamps?
esandes is offline
post #9 of 35 Old 09-12-2002, 06:13 AM
I want to put an automatic one on my cobra. I have to take my mast on and off every time I drive it to put the cover on. Anyone install an electric antenna in the stock location?
cobra96_1252 is offline
post #10 of 35 Old 09-12-2002, 10:13 AM
Custom2kGt's Avatar
If you are going to delete/move the antenna only use the delete plate until you can afford the body work to cover it properly. Yes the car would look better w/o the antenna, but do it right. I don't know pricing on body work but it couldn't be more than 200 bucks to fill the hole and paint. Obviously the car cover issue can be resolved by the electric antenna. I think JC Whitney has some. For what it's worth I don't think that would be too cheesy, just don't get a super tall antenna.
Just my .02 guys.
Custom2kGt is offline
post #11 of 35 Old 09-12-2002, 01:50 PM
You could just mark your car cover in the position of your antenna. Then take it to an upholstry shop and have a grommet installed. Shouldn't be more than $10.00 if they charge you at all.
Silver 01GT (DOA)
UPR Blue Thunder Shifter
Magnaflow Catback
"Honey, I never drive faster than I can see. Beside's its all in the reflexes."--Jack Burton
kmbgt is offline
post #12 of 35 Old 09-12-2002, 03:10 PM
Custom2kGt's Avatar
that's a good idea, or simply unscrew your antenna each time you put on your car cover, just a thought.
post #13 of 35 Old 09-12-2002, 03:24 PM
Andrew WOT's Avatar
Did anybody actually use that antenna delete plate?
What is involved in installation?
98 GT Black 4R70W;
01 P&P heads (Stage1 Fox-Lake); Bullitt intake (port matched); Steeda pulleys; WMS Velocity Tube/87mm Pro-M Bullet Combo; 24lb injectors; 180 Thermostat;
SCT Racer Kit; Denso IT16; FMS 9mm wires; Hawker ODYSSEY PC680MJ battery;
JBA headers; Magnaflow X pipe w/cats; Borla Cat Back;
FMS 3.73 gear; PI Stallion 3200 (multi disk lockup); Jerry Mod; B&M Race tranny cooler; FRPP Aluminum Driveshaft; Metco Driveshaft Loop;
H&R Race springs; Tokico Illumina shocks/struts; MM full-length SC; MM CC plates; MM LCA;
Hawk HPS brake pads; 255/45/17 Toyo Proxes T1S;
13.3@102.678 1.85 60' Racing weight: 3540 lbs
Andrew WOT is offline
post #14 of 35 Old 09-20-2002, 08:43 PM
Talking Has anybody tried this? Does it work good?
I want to do it but I want to keep my clear radio reception that I currently have. If anyonehas tried it, please post ur opinion. Thanks
Look at my suave banana dance! Dance well little banana..... Click here to see my banana dance --->
Saleen0296 is offline
post #15 of 35 Old 09-20-2002, 11:33 PM Thread Starter
I'll let you know in a week or two. I just ordered one today, along with that antenna delete plate. California Mustang says you can mount it anywhere in the car. I'll try to stick it under the fender below where the stock antenna mounts.
When I get a few extra bucks, I'll visit my friendly body shop guys and ask them to fill in the hole and paint both my fenders.
post #16 of 35 Old 10-24-2002, 01:30 PM
powermod's Avatar
So how did it work out?
powermod is offline
post #17 of 35 Old 10-25-2002, 07:54 PM
99SaleenS281's Avatar
I did the hidden antenna/cobra R delete plate last weekend. The antenna has to hook up to a +12v power source, which I did (checked it w/my volt meter). I put it in the fender directly below where the old mast was. Results? I get 0 reception. I don't even kind-of get any station at all, zip zero nadda. Just static across the AM and FM bands... Maybe my unit was defective, whatever, I'm gonna call them next week and find out how something advertised as being able to receive all your favorite station doesn't receive jack.
The plus side? Car looks really good from the front.
99 Saleen S281, #137
Goes:
S-trim, HP pipe, Diablo tune, 83mm MAF, 70mm TB, JBA headers, Magnaflow X-pipe, BAR Upper, 03 Lower, MSD Stacker 8, 03 Cobra pump/tank, 42s, 180* t-stat, PI 2400 stall, Art Carr 4R70W, Jerry's mods, rear girdle, HPM loop, tranny cooler, poly mounts, Canton pan/windage tray
Turns:
GW subs, f/r STBs, complete MM front end
Misc:
rear seat delete, Corbeau seats, clear corners, Clarion deck, gauges, HIDs
374rwhp 359rwt SAE
99SaleenS281 is offline
post #18 of 35 Old 10-25-2002, 09:33 PM
PhatDoggy's Avatar
Take a guess at what material is an EXCELLENT shield for radio signals...metal. And your fender...metal. If you put your receiver in a location that isn't heavily shielded (behind glass, for instance), you will pick up a signal (assuming it's not broken). Like Mikey...try it, you'll like it.
