4.6L twin turbo build - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 11-24-2011, 11:32 PM Thread Starter
Question 4.6L twin turbo build
I'm starting to collect parts for a 4.6L twin turbo SOHC motor. Initially, I was planning on building a 351W motor. Once I found out how much stronger the mod motor blocks were from the factory, I switched to the newer (to me) block. My plan is to purchase a 4.6 MMR Street Mod 600 shortblock. Bolt on a pair of TFS TW Track Heat 185s and later a pair of T28 turbos. Anyone running a combo like this one? Should I go with a single turbo (T76) instead? The block is rated for 600 rwhp, that's plenty for the street.
Nitrous Al is offline
post #2 of 15 Old 11-25-2011, 01:46 AM
The block's not the weak point in the MMR 600, the rods and pistons are what limit it to 600rwhp. I think the Trick Flow heads won't be needed for just 600 rwhp. Check out this article
ModularHeadShop real world 600RWHP combo
TWISTED2v is offline
post #3 of 15 Old 11-25-2011, 05:23 AM
2002 SN95 GT's Avatar
i should be building a 4.6 dohc in the spring or summer, and make it twin turbo a year or 2 later im going to have the compression around 9.5-9.85 so i can run N/A for a while and run lower boost and still have good drive ability while not spooled up, ive already got a teksid block, and mach1 intake, i need to find a set of 03-04 C heads
but going twin or single can cause some arguments, alot of people told me to go single and im still going twin, im going to go with 2 57mm Comp turbos with ball bearing and billet wheel, should spool real nice
i think going with 2 small turbos over a larger single will probably give you better mid power and pretty good peak power, while the single may give you major top end
im doing twin for the sleeper look, clean engine bay and the turbos are up front tucked in behind the front bumper
1996-2004 mustang turbo system
if you want to go single i think a 60mm should do great and spool fast, i got a friend with a built 05 Gt with a single 60mm turbo
be sure to at least get a billet wheel
2003 Mustang Mach1 5 Speed, K&N intake, Xpipe, 3.73 gears, J&M Uppers and Lowers, Bama Tune
2008 Suzuki GsxR 750 K8, Gears, Power Commander, GP Guspension, M4 slip on
2002 SN95 GT is offline
post #4 of 15 Old 11-25-2011, 12:23 PM
Trader Feedback: (22)
Get you a single precision billet 67mm and a quality hotside
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #5 of 15 Old 11-27-2011, 12:41 AM
swinerton's Avatar
Trader Feedback: (15)
This^^^^
Quick spool, and will support 600rwhp perfectly. Easier to plumb, and less headaches. Cheaper too.
Cory Swinerton
2013 Boss 302 #540 712rwhp/592rwtq (SOLD)
1999 GT 2V 775rwhp Ysi, Boss 304". (SOLD)
Originally Posted by WhiteLX408 View Post
Running street tires at the track is like wiping your ass with a turd.
swinerton is offline
post #6 of 15 Old 11-27-2011, 01:30 AM
Where's a guy get a quality hot side that retains the factory accessories?
00GT4.6 is offline
post #7 of 15 Old 11-27-2011, 02:22 AM
im getting a turbo kit from HP performance at a later time but they say their kit retains all factory accessories, give them a call and see if they will sell you a hot side, its a twin kit
im getting comp turbos for my build, i got a friend that is a dealer for comp turbo
and for turbo size a billet 60 should be fine for 600hp, bigger is just going to take longer to spool,
and a billet 65 should hit 5-6psi by 2400 rpm
message probercr93 http://forums.corral.net/forums/memb...robercr93.html
he is the one with an 05 GT with a single turbo and knows some pretty good stuff and he is a dealer for comp turbo
post #8 of 15 Old 11-27-2011, 07:09 AM Thread Starter
Maybe a single turbo IS the way to go.
post #9 of 15 Old 11-27-2011, 12:02 PM
I was asking about a quality hotside kit for a single turbo.
00GT4.6 is offline
post #10 of 15 Old 11-27-2011, 11:56 PM
y2k02's Avatar
My twin 60mm HP kit seems to work well.
I have a full hotside to a HP 1st gen kit setting in my garage.
2002 2v TF heads Logan Intake NA SVT Cams
Twin 60mm Turbos TH400 Holley Dominator EFI
y2k02 is offline
post #11 of 15 Old 11-28-2011, 12:44 AM
04Ryan's Avatar
Couple guys on here are running a CG Fabricators hotside...he's out of TX and builds some quality stuff from what I've seen.
1992 2V Notch
S-Trim 14lbs
10.53@133
04Ryan is offline
post #12 of 15 Old 11-28-2011, 12:47 AM
His headers don't allow you to keep all factory accessories. Which I'm wanting to do.
00GT4.6 is offline
post #13 of 15 Old 11-28-2011, 01:01 PM
I have an on3 kit with upgraded IC, turbo, and mass air. 683hp stock block bored .020 dished srs pistons, h beam rods, 8 bolt crank, studded everywhere, stock heads. I was told an early 4.6 block is capable of 1000hp... dunno that I'll push that limit but... almost 700hp is fun too! lol Going to buy some shorties and an edelbrock intake and see what I get out of her.
1999 GT/Cobra clone
Built 4.6 2v, MP 70mm turbo Done blown'd it up!
New build Turbo teksid 4v swap
fsstnotch is offline
post #14 of 15 Old 11-28-2011, 02:22 PM
somebody needs to get a car down to cgfabrication where he can make some headers that work with a/c. im not sure if the front swaybar works with his kit either, im still waiting to install all of my stuff. he does list it as a "race kit" though, but needs to come up with a street kit sometime in the near future. i think thats what mostly everybody is wanting
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #15 of 15 Old 11-28-2011, 02:24 PM
Agreed. I've talked to him at CG Fabrication and he said he would do it if someone brought in a car for him to mock it up. I wish I lived closer because I would let him use my car lol
00GT4.6 is offline
