Why does my driver side window not roll down in extreme heat? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 08-04-2012, 03:21 PM Thread Starter
NJBlackGT's Avatar
Okay, I'm starting to get a little irritated by my driver's side window. It decides not to roll down in the extreme heat. What gives? I get in the car and I don't have the opportunity to let the interior cool down a little after it sits in the hot sun. Anyone else have this issue? Solutions??? Once it cools down, then it's okay.
2003 GT (5 speed) - TFS heads & cams, full exhaust, 3.73 gears, CAI, t-body, plenum, dyno tune... just to name a few
NJBlackGT is offline
post #2 of 16 Old 08-04-2012, 08:29 PM
wmburns's Avatar
Consider that the Mustang's power windows are controlled by a automatic reset circuit breaker. There is a CB in the battery junction box under the hood and there is also a CB in the window motor itself.
A CB can sometimes be affected by heat. IE, very high heat may make a CB trip at a lower point. However, I think the CB is just bad.
If only the driver's window has the problem, then likely the CB in the engine bay is OK.
wmburns is offline
post #3 of 16 Old 08-05-2012, 07:41 AM Thread Starter
NJBlackGT's Avatar
Thanks. Is there any way to simply "test" the condition of the circuit breaker in the window motor before just replacing it?
post #4 of 16 Old 08-05-2012, 09:18 AM
huesmann's Avatar
Does it not roll down at all, or does it roll down partway and get stuck?
huesmann is offline
post #5 of 16 Old 08-06-2012, 01:15 AM Thread Starter
NJBlackGT's Avatar
It won't roll down at all actually.
post #6 of 16 Old 08-09-2012, 02:00 AM
04Ryan's Avatar
My 04' did this if left parked in the driveway with the sun beating on the drivers side door all day...I was told by a Ford mechanic that the power window motors will do that when they are going bad. I owned that car for 3yrs and never had a problem if it was parked in the garage. It never failed and never slowed down going up or anything like that...I did notice that sometimes if it acted up I could slam the door closed and it would start working again LoL So I'm not sure if it is a sign of a motor going out...but I do know that not all Mustangs do that. So something must be wrong with the motor....
1992 2V Notch
S-Trim 14lbs
10.53@133
04Ryan is offline
post #7 of 16 Old 08-09-2012, 07:56 AM
bullitt 736's Avatar
^^^^^^^^ my first Bullitt did that three or four times over the years. 145k.
Bullitt #2 has done it once in 50k.
Both are still on the stock motor.
Slam the door while holding the switch always worked.
Charles - Bullitt 736
bullitt 736 is offline
post #8 of 16 Old 08-10-2012, 09:31 PM
double0fox's Avatar
Had this happened to me till it finally just quit working. There is a circuit breaker under the dash in the fuse box. Changed that, and started working right away.
1997 Viper GTS
2000 Mustang GT
2007 Honda 600RR
double0fox is offline
post #9 of 16 Old 08-21-2012, 10:33 AM
WrenchThrower's Avatar
Thought I was the only one with that problem. It only happens when going through taco bell though.
4.10's,CMS stage I cams, auto, Pypes O/R X-pipe,SLP power flow exhaust, Trickflow 70 mm tb/plenum, Trickflow SFI U/D Pulleys. Ford B springs,93 Octane tune.
WrenchThrower is offline
post #10 of 16 Old 08-22-2012, 10:18 PM
Member
Floordford's Avatar
Trader Feedback: (15)
My passenger window is doing this to me also. It only happened after I had been broken into so I thought it was the window regulator. Or maybe the motor not wanting to work in the heat. Its odd because when it gets into the 60s it works fine. Anything hotter and it wont budge.
Sold-2000 GT-bolt ons and suspension. 273hp/ 309ft.lbs.
Good bye old friend
Floordford is offline
post #11 of 16 Old 08-24-2012, 01:09 AM
02gtfromky's Avatar
My passenger window will not roll down or up from driver side 95% of the time. Passenger side switch works fine. Replaced the switch on the driver side and no change. Any ideas?
2002 gt
full bolt on's, built 3650, zex 125
awaiting install- heads, hitech stage 2's
02gtfromky is offline
post #12 of 16 Old 08-24-2012, 08:29 PM
easy fix...while holding down the window button put a little pressure on the window with your hand and push down. Always works for me
2003 GT 5spd - 01 Cobra wheels, H&R ss springs, Tokico blues, Upr off road X, 40 series, Borla style tips, Tri-ax, Bullet center console, bullet pedals...
Slayerripkdc is offline
post #13 of 16 Old 08-24-2012, 10:20 PM
Member
Floordford's Avatar
Tried that. Did nothing. Switches work fine and it rolls down fine when it wants to. But it just needs to be a cool day with all the planets lined up for it to work. I keep it up even after i check if its temporarily working. Im afraid it will get stuck in a position other than all the way up.
Good bye old friend
post #14 of 16 Old 08-25-2012, 08:19 PM
trueblue01stang's Avatar
There's a break in one of the wires. Had the same problem a while back.
1999 Black 35th Anniversary Edition GT #2803/4628 (wrecked. waiting on the money tree to grow)
2001 True Blue "V6" (semi-sleeper junk box with a drive train and interior swap)
trueblue01stang is offline
post #15 of 16 Old 09-17-2012, 11:39 PM
Member
Floordford's Avatar
Any updates to speak of? Im thinking of replacing the whole motor/ regulator assembly.
Good bye old friend
post #16 of 16 Old 09-23-2012, 07:58 AM
Deceptive GT's Avatar
I was told by a Ford Mechanic that there was an issue with the first gen window motors in these cars. If you hit the door about where the motor is, it should start working.
02 GT Vert Project "Deceptive GT"
Waiting to Strike!
Deceptive GT is offline
