Kenne bell boost a pump wiring help... - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > Modular Tech Forums > GT & SOHC
Old 08-03-2012, 05:19 AM   #1
DriverMod's Avatar
I got the unit mounted nicely and am ready to begin wiring. Can anybody put this in simple english for me ? I am reading that it is a simple 3 wire hook up for 99-04 GT. 1 to ground. 1 to a green and yellow wire going into the inertia switch, and the other smaller fused power wire to another green and yellow wire in the harness running along the trunk panel. Is that the same for 98 GT ? The instructions make it seem far more complicated than this lol. Any help would be appreciated greatly. My brain is still fried from all the nitrous wiring.
__________________
98 Mustang GT
Patriot Pi heads / Comp 270's / Longtubes / Full Exhaust / 373's / NX 100 shot plate for now....Intercooled Tork Tech kit with Posi-ported Eaton under way. Staying E-85 and going to be even more PISSED!!!
DriverMod is offline
Old 08-03-2012, 07:26 AM   #2
DriverMod's Avatar
Anyone ??? ?
__________________
98 Mustang GT
Old 08-03-2012, 08:44 AM   #3
PM me your email, I'll send you a good diagram for install
__________________
1999 GT/Cobra clone
Built 4.6 2v, MP 70mm turbo Done blown'd it up!
New build Turbo teksid 4v swap
fsstnotch is offline
Old 08-04-2012, 12:30 AM   #4
DriverMod's Avatar
Ok. It's wired in and everything seems to be working. I had the lethal performance wiring upgrade for the boost a pump. Thats what made it confusing. The car runs and drives like normal so i am assuming the booster is working. I am going to try to find a way to test the voltage tomorrow. Any ideas where to probe?
__________________
98 Mustang GT
Old 08-05-2012, 02:06 AM   #5
swinerton's Avatar
Yellow/brown wire. Probe + there, and the other lead from your VOM to ground. Did you leave the Hobbs switch out? If so, you can turn the knob from 0-50%, and watch voltage climb to around 17.
__________________
Cory Swinerton
2013 Boss 302 #540 712rwhp/592rwtq
Originally Posted by WhiteLX408 View Post
Running street tires at the track is like wiping your ass with a turd.
swinerton is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