-Keith
...with an '02 engine
Fraudulent business warning: SD Wheeler (aka TheGame, shadoworks, LoneStarGT, darchangel) is a crook.
PhatDoggy is offline
post #19 of 35 Old 10-26-2002, 12:15 AM
I did think about that, but they also said you could "mount it anywhere". Kinda be a shame to mount a "hidden antenna" in plain sight.
post #20 of 35 Old 03-04-2003, 07:36 PM
Silver98GT's Avatar
99Saleen, any pics with the antenna delete plate?
98GT
Silver98GT is offline
post #21 of 35 Old 03-04-2003, 09:47 PM
natx808's Avatar
wow you guys are pretty anal, I don't take off my antenna to put the car cover on! LOL I just let the frickin thing bend over like it is catchin a bass.
"Irreverence is the champion of liberty and its only sure defense."- Mark Twain
natx808 is offline
post #22 of 35 Old 03-04-2003, 10:40 PM
yea a friend tried this ... yellow stl gt.. and he said that it didnt' work either
NATHAN
98 MUSTANG GT
bolt-on's that put it in the 13's
LILRED is offline
post #23 of 35 Old 03-05-2003, 06:10 AM
I bought a plastic grommet that snaps together through a small hole you cut for the antenna. It works really good. I'll look for the info of where I bought it and post it later.
2000 GT Black
PYRT is offline
post #24 of 35 Old 03-07-2003, 10:34 PM
Ayrton's Avatar
Did anyone find out if the $30 hidden antenna worked or not, or is there another one?
Ayrton is offline
post #25 of 35 Old 09-22-2003, 03:10 AM
powermod's Avatar
So did anyone have any luck with the CA Mustang antenna module? I would like to get rid of my antenna, but if this thing doesn't work I would like to know.
powermod is offline
post #26 of 35 Old 04-04-2004, 04:03 PM
Cal Mustangs sell the same HAM as the link below.
http://www.roddoors.com/sohidant.html
I have one, and it works great . I mount mine on top of the windshield behind the rear view mirror. Took me 5 mins to installed. The hardest part was removing the head unit.
Please note you cannot mount it under metal. It does not work.
philmiup is offline
post #27 of 35 Old 04-04-2004, 05:08 PM
If that works Id be interested. Do you have any pics of it installed? I don't use my radio at all. That's why I have Kazaa Lite and a CD burner. But I hate having that big antenna on the car.
90 Vette ZR-1 red/red 6 speed 12.85 @ 112.3
99 GT green/tan 5 speed 13.97 @ 101.3
AIM vettesarethebest
yahoo lt5zr180 feel free to IM me anytime Im on
99 GT Coupe sw is offline
post #28 of 35 Old 04-04-2004, 06:36 PM
I have often wondered if it's possible to just use the antenna module that's stock on 95+ Crown Vics. It's mounted on the metal panel between the rear speakers in the trunk. Those cars have good reception, but there is a separate pattern in the glass near the top.
2000 V6 with these bolt-ons:
2001 5.4L E350 Engine
T45 5-speed
FRPP Aluminum driveshaft
8.8 t-lok and 3:73's
Intrax 2" drop
JS15132 is offline
post #29 of 35 Old 04-04-2004, 10:16 PM
I dont have any pics. I just stick the HAM behind the rear view mirror, run the line across the top of windshield trim panel, down the passenger side A pillar, under the glove box to the back of the head unit and connect the power line to a good 12 volt source.
If you stand outside in front of the car, you cant even see the HAM cause the the top of the windshield have factory tint.
IMHO, the FM station works great. AM station is ok.
philmiup is offline
post #30 of 35 Old 04-04-2004, 11:00 PM
Where in Pittsburgh are you from?
post #31 of 35 Old 04-05-2004, 08:25 AM
Where in Pittsburgh? McKeesport, hence the 15132.
T45 5-speed
Intrax 2" drop
JS15132 is offline
post #32 of 35 Old 04-05-2004, 10:25 AM
Im from Cranberry.
post #33 of 35 Old 04-05-2004, 10:58 AM
Where did you run your 1/4's? I'd like to take my 5.4 out and see what it will do N/A before I try to stuff a blower in there. A lot of people around here go to keystone.
T45 5-speed
Intrax 2" drop
JS15132 is offline
post #34 of 35 Old 04-05-2004, 12:42 PM
I just looked at the crown vic radio and rear defrost schematics, it looks entirely possible to use it. The antenna module connects to the defroster grid and the defrost power lead goes to the antennal module, the module isolates the two systems and uses the grid as an antenna. I think I'm going to try to hook one up, I have dozens of those modules lying around at work. Worst thing could happen is I fry the factory head unit.
T45 5-speed
Intrax 2" drop
JS15132 is offline
post #35 of 35 Old 04-05-2004, 01:02 PM
I ran that time at Quaker City. But I do go to PRP (Keystone) alot.
